10-26-2021, 04:05 AM | #1 |
Rep 16
what is the ID of bilstein pss14 front springs?
I'm trying to order GC Camber plates to pair with my bilstein pss14 but can't find the ID of the front springs anywhere. Does anyone by chance know?
10-26-2021, 10:14 PM | #2 |
Rep 3,539
You need the OE spring perch. Bilstein B14/16 coilovers have a 60mm ID bottom and stock spring (~96mm IIRC) ID top.
johnung4528.00 |
10-29-2021, 03:27 PM | #3 |
Rep 75
If you are ordering the camber plates anyway, you could get the 2.5" spring perch, 2.5" Hyperco or Swift Springs (in a 250-275# range) and get 60mm to 2.5" adaptor plates for the bottom. 2.5" springs fit over the Bilstein dust boots better than 60mm. This also leaves you room to experiment with different spring rates if you want to work on getting tuned for Flat Ride Suspension. my 0.02
I have the B14 kit and got Vorshlag camber plates and this is what I ended up doing. The B14 kit comes with 400# front spring rate. Too stiff IMHO and according to many who have installed the B14 kit. (I also upped the rear spring to a 750# Hyperco)
2014 335i - BM3 Stage 2+ Race Gas, VRSF Catless DP, Race IC, CP, Muffler Delete, xHP Stage 3, NGK 97506, Eldor Coils, Turner Motorsport intake with BMS filter, BMS Oil Catch Can, Red Line fluids.
07-20-2022, 10:00 AM | #4 | |
Rep 39
07-20-2022, 11:17 AM | #5 | |
Rep 75
The Verdict - Flat Ride is where its at. Do some research. Farkle on this board and Fat Cat Motorsports on YouTube. They explain it all in intricate detail.
FaRKle!4016.00 |
