08-16-2018, 10:13 PM | #1 |
Rep 91
Looking for fitment advice - 435iX convertible
Let me preface this by saying that my knowledge of understanding wheel fitment is limited to understanding how to interpret tire sizes. I don't know anything about offsets, spacers, etc. I'm hoping to get some guidance from this forum to help me make a decision about a possible change from a square 18" setup to a staggered 19" setup. My suspension and brakes are stock, and I don't plan to change either of them. I'm not interested in lowering the car, stiffening the suspension, etc. So... here's what I'm considering:
I recently bought a 2015 435i Xdrive convertible (F33). I have the factory square setup with 400m wheels and a new set of 225/45/18 P7 RFs (they were put on by the dealer before I bought the car; this wouldn't necessarily have been my tire choice, but I don't actually mind them). I'm considering buying a set of 19" 366 rims from a member that came off of a 650i. He has indicated that the specs are: Front: 19x8.5 +33 Rear: 19x9 +44 I'm considering Michelin Pilot Sport 4S tires, but I'm wondering: a) Would these wheels fit my car without any modifications/concerns/etc? b) If the answer to a) is yes, what tire sizes would be recommended for this wheel setup? TireRack's site returned: 225/40ZR19 (F) • 255/35ZR19 (R). However, when I put my car into Discount Tire's site, the widest tire size that was returned was 245. I'd love any guidance to help me understand the pros/cons of what I'm considering, and also what I should know about my fitment options. My primary motivation is appearance, but any gains in traction, etc would also be welcomed. Thanks, Jeff Last edited by jeffthx; 08-16-2018 at 10:44 PM.. |
08-16-2018, 10:38 PM | #2 |
Rep 5,140
The wheels will fit fine!
But with xDrive you need to be a bit more careful with tires sizes. I would recommend 275/35-19 for the rear wheels, then you have two options for the fronts. Either 235/40-19 or 245/40-19. 235/40-19, dia. 671mm 245/40-19, dia. 679mm 275/35-19, dia. 675mm The front sizes differs about ±0.5% from the rear, both setups will work with xDrive. |
08-16-2018, 10:39 PM | #3 |
Rep 4,327
oem diameter is 26". for x-drive(transfer case), the max difference between front and rear diameters should not exceed 1.2%, equal front and rear diameters is optimum.
tire size combo i'd suggest on the wheel specs you've given is 235/40/19 front, 265/35/19 rear. 26.4" dia. front, 26.3" dia. rear, difference 0.4%. slightly larger diameter=taller sidewall=reduced fenderwell gap from oem spec. you may also use 225/40/19, 255/35/19 oem specs. 225/40 will be somewhat stretched on 8.5 or 245/35/19, 255/35/19, 25.8"/26", 0.8%, front fenderwell gap will be increased slightly from oem spec due to shorter sidewall |
08-17-2018, 05:19 PM | #4 |
Rep 91
This is all helpful. Thanks.
Just to confirm-- the tire size combos that are being recommended would be able to simply be swapped out with my current wheels without any other spacers or modifications? Thanks, Jeff |
08-17-2018, 09:23 PM | #6 |
Rep 91
alohasurftoad3078.00 |
09-10-2018, 09:44 PM | #7 |
Rep 91
One more question: A different set of wheels I'm looking at has the following specs:
19x8.5 ET 33 19x9.5 ET 39 This is a bit wider in the rear than the first set I posted above. 2 questions (again): --With stock suspension/brakes, are there any concerns with these wheel widths? I have no plans to do anything with suspension/lowering/etc. --What would be a good tire size combo for xDrive with these wheel widths? I want a fairly low-profile look, but don't want the ride to be too harsh (my car currently has 225/45/18 P7 run-flats, and don't want anything that would ride rougher than that). Thanks in advance, Jeff Last edited by jeffthx; 09-10-2018 at 10:19 PM.. |
09-10-2018, 10:26 PM | #8 |
Rep 4,327
same recommendation as previous. 235/40/19, 265/35/19 is the best size for x-drive and the wheels you're considering. what brand/model of tires are you planning? because unfortunately the selection of brand/model is limited with those sizes.
09-10-2018, 10:31 PM | #9 | |
Rep 91
Thanks, Jeff |
09-10-2018, 10:45 PM | #10 |
Rep 4,327
the fitment will look like thx@wdeerfield except your rear wheel/tires will be 6mm further out and the front 2mm further out. if you can afford it, get the mps4s and be done with it.
https://f30.bimmerpost.com/forums/sh...hlight=vmr+803 |
09-10-2018, 11:26 PM | #11 | |
Rep 91
Thanks, Jeff |
