04-07-2023, 07:32 PM | #1 |
Rep 83
Car not building boost?
Ever since I gotten my car, I have gotten the drive train pop up time to time under full throttle. Sometimes when going up a hill under throttle it’ll pop up. Sometimes when I’m just punch it and it’ll pop up. When in higher gear and you press try to build boost it’ll pop up as well. All these are times I’ve noticed it. When I took it to my local bmw indie shop, he said it might be my boost pressure regulator or turbo. Anyone can confirm this? Recently bought a obd2 plug and saw that my boost was under and sometimes a bit over 1 psi. Anyone can help me with this? I saw it hit 3 psi, car def feels slower than usual but maybe it’s all in my head?
04-08-2023, 01:03 PM | #2 | |
1296
Rep 3,533
04-08-2023, 02:09 PM | #3 |
Rep 190,750
+1
04-10-2023, 11:12 AM | #4 |
Rep 7,602
05-04-2023, 09:07 PM | #5 |
Rep 83
finally made an appointment with one of my good friends shops and went in there today. it had a bunch of codes come up. car is def in limp mode. 1, my water pump went out and 2. car isnt building any boost and feels dead. they did a smoke test on it and it was leaking from the charge pipe near the turbo. hes gonna check the turbo when hes doing a water pump and going to get a new charge pipe seal to see if it builds boost again. if not may have to get a new turbo.
05-04-2023, 09:09 PM | #6 | |
1296
Rep 3,533
05-04-2023, 10:33 PM | #7 |
Rep 83
05-05-2023, 11:55 AM | #8 |
Rep 190,750
let us know if that fixes the issue
05-05-2023, 04:30 PM | #9 | |
Rep 260
If you're replacing the water pump, it's best to do a more thorough job. The parts cost more but if you're paying a shop the labor will be less if they do it all at once. I replaced the water pump, thermostat, something called the "Mickey Mouse Flange," and the coolant expansion tank return hose (a very thing hose which goes across top front of car). I also replaced the entire drive belt -- the drive belt, tensioner, and pulley. Fix it now or fix it on the side of the road. Not saying it's urgent, but sounds like you're close to the age where those items fail, and you should replace them as your budget permits. |
n55demon19.00 |
05-06-2023, 11:41 AM | #11 | |
Rep 83
05-18-2023, 01:18 PM | #12 |
Rep 83
so i got a call from them today. waterpump and thermo changed. the charge pipes were fine no cracks in them and they changed out all the seals so its not leaking anymore. but the car is still throwing a code that boost isnt holding/building. under hard throttle the drive train light still comes on. do you have any guesses? im guessing it may be something from the turbo back?
05-18-2023, 01:20 PM | #13 | |
1296
Rep 3,533
05-18-2023, 01:33 PM | #14 |
Rep 83
should i buy an obd2 reader and get the info this way? im gonna go to the shop in a little and ask if they can give me the code. i had my other mechanic who works on bmws and knows the 335i platform well, he said i might needa new boost pressure solenoid. so im gonna do that first before anything and pray it fixes it.
05-18-2023, 08:59 PM | #15 | |
Rep 7,602
05-19-2023, 12:11 AM | #16 |
Rep 83
We are gonna test the boost pressure regulator next week, the only code the car is throwing is just the one dealing with boost. I don’t know the exact code, forgot to ask them. But to me it seems like it might be the boost pressure solenoid. Charge pipes were fine, and we fixed all the boost leaks. Aside from the solenoid, I think it would either be a bad cat, seiezed turbo, or maybe my engine compression is just down to shit. But car has 80k miles on it. I know the boost solenoid was a common issue with the n54s and seems to be common on 55s also. Considering my waterpump went, I would assume that my boost solenoid also went bad. Just my train of thought and the googling. Also what I’ve talked to with the dude who works on my car. Let me know if it makes sense or I’m missing something. My old mechanic also told me that i should replace the boost pressure solenoid as well.
05-23-2023, 08:40 AM | #18 |
Rep 2,357
I have had no boost pressure solenoid failure on my 2012 but I have had two pcs starting to make a loud humming sound. Just replaced at that point.
(A Dane in China) |
05-27-2023, 02:55 AM | #19 |
Rep 83
06-04-2023, 05:03 PM | #20 |
Rep 83
so i just put in a new boost solenoid and it seems fixed the issue i believe. no more light on full throttle while 2k rpm in 4th as it usually did. also i can hear the despool when i rev it in neutral. car def pull a lot harder, especially in first and second, pull the head back to the seat.
06-04-2023, 05:09 PM | #21 |
Rep 83
thejeremyman94362.00 |
06-05-2023, 08:20 AM | #22 | |
Rep 190,750
