BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > B58 squeak - faulty tensioner/slipping belt
      09-14-2018, 08:59 AM   #155
BMW in NE
Drives: 2018 BMW 340i xDrive
Back from the dealer: here's the report.
Tech was able to duplicate the squeaking noise. No TSBs at this time, but was able to find in the system where enough people have complained about this that BMW is looking into the issue. I was told to monitor the issue and if it gets worse to let them know. They would be in touch if there is any more info from BMW.
Creaking door seals were fixed using the Teflon tape. The tech did a really nice job applying the tape so you can just barely see the edge when the doors are closed. On my drive to work this morning I didn't notice any creaking so it seems to be fixed.
      09-14-2018, 03:11 PM   #156
dereksM3
dereksM3's Avatar
Drives: 2016 MG 340i M-Sport
Interesting my dealer "applied wax" to fix the seals. Doubt it will lost long, will need to bring in the TSB for them to fix it properly.
My 340i has had the AC belt squeek for almost 2yrs. Hasn't gotten any better or worse, for now I don't really worry about it. Figured the ricers would just think I have an uber cool German BOV.
Beek702.50
      10-31-2018, 03:37 PM   #157
pimp4cheddar
El Capitán
pimp4cheddar's Avatar
Drives: MR F30 340i
Sending this back up.
Just picked up a 340i 8AT - leaving a Bed Bath and Beyond (don't judge me) earlier today and noticed the squeak from 1st to 2nd gear.
Searched and found this endless thread of disgruntled consumers. This fucking sucks - 2 years and no fix? Pretty shitty...
Also - I have heavy squeaks during accelerating and releasing of pedal under low speeds. I'll be purchasing tape off Amazon to fix this on a $55k 3 series
      11-07-2018, 08:40 AM   #158
BMW in NE
Update: Now that it's winter here in New England I'm not running the A/C at all and I have no squeaking.
As far as the door creaking issue.. looks like the tape did the trick. I haven't noticed any creaking at all in the last 1.5 months.
      11-08-2018, 09:34 AM   #159
NormanConquest
That Libertarian Guy
NormanConquest's Avatar
4014
Drives: 340i
I had creaking but it was the seat not the door.
      11-08-2018, 11:01 AM   #160
330indy
CCA member
330indy's Avatar
Drives: e46 + e92
Don't you use the compressor for defrost in winter?
00 Z3 - Conforti, Magnaflow
02 330i ZSP - Dinan Stage3, Corsa
13 M3 ZCP - Corsa
3 pedals all, Redline fluids
      11-09-2018, 08:12 AM   #161
BMW in NE
I haven't had to use defrost yet (hasn't been cold enough). I'll give it a try but I can confirm my car doesn't make the squeaking noise w/ the A/C off.
      12-04-2018, 07:12 AM   #162
VVlasy
Drives: 2016 440i xDrive GC with MPPSK
I probably had the worst case of the squeak. Mine would do it always in warm weather and not only from 1st to 2nd, but 2nd to 3rd and even 3rd to 4th. Sometimes even beyond depending how warm it was. I could also feel the car lose power on upshifts due to the slippage even in cold weather, although it was much worse in the summer.
On monday my tensioner pulley failed, causing a crazy vibration from the engine bay accompanied by an ugly banging sound on “cold start” for about a minute.
Tommorow I am picking it up and will update you if the squeak comes back. Though I highly doubt these two things were unrelated, since the squeaking was getting worse.
      12-09-2018, 10:42 AM   #163
BMW in NE
Yup..squeaks with the defrost on (a/c).
      01-05-2019, 10:41 AM   #164
brakthru
Drives: 2007 BMW 335i
Any update on this? The new pulley fix your problem?
      01-05-2019, 04:24 PM   #165
VVlasy
Right now it is around 0 °C. So I don't want to say it has been fixed, for it to reappear in summer.
I also have some banging coming from the transmission on cold start that I am scheduled to have looked at on 17th....
nickf3063.00
      01-05-2019, 06:12 PM   #166
brakthru
Sorry to hear that.
Keep us posted.
      01-10-2019, 06:09 PM   #167
awilki0101
awilki0101's Avatar
511
Drives: 2016 340i xDrive
Picked mine up today after 3x trying to get this solved. They finally heard it and they determined belt tensioner and belt needed replaced. So far so good, but I will give it a week and see
VVlasy36.00
      01-10-2019, 06:12 PM   #168
bimmer456
Drives: 340i
I had this problem but haven't heard anything recently. Not sure if they replaced it without telling me. Don't recall hearing anything after I got my mppsk.
      04-16-2019, 05:56 AM   #169
VVlasy
As I promised, now that it has warmed up a bit I am posting back about the squeak.
I am happy to say that it is gone. It may be too late for some to get it fixed under warranty, but get your dealer to replace the tensioner. It is not normal and will get progressively worse.
      10-09-2019, 10:22 PM   #170
hbrakes
Drives: 2016 340xi
As someone who referenced this thread and others - I was able to get my tensioner and belt replaced at no expense (dealership backed me up to get it approved).
Unfortunately, it still makes just as much noise in both warm and cold weather, regardless of AC on/off.
Not super pleased.
      10-10-2019, 12:45 PM   #171
gabrmdoom
Drives: BMW 340i
Heading to dealer today
I bought this car like 2 years ago cuz of the supra hype. Someday itll be a 900 awhp beast. Maybe?
      10-18-2019, 07:10 AM   #172
J3Vr6
Drives: 2016 BMW 340i (RWD)
For what its worth, I only hear the squeak between shifts when I have the air conditioning on. When the air is off, there is none.
      07-09-2020, 04:04 PM   #173
Edwardsc1
Edwardsc1's Avatar
Drives: 2016 BMW 340i M Sport
Hey guys, bringing this one back from the dead. Any updates on this issue? I have an appointment with my dealer tomorrow morning for this issue. Didn't know if there was any info I could let them know about that's come up since 2019.
      07-10-2020, 04:30 PM   #174
BMW in NE
Same... i just heard it for the first time this year.
      08-05-2020, 08:11 PM   #175
jax5on
jax5on
Drives: 2016 BMW 340i xDrive
I've got the same issue in my 2016 340i... has a TSB been released yet?
Aldor2757.00
      08-06-2020, 02:08 AM   #176
Mattme90
MattM
Drives: e90 335i pre-lci
Bump
