10-26-2021, 06:41 PM | #1 |
Rep 11
F30 Xdrive lowering
Does anyone know what's the safest and lowest ride height that an xdrive car can be at to not worry about popping/snapping the front axles?
10-26-2021, 08:02 PM | #2 |
Rep 5,392
cfm56d7b5886.00 alohasurftoad3078.00 |
10-26-2021, 09:05 PM | #3 | ||
Rep 11
10-26-2021, 09:11 PM | #4 | |||
Rep 5,392
10-26-2021, 10:16 PM | #5 | ||||||||
Rep 11
10-26-2021, 11:20 PM | #6 |
Rep 1,369
Each axle is about $1400, each so don't go crazy with lowering. I've got ACS springs and you'd think the ride height is factory. I believe Eibach also makes a reasonable set as well that makes the car look more factory than the slammed look. Dinan and H&R offer something a little lower and I haven't seen any complaints from xDrivers for F3x chassis so that might be something to look at. Keep in mind some springs are OE damper friendly and some are not. Choose carefully.
10-27-2021, 12:11 AM | #7 | |
Rep 11
10-27-2021, 09:47 AM | #8 |
Rep 1,369
I've heard H&R is lower than Eibach or ACS but there might be more than one model of H&R. I'd double-check that. I checked my car right now and the ACS springs have a 2~2.5 finger gap.
10-27-2021, 10:14 AM | #9 |
Rep 472
I have a 2015 328i xdrive and have this exact setup which in my opinion is the best lowering option for this car without crashing over bumps or a super harsh ride. Also, big thanks to johnung who helped answer tons of suspension questions for me!
- Eibach Pro Kit Spring - part no. E10-20-031-04-22 - Koni Special Active struts - part no. 87451378KT - shortened front bump stops from BMW E39 - part no. 31331138814 - shortened rear bump stops (I didn't end up installing as it wasnt necessary) - part no. 33536762722 |
10-27-2021, 10:44 AM | #10 |
Rep 10,256
10-27-2021, 12:18 PM | #11 | |
Rep 5,392
That's just eyeballing it though. Would have to actually take measurements to make sure that it isn't an optical illusion. I typically recommend to take before/after measurements from the center of the BMW logo on each wheel to the lower edge of the fender lip. That provides a true axle center measurement that shouldn't change if wheels/tires are swapped. Problem is everyone does what I did three years ago. Throw those new lowering springs on without doing a "before" measurement! 😀 |
10-27-2021, 06:15 PM | #12 | |
Rep 11
