09-14-2020, 09:26 AM | #1 |
Rep 19
Cold Start Misfire?
this is my 2014 335xi 23k miles bm3 stage 2 vrsf bolt ons the car has started sounding like this on cold starts, no cel. ngk spark plugs gapped to .22 installed around a month ago.
09-14-2020, 02:09 PM | #3 |
Rep 2,653
I swapped plugs to NGK's at .22 not too long ago. I was racing an S4 and BAM, misfires like mad and I limped the car off the highway. I was able to get home. I pulled the plugs and two of them were pretty much done. Two packing washers under the central electrodes came loose. I pulled all the plugs and replaced them with OEM plugs gapped to .30 and haven't had any issues since. I was running OEM plugs before the NGK's for at least 30K miles and no issues either.
jv004400.00 |
09-14-2020, 02:23 PM | #4 |
Rep 19
I think it started happening after the spark plug change. I did the tune and bolt ons all at the same time with the spark plugs. I don't know how to check for shadow codes
09-14-2020, 04:09 PM | #5 | |
Rep 7,591
You should be able to scan for both active and shadow codes with BM3 or something like bimmerlink too i believe. Just because you dont have a CEL or drivetrain malfunction popup doesnt mean you have no codes. |
09-17-2020, 12:42 AM | #6 |
Rep 19
I had my buddy at my local independent shop scan the car and there’s no codes. I’m going to tune back in the oem cold start and see if that helps at all. I have no clue what this could be. I can’t really hear it much after driving the car and it drives great no issues at wot
09-17-2020, 01:17 AM | #7 | |
Rep 605
09-17-2020, 11:46 AM | #8 | |
Rep 7,591
09-17-2020, 02:19 PM | #9 |
Rep 19
09-17-2020, 02:55 PM | #10 | ||
Rep 7,591
