02-12-2019, 06:08 PM | #67 |
Rep 190,804
02-13-2019, 08:07 AM | #68 | |
Rep 772
Drives: 2015 435i grand coupe xdrive
Id go with the turner closed one but the filter on it is so damn small. I believe surface area is a key factor in intakes and pipe size. Honestly I'm ready for someone to release a relocation inlet for our car. Where we move the coolant tank over, and have the short rout to the turbo.
2015 435i grand coupe xdrvie (current)
2006 F250 powerstoke CCSB (current) 2014 M235i Black on Red (SOLD) / 08 e90 335i MT Pure Stage 2 High flow (SOLD) 08 128i 6MT (SOLD) / 08 335i 6MT Pure stage 1 (SOLD) |
02-13-2019, 10:35 AM | #69 | |
Rep 439
Drives: 2016 M235i Xdrive 8A
Much like the twin snakes of the RB26 growing up..
SOLD 23K Black 2013 F30 335XI 8A Msport | BMS Intake | BMS Front Mount | VRSF Charge Pipe | BM3 Tune
2016 F22 M235 8A HK NBTevo | CTS HEX Intake | CTS Chargepipe | Gplus Intercooler | VRSF DP | BM3 Stage 2+ | 18" CSL Replicas | XHP X-Delete |
02-13-2019, 10:39 AM | #70 |
Rep 772
When I did them on my N54 it really helped throttle response and top end. But The tubes that came out were extremely small, the n55 doesn't have that bad of a snake around.
03-05-2020, 04:44 PM | #71 |
Rep 7
Hi. I have installed it on my f30, but how have you solved the problem with the high-temperature coming from the cooling hose? The aluminum part almost sits on the cooling hose and the intake pipe takes all the heat from it - the intake air before turbo becomes much hotter (especially in a traffic jam) than with OEM. Contacted CTS Turbo and they said, that the intake temperature before turbo doesn't make an impact on performance... So, it seems like they make it just you to have some great Instagram stories..
05-28-2023, 09:38 PM | #73 | |
Rep 97
05-29-2023, 01:13 AM | #74 |
Rep 7,606
02-05-2024, 07:21 PM | #75 |
Rep 73
jus installed the dinan. throwin codes all over the place , maf, maps,harnesses.voltage codes, etc etc etc. theres def oil on it when i opened it up. so maybe wipe it off if u go dinan. seriously i may jus go back to stock , car ran great w all my upgrades so far, dinan was last thing.now cels everywhere once up to temp in sport mode.
02-05-2024, 10:53 PM | #76 | |
Rep 7,606
https://f30.bimmerpost.com/forums/sh....php?t=1765289 |
02-06-2024, 12:44 AM | #77 | |
Rep 73
did engine reset with protool after everything but this dinan, but is there a specific maf reset? Last edited by jjjccc; 02-06-2024 at 01:27 AM.. |
02-06-2024, 08:19 AM | #78 | |
Rep 4,145
Remove the Dinan and go MPPK with a drop in or CTS (my favorite). I know MHD has a adaptation reset for a few areas, I'd assume BM3 does as well.
Mods: Yes.
02-06-2024, 11:32 AM | #79 | |
Rep 4,920
02-06-2024, 01:38 PM | #80 |
Rep 73
ok yea, i jus dont like anything about this dinan. i surely thought i was doin rt by gettin an enclosed intake.
even tho cts looks great/runs stable, is it really that loud at idle?? i never had any cai that was loud at idle only when punchin it. my vrsf catted down pipe and borla s type is pretty LOUD at cold start, and in sport mode.almost lil too much for my taste. |
02-06-2024, 01:54 PM | #81 | |
Rep 4,145
Mods: Yes.
jjjccc4.50 |
02-06-2024, 02:38 PM | #82 |
Rep 4,145
In terms of intake - basically anything (but Dinan) is better than stock. I've had 5-6 different setups, including stock, Dinan with MPPK and without, MPPK w/AFE, BMS, CTS and now RK Tunes front mount (it's great too)
When I install my intakes, I reset the Intake Mass Airflow, Lambda Sensors, and Idle. I'd recommend you do the same.
Mods: Yes.
02-06-2024, 05:32 PM | #83 | |
Rep 7,606
02-06-2024, 08:17 PM | #86 |
Rep 7,606
03-03-2024, 10:12 PM | #87 |
Rep 73
reset adaptations after m perf lower box and filter. now im gettin codes i never seen, says basically somethins drainin battery while at rest. 30f requested doesnt take place,30b on,relay fault in power window regulator, electronic wastegate re-learning cold start. never had these before on the dinan just all types of other ones. how long does it take adapts to relearn air intake/fuel mix and idle?
so many diff things about 30,30a,b,f, on the net but none of this before mppk intake. my batt is only a year old and tests fine on ohm meter. denso alternator is also basically new. maf and map on chargepipe are new also. batt was like only .2 volts lower than it shud be, cuz i dont drive it often enough, that couldve triggered these per what alternator is doing.i do know our system will thro a code if alternator is over charging battery(in this case batt being low so to system it looks like overcharging), and yes my batt is registered Last edited by jjjccc; 03-04-2024 at 12:39 AM.. |
03-03-2024, 11:34 PM | #88 | |
Rep 4,145
