BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > F30 LCI M Performance (Black Line) Tail Lights
      06-15-2019, 09:53 AM   #441
Eschmacher
Car Hypochondriac
171
2014 BMW 335i  [0.00]
I like the blacklines, but they look best on white cars imo.
I want shadowlines so bad, but I'm not willing to drop over a grand on them.
      06-19-2019, 09:31 AM   #442
yoandry
yoandry's Avatar
Drives: 13 F30 335i & JGC
Send a message via AIM to yoandry Send a message via MSN to yoandry
PS2+ WMI + MHD Bef+JB4, VRSF DP, CP, FMIC Race 6, AFE Intake, MP-LSD, MPPK, MPE, MP-Susp, MP-Brakes, 437M, MP-interior trim, MP-Alcantara Steering Wheels W/race display, MP-Lip, MP-Diffuser, MP-Spoiler, MP-Rocker Panel, MP-Sills, MP-Pedals, MP-Grille, MP-Mats. XDI-35 HPFP installation pending....
      06-20-2019, 04:50 PM   #443
gt-[r]
Drives: 2013 E82
Originally Posted by DaGreat81 View Post
I'm gonna try butyl rubber from amazon, the oem lights also have this problem
where are you applying the rubber? I bought some gorilla water proof tape and tried to tape off the tail lights... its better, but i recently washed my car and it actually happened again... there must be an area that is exposed somewhere that is letting water in
      06-20-2019, 10:57 PM   #444
MFNATIK
MFNATIK's Avatar
Drives: 17 F80 ZCP, 05 M3C
Said no one with OEM lights
Just washed my car with the Blacklines and not a hint of condensation.
      06-21-2019, 03:33 PM   #445
DaGreat81
I did too and the condensation went away on its own and never came back for oem, it was only the first 2 weeks I had that issue, both outer lights are fine
regarding the depo lights, I returned mine, I couldn't stand them, the condensation never improved over time, I'm sure there is a leak somewhere near the edge on the pointed corner towards the side of the car, you can see the pinched weld is very narrow
      06-21-2019, 05:54 PM   #446
Kailec
Kailec's Avatar
Drives: 2013 328i xDrive
Yeah I've never heard of any OEM owners having condensation. If there is I'd imagine it's a manufacturing defect and affects a small percentage of owners. Meanwhile it seems like every Depo owner has condensation. I can't imagine any OEM part having condensation. Can you imagine if the car you bought had condensation? You'd complain to the dealer, and rightly so!
      06-22-2019, 12:42 PM   #447
jmciver
jmciver's Avatar
Drives: 2017 M3, 2020 X7 40i
2009 BMW 128i  [0.00]
2013 BMW X3  [0.00]
2020 BMW X7  [0.00]
2017 BMW M3  [0.00]
I have the OEM backlines and had some condensation with them. It showed up after a few months of ownership. The condensation was not bad and I would say it was "within BMW spec" for condensation according to BMW factory maintenance/repair procedures. It lasted for a few days, with the condensation going up a bit and down a bit a few cycles, until it all went away. This was over a year ago and I have not seen any more since (knock on wood). That said, it did piss me off when it happened...
The OEM ones can and do have condensation and the BMW factory maintenance procedures cover it. If the condensation is too bad, they can be replaced under warranty. However, I speculate that the criteria for warranty replacement will vary depending on your location. I also speculate that the cause of the condensation in the OEM ones has to do with where they are stored (at the factory, vendor storage, etc). The more humid/cool the storage environment, the more likely moisture can get trapped inside the light assemblies. The good news is that the light assemblies are designed to take care of condensation (i.e. they are not completely sealed) which is why light to moderate condensation should dissipate over a short period of time - like what happened to my lights.
Now as far as non-OEM lights are concerned, quality control is another factor as typically non-OEM quality control is not always the same as OEM (but it can be YMMV)....
///M3 COMPETITION 6MT - 2017 F80 Smoked Topaz Metallic
MP-HAS / GC Camber Plates / Carbonstructure Interior / Blackline Tail Lights
X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic
X3 - 2013 F25 Titanium Silver Metallic (wife's) / 128i 6MT - 2009 E82 Jet Black (son's)
      06-22-2019, 03:37 PM   #448
IK6SPEED
Drives: BMW M3 / AH3
Obviously getting a BMW Warranty on Blackline Lights will be an issue with BMW NA.
