09-16-2020, 10:29 PM | #1 |
Rep 154
Car shutting off on WOT 1F053C: Maximum acceleration exceeded
Hi,
Car keeps shutting off on WOT. No gas and only brake when this happens, quite scary actually. Everything works fine after restarting the car. I saw two fault codes First one Oil service wasn't reset when it was changed in the turbo install I guess. Second one Looks like the DME is shutting the car off because too much power? Thought it was the hpfp crashing but I saw it at 2300psi when it happens. Could this be happening because of the oil service code? Here's a log of my second revision https://datazap.me/u/jptsunga/vtt-gc...log=0&data=3-5 |
09-18-2020, 12:37 PM | #3 |
Rep 154
No issues until the overdue engine oil service fault code came up and along with the maximum acceleration exceeded. Resetted the engine oil service and cleared the codes and see if it happens again. Is the DME smart enough to restrict power based on an overdue service?
09-18-2020, 07:02 PM | #4 |
Rep 18
I had this same issue after getting an E50 tune, only happened when it was wet. My understanding is it's traction control related. It is a bit scary when it happens the car effectively shuts down. After restart the car is fine and the codes go away.
My tuner told me I could adjust the boost reduction in BM3 to help. Really it's solved by turning TC completely off when ripping on it and throttle control in comfort mode when it's wet. |
Jay5k87.50 |
09-19-2020, 06:00 PM | #5 | |
Rep 154
09-19-2020, 07:29 PM | #6 | ||
Rep 18
Jay5k87.50 |
09-20-2020, 01:12 PM | #8 |
Rep 154
Let me try that because ever since I started the E40 tune. I log with traction control off once per day and go home right after and don't drive the car hard. Also now that I think about it, it hasn't happened with sport +, only in sport.
09-20-2020, 01:14 PM | #9 |
Rep 154
Thanks for this info. I notified my tuner about this. Before we thought it was the hpfp crashing, but after monitoring the rail pressure when it happens and looking up the code description, I figured it wasn't the hpfp and notified him this weekend.
10-05-2020, 10:47 PM | #10 |
Rep 95
FYI I just had a dirty rear wheel speed sensor issue, that also caused this code to pop up along with wheel speed plausibility code, so if your still getting this I would also remove the rear wheel speed sensors clean them, and blow some air down the hole at the reluctor ring for good measure, also note I do have the max acc coded to the maximum value so it looks like you can still get this error that that setting if you have a bad speed sensor
Jay5k87.50 |
10-06-2020, 03:31 PM | #11 | |
Rep 154
