11-14-2018, 09:23 PM | #1 |
Rep 202
Drives: 2011 M3 6sp
Moved : Screen Help :)
Hey everybody so lm almost done with my NBT retrofit BUT lemme just say before anything else l did use the search options l just couldn't find a definitive answer so...
Wired everything up new cables and everything sound works 100% BUT my display is not working, l was under the impression NBT could work with the smaller screen (L7 ENTRY CID 6.5 ) but the screen just stays black, l was also under the impression that the screen would at least turn on (haven't coded yet but l will/can) :/ Any help is appreciated, Ethan Update : coded and still staying black, I️ saw a video of hu_entrynav working on the small 6.5 screen so am l still missing something? Reason I'm trying to get it to work is I'm waiting for my big screen to get repaired and l just wanna see it work lol Anyway thank to anyone who chimes in, Ethan |
11-14-2018, 11:21 PM | #2 | |
Rep 10,473
What was the part number on the HU? And what is the part number on the CID? |
justanurse54.00 |
11-14-2018, 11:27 PM | #3 | ||
Rep 202
Drives: 2011 M3 6sp
And here is the pic of the display lm trying to use while waiting |
11-14-2018, 11:32 PM | #4 |
Rep 10,473
Part number for HU is on the side label, not that label.
justanurse54.00 |
11-14-2018, 11:48 PM | #5 |
Rep 202
Drives: 2011 M3 6sp
11-14-2018, 11:52 PM | #6 |
Rep 202
Drives: 2011 M3 6sp
This is the only other sticker on there
11-15-2018, 12:02 AM | #7 |
Rep 10,473
And that’s your part number 65129383072
As it’s a 2014-2015 unit, it’s not a NBT EVO or EVO+ unit As the CID has a 2014 date on it, it is also the older video type. My thought was you might be mismatching compatiablity of the two types, but those units should be compatible with each other. Have you confirmed the CID does work in another vehicle? |
justanurse54.00 |
11-15-2018, 12:06 AM | #8 | |
Rep 202
Drives: 2011 M3 6sp
11-16-2018, 12:46 AM | #9 |
Rep 202
Drives: 2011 M3 6sp
l tried to code different options as well as tried using a different cable and just nothing, I'm not sure if it's a voltage issue or a hardware issue because sometimes l get the no signal display and sometimes l do not it just stays black, sound and everything else is working :/
11-16-2018, 08:20 AM | #10 | |
Rep 765
11-16-2018, 08:26 AM | #11 | ||
Rep 202
Drives: 2011 M3 6sp
11-16-2018, 08:27 AM | #12 | |||
Rep 765
justanurse54.00 |
11-16-2018, 08:31 AM | #13 | ||||
Rep 202
Drives: 2011 M3 6sp
11-16-2018, 04:53 PM | #14 | |||||
Rep 765
11-16-2018, 04:54 PM | #15 |
Rep 765
"Entrynav" and "entry" are two different headunits and screens.
justanurse54.00 |
11-16-2018, 04:57 PM | #16 | |
Rep 202
Drives: 2011 M3 6sp
Oh alright l think that's what l was looking for l have hu_entry with a combox because my car has a build date of 04/14, so even though it looks the same there is a different 6.5 display screen for entry and entrynav? |
11-16-2018, 04:59 PM | #17 | ||
Rep 202
Drives: 2011 M3 6sp
11-16-2018, 05:07 PM | #18 | |||
Rep 765
justanurse54.00 |
11-16-2018, 05:09 PM | #19 |
Rep 765
I'm sorry I see u did upgrade to nbt. Ok ur 10" will work fine tho u may need to make some modifications for it to fit correct in the dash.
justanurse54.00 |
11-16-2018, 05:16 PM | #20 | ||||
Rep 202
Drives: 2011 M3 6sp
11-16-2018, 05:21 PM | #21 | |||||
Rep 765
justanurse54.00 |
11-16-2018, 05:40 PM | #22 | ||||||
Rep 202
Drives: 2011 M3 6sp