      06-22-2019, 06:32 PM   #449
jmciver
jmciver's Avatar
2013 BMW X3  [0.00]
2020 BMW X7  [0.00]
2017 BMW M3  [0.00]
Good point, considering they are not DOT approved in the US due to the lack of integrated side reflectors. However, you should at least have a chance if they were purchased from a reputable vendor.... YMMV of course...
      06-22-2019, 06:37 PM   #450
IK6SPEED
GL with that.
      07-02-2019, 12:16 AM   #451
mlev
mlev's Avatar
Finally got mine installed last week. Took a bit more coding than just changing everything to LED and disabling the monitoring checks. Needed to make quite a few changes in the advanced section of BimmerCode REM to get the full combined inner+outer amber signals and a few other things to function as intended. Specific coding here: https://f30.bimmerpost.com/forums/sh...2&postcount=47
I was initially on the fence but I'm really happy with how they look in person. Compliments my other black/CF accents. Not a daytime pic but here's a shot.
      07-17-2019, 02:55 AM   #452
tmdals0213
tmdals0213's Avatar
Switzerland
197
Drives: 2016 340i M-Sport
selling mine, locally in los angeles. (that means will not ship)
ceramic coated with opti-coat pro 1 month ago.
DM me IG @340i_bsm_cr
Diligentia Vis Celeritas
      07-31-2019, 11:49 AM   #453
mlev
mlev's Avatar
Can anyone confirm which type of LED bulbs are needed for the OEM blackline reverse lights?
      10-09-2019, 04:49 PM   #454
gt-[r]
Drives: 2013 E82
I have a rear tail turn signal malfunction and noticed that there is condensation in my taillights again anyone have this issue?
Where do I get usr turn signal bulbs from? It's not listed on their site
      10-09-2019, 09:22 PM   #455
sean2648
sean2648's Avatar
Drives: 2015 335i
What is USR turn signal bulbs?
You're just getting a replacement bulb if there is something wrong with one of them, the bulbs aren't manufacturer specific to the company who makes the lights. And if you think you are having a malfunction with the turn signal, check the connections, not the bulb. Or just swap out the bulb from the other side to eliminate 1 possibility.
'15 335 M Sport 6MT /// FBO /// Custom Tune /// Custom Interior
Instagram /// Build Thread
      10-16-2019, 01:38 AM   #456
Cpatel
Drives: N26 328i
My prelci tail lights have LED turn bulbs, LED brake light bulbs, and LED reverse bulbs. Can I swap those out and put them in these / are the bulb sizes the same?
Does the black line depot require only one LED brake light bulb for the inner and outer portions?
      02-01-2020, 12:33 PM   #457
dexterdpc
Drives: '14 328d F30 Luxury Line
Reverse light is the same halogen bulb as the pre-LCI, so yes.
As for the rest of the bulbs in the tail lights, all are built in (on the OEMs and Depos) so you don't need bulbs. Only the reverse are changeable.
      02-01-2020, 12:39 PM   #458
dexterdpc
My Blackline Upgrade: US 2014 F30
OEM's a bit more work in terms of connectors and coding, but so glad I used them. Last pic is mine next to my neighbor's '18. I recommend the OEM Blackline and the OEM harness with Bimmercode coding. No plastic resister boxes!
I added the OEM Harness instructions as it tells you how to wire everything as well.
      03-05-2020, 01:11 AM   #459
the_experiment
Drives: 435i xdrive
Any OEM options for F32? The packages linked here only list F30.
      03-13-2020, 11:16 PM   #460
chhappy7
chhappy7's Avatar
120
Drives: 2015 328i RWD
2015 328i  [0.00]
So for the people who did the retrofit, is this the right lights to retrofit onto my 2015 pre LCI? https://www.schmiedmann.com/en/bmw-f...3212450105BMWT
2015 328i - M3 style front bumper/fender/side skirt, M Sport rear bumper/diffuser, M Performance brakes, BBS SR, ceramic iDrive, LCI radio trim, 6WB, carbon fiber lip, X5M razor key
      08-21-2020, 10:34 AM   #461
RalF-BMW
RalF-BMW's Avatar
Drives: 2015 335i M sport
Anyone knows of any other reputable vendor who sell this tail lights? They're not available anymore at e-acca.com and other sites.
