10-26-2021, 12:22 AM | #1761 |
Rep 40,752
PM sent.
10-29-2021, 06:50 AM | #1762 |
Rep 9
Question coding a BMW bike. But this could be same for a CAR.
I want to change the look and feel of the dashboard TFT, how it shows the speed etc. Seems that I need to have a CAFD (KOMBI) for a bike model A (which I dont have) and use it into bike B that I have. Does this mean I need to find out which CAFD is for the bike A, from the PSDZDATA full, and rename to the CAFD of my bike B, and code it? |
10-29-2021, 09:32 AM | #1763 | |
Rep 40,752
10-29-2021, 06:29 PM | #1764 | |
Rep 9
A hint I got is as below but then what does this mean? "You need a launcher that has mapped cafd files to enable this option, standard esys cant do it" |
10-29-2021, 07:07 PM | #1765 |
Rep 40,752
PM sent.
10-31-2021, 04:15 AM | #1766 |
Rep 7
fault esys
Hi shawn hope you're doing well
if i like to read out kombi thats work. but i only see . i like to code out sos error.. View post on imgur.com It's an f12 M6 2013. Do you think that i need de update my psdzdata? |
10-31-2021, 10:00 AM | #1767 |
Rep 40,752
No, but you need to update your E-Sys to 3.27.1 and use Launcher PRO 2.8.2 to fix missing CAFD Data.
10-31-2021, 12:29 PM | #1768 |
Rep 20
Hi shawn, are you ok?
I need some help, I re-installed e-sys on my notebook after formatting it, and now when I try to fdl code, some moduls only appear dots. I've noticed that if I change the Memory Settings on Launcher Pro, sometimes de dots are gone in one modul but happens on another one that before is working, now it's only dots... How can I solve this? |
10-31-2021, 01:04 PM | #1769 | |
Rep 40,752
From TokenMaster's Blog: UPDATE: 06/20/2020 - Uninstall the old version, download and reinstall the new, repackaged version and the updated BFU_XODE.EST Links are there: http://tokenmaster.blogspot.com/2019...r-pro-282.html
10-31-2021, 01:47 PM | #1770 | |
Rep 20
I'm using Launcher Pro 3.7.0.315, 2 years ago i've done a donation to Eli and got it. Anyway, i have downloaded Launcher Pro 2.8.2 to try to use the free version, but now the error is that it doesn`t work with e-sys 3.33.4... Should I downgrade? I'm asking because a week ago nothing that happens, was using the same versions of e-sys and Launcher Pro and everything works perfectly! But now, seems like need some adjustments...
10-31-2021, 03:11 PM | #1771 | |
Rep 40,752
Are you sure you were using Launcher PRO 3.7.0 and not E-Sys direct when you had trimmed CAFD (dots)?
10-31-2021, 03:54 PM | #1772 |
Rep 7
10-31-2021, 04:02 PM | #1773 |
Rep 40,752
I don't understand what you ask. Install E-Sys 3.27.1 and Launcher PRO 2.8.2. That's it.
11-01-2021, 12:37 AM | #1775 |
Rep 20
I'm using Dynamic Activation on Launcher Pro (my activaction code was used on my last computer, and I don't know how to cancel them and request new ones), maybe that's the problem?
11-01-2021, 01:22 AM | #1776 | |
Rep 40,752
Try using Launcher PRO 2.8.2 if you can't get get your version activated: From TokenMaster's Blog: UPDATE: 06/20/2020 - Uninstall the old version, download and reinstall the new, repackaged version and the updated BFU_XODE.EST Links are there: http://tokenmaster.blogspot.com/2019...r-pro-282.html
11-02-2021, 10:16 AM | #1777 | |
Rep 20
I've installed e-sys 3.27.1 and using Launcher Pro 2.8.2 and the dots are gone... Ok, but now on the KIS/SVT sector, the I-Step are "not available", even when I open e-sys direct with no Launcher. Can I flash iDrive
(iStep update) using this version? How should I proceed, since I can't perform KIS/SVT Calculation? Sorry about so many questions, that's because a week ago I was using Launcher Pro 3.7 and e-sys 3.33 and was everything perfect, the problem was only to get new activation codes Quote:
11-02-2021, 10:19 AM | #1778 |
Rep 7
11-02-2021, 10:27 AM | #1779 | |
Rep 40,752
And flashing is done with E-Sys Direct, no Launcher.
11-02-2021, 10:29 AM | #1780 |
Rep 20
11-07-2021, 02:34 AM | #1781 |
Rep 7
Hi!
can someone help me.. replaced bij clockspring, now i have problems with my paddles and many issues fromt steeringwheel. checked ista and dont have current coding for SZl checked esys and dont have CAF data on SZL.. “Detected CaF for SWE” greyed out.. use esys 3.27.1 what to do? thanks!! |
11-07-2021, 10:05 AM | #1782 | |
Rep 40,752
PM sent.
