09-15-2020, 07:14 AM | #1 |
Rep 694
Tire pressure coding question
2015-435 convertible....is it possible for our tire monitors to read out the actual pressure?
It drives me nuts wondering if it is actually 1 pound under the threshold or I actually have a low tire. It seems its always my passenger side too, so not like I can stick my head out at a light and check.....and god forbid my wife would know if a low profile tire is low or normal |
09-15-2020, 10:20 AM | #3 | |
Rep 694
If I reset the TPMS and then drive above the 19mph limit then it will go green or stay illuminated as before. It is an 8/14 production date, maybe it is a later production? |
09-15-2020, 10:59 AM | #4 |
Rep 524
https://f30.bimmerpost.com/forums/sh....php?t=1104376
Read here i think you will need just coding and new sensore |
09-15-2020, 12:21 PM | #5 | |
Rep 694
09-15-2020, 03:17 PM | #6 |
Rep 16,063
You should have it, unless your car was originally sold in Canada or Mexico. Do a VIN search, if you have tire pressure display it will say so, option S2VB.
09-15-2020, 03:36 PM | #7 | |
Rep 694
Wheels And Drive S258 Tyres With Runflat Properties S2TB Sport Automatic Gearbox S2PE BMW LA Wheel, M Star Spoke 400 S2VB Tyre Pressure Display Sure as shit...Ill have to mess with it more. I tried after lunch but still couldnt get a numeric readout. Thanks for the guidance though. I hope they didnt sell me the wrong year monitors for my A/M wheels |
09-15-2020, 04:03 PM | #8 |
Rep 2,302
Maybe the previous owner or someone decoded the 2VB because he didn't want to buy new sensors or so.
09-15-2020, 04:31 PM | #9 |
Rep 16,063
It takes all of maybe ten seconds to get the pressure read out. Go to vehicle information> vehicle status> tire pressure monitor. You have to do it while the car is moving.
09-16-2020, 06:47 AM | #10 | |
Rep 694
Yeah, I think I have an issue b/c as you mention its pretty darn straight forward |
09-16-2020, 07:23 AM | #11 |
Rep 16,063
I doubt it's the sensors. The two TPM options use different sensors in the wheels and different receivers as well, so if you had the wrong sensors the system shouldn't work at all. If you have Bimmercode connect to the car and open the head unit menu. There's a section for tire pressure/temperature display. The choices are pressure and temperature, pressure only and none. If it shows none as the current checked option that's the problem.
09-16-2020, 09:49 AM | #12 | |
Rep 694
Thanks |
11-18-2021, 08:24 AM | #13 |
Rep 694
So, only took a little over a year for me to go in and mess with this. You guys were correct, the feature was inactive and I can't believe I didn't do this sooner.
Thanks for the info guys |
