07-14-2020, 12:35 PM | #23 | |
Rep 104
Drives: BMW 328i
Regardless of all of this you will want to change the bulb type to LED in the front electric module anyway, otherwise your not making full use of the advantages that LEDs offer. This coding is all VERY easy to do in bimmercode, literally takes 5 minutes and the warm/ cold checks and bulb types options are right on top of each other. |
07-14-2020, 01:49 PM | #24 | |
Rep 90
Drives: 2013 BMW 328i
07-14-2020, 02:40 PM | #25 | ||
Rep 104
Drives: BMW 328i
There are tons of awesome things you can activate, a well worthwhile investment. |
07-14-2020, 04:46 PM | #26 |
Rep 90
Definitely! Which app are you using for fault reading?
07-14-2020, 04:54 PM | #27 | |
Rep 104
Drives: BMW 328i
08-05-2020, 08:33 PM | #28 |
Rep 90
Could you drop a link to what bulbs you used for the parking light and the drls? I think I am going to settle with the aukees for the low and high beams plus those beamteach fogs that billfitz recommended. As far as the turn signals go I dont really care about them to be honest and will probably leave them as is.
08-06-2020, 10:51 PM | #29 | |
Rep 104
Drives: BMW 328i
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 And these are the ones I bought for my parkling lights (position lights i think they're called in bimmercode). I can't attest that they work because I ended up changing headlights before I could ever install them. However, they were the exact ones everyone else was buying on the forums. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Goodluck! |
08-07-2020, 12:20 AM | #30 | |
Rep 104
Drives: BMW 328i
https://www.amazon.com/dp/B079NSBTF8...p_mob_ap_share I had trouble finding turn signals that would work, in my experience they are trickier than the other bulbs. I ended up using the LED turn signals from unique style racings and they work great. But like you said, not a necessity. |
08-07-2020, 07:22 AM | #31 |
Rep 16,054
LED turn signals react faster, and they're brighter, so they're well worth doing. I like the look of LED in the front too, as they're only orange when they light up. When they're off they're silver.
08-07-2020, 05:14 PM | #32 |
Rep 90
Drop me a link to some good ones or the ones that you used. If they arent too expensive I'll get them as well.
08-07-2020, 05:23 PM | #33 |
Rep 16,054
These are what I have for front and rear turn signals:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 You have to confirm what bulb base yours uses, they're not the same with all chassis. |
08-30-2020, 08:53 PM | #34 | |
Rep 90
08-30-2020, 08:55 PM | #35 |
Rep 90
I decided to purchase the aukees from your recommendation. I bought some h7s in a bundle and they turned out to be defective so I am in the process of returning them and awaiting the arrival of the aukees.
08-31-2020, 09:06 PM | #36 |
Rep 90
I just installed some led turn signal lights. Are they supposed to remain on when the headlights are on? I can't remember if they do or if they only turn on when you use the signal. They do flash when using the signal, but I cannot recall whether they stayed on with the headlights.
08-31-2020, 09:48 PM | #37 | ||
Rep 104
Drives: BMW 328i
sspade2464.50 |
08-31-2020, 10:31 PM | #38 | |
Rep 90
Ah I see. Its not a big deal to me honestly I just wanted to make sure the lights were functioning properly. |
09-07-2020, 12:05 PM | #39 |
Rep 15
Hi Guys,
I am about to ship my F33 to Europe where I will need Orange/Amber indicators. I read that people changed their rear indicator bulbs for Amber LED's and the result was amber signal lights with the red rear lights. Can anyone who has done this confirm that this works? Did you use a very high lumen rated version? Last edited by Wired435; 09-07-2020 at 01:41 PM.. |
09-07-2020, 01:33 PM | #40 |
Rep 16,054
Open a new thread. Your question has nothing to do with the thread title, and for that reason many who might be able to help will never see your question.
09-07-2020, 04:02 PM | #41 |
Rep 15
09-09-2020, 06:55 PM | #42 | ||
Rep 5
09-09-2020, 08:34 PM | #43 | |
Rep 104
Drives: BMW 328i
High/ low (H7): https://amzn.to/33d7g2i Fog (H11): https://amzn.to/33d7g2i Last edited by idopullups; 09-09-2020 at 08:46 PM.. |
09-09-2020, 09:33 PM | #44 | |
Rep 16,054
I have no glare problems with LED in any of my lamps. If anything I have less glare, as with the brighter LEDs I was able to lower the aim of the lights and still have better visibility over longer distance.
V_ARZADON0.00 |
