11-04-2017, 07:44 AM | #1 |
Rep 4
F31 Touring Tailgate Problem 62 plate
Hi, My first post on this forum. I have got a tailgate problem. It suddenly stopped working the other day. The main tail gate would not lift from key fob/hand sensor on the lid. It judders like it want to move and doesn't. At the time the glass lid was working and still locked. I took it into my local BMW garage and they told me it needs a new locking mechanism. They said it was dirty and contaminated. I live near the beach so can I accept that. They cleaned it and got it functioning again, but only lasted for 2 days after paying out over £130.00. Current status is the tailgate is now doing the same but the glass lid is also not opening. Complete lock down.
I am concerned they have not diagnosed the fault fully and I am expected to pay more hundreds of pounds. I believe it may be more electrical than mechanical. What's your thoughts on the above? Does any one have details on the fuse box layout and which fuse number does what? The interior lights are now behaving weirdly. When driving at the night, the convenience lightning when entering the vehicle stays on. Thanks in advance. Mr J.N. |
11-04-2017, 09:18 AM | #2 |
Rep 332
My previous car, not a bmw, was legendary for throwing weird and random electrical gremlins as the battery began to give up even though it would turn the starter motor without issue and still hold charge
Good luck |
11-04-2017, 11:58 AM | #3 |
Rep 565
I had a E61 series touring til last month. They had a notorious fault with the wiring loom to the rear tailgate.
The 2 cable bundles through the hinges to the tailgate were far too tight and not of a high flex type cable.Over time the cables become brittle and go open circuit or worse the insulation fails and they start shorting across each other giving all sorts of weird faults. The fix is fit new loom from within the roof mounted speakers. Not a straight forward job but Quarry motors did it for me for a good price. Dealer was after about £700 per side I think. Now I'm in the F31 club I don't know if this is a common problem on this model or not but some of your symptoms are similar to what I had on the E61. Last edited by flashollie; 11-06-2017 at 03:25 AM.. |
12-02-2017, 03:24 PM | #4 |
Rep 3
Did you solve it icejim?
Sounds like we have similar a similar problem, did you get to the bottom of it? We have had a new FEM module, whatever that is! and a new catch, but none of these worked. Ours started with the tailgate wanting to open and making the noises, but failing, then within hours, the doors failed to open. Had to use the key in the lock. Our glass opens ok though. We've currently spent £1000 (fem) this was to fix it once and for all (dealers words)! They then fitted the catch without charge. We have lost complete faith in the dealer, they clearly have no idea. Really hoping you can shed some light on it.
It's a 2013 F31 Touring. |
12-03-2017, 09:49 AM | #5 | |
Rep 4
Fault Now Fixed
My problem did get fixed. It was a case of trial & error. Initially they said a new locking mechanism catch in the bottom [v-slot opening]. This was installed and improved it slightly, but was still only an intermittent fix. After every 10-12 open/closes it would not open again. More investigation led to the cable from locking catch leading up to the solenoid motor which has an internal cam mechanism which controls the lockdown of the boot. This is located inside the boot on the left. This was replaced and all is now working as new. The cam mechanism/solenoid motor fault was also the reason to the internal light problems I experienced as it was confused as to when it was open/not open. Total outlet for labour and the two parts was £560.00 [which includes the initial labour cost of £130 on my first visit to the garage] Not sure what an FEM module is. All the issues/fixes above was in the rear of the car. Hope this helps you out. |
12-03-2017, 04:53 PM | #6 | |
Rep 92
12-06-2017, 03:14 AM | #7 |
Rep 3
Thanks for the reply Icejim it may be useful information as it’s going back in on Friday. I’ll keep the thread updated for anyone who needs it
04-03-2021, 08:18 AM | #9 | |
BMW Touring F31
Rep 1
thanks for your post on the tailgate problem. I am experiencing the same now. Was the solenoid the problem or the cable. Which was replaced. The solenoid or the cable. Also. do you know how to manually release the tailgate. Is this an easy job if I want to do this myself please |
f31, fuse, locked, tailgate, touring |
