BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > DIY - F30 OEM Backup / reversing camera retrofit installed!
Studio RSR
      04-14-2017, 08:18 AM   #309
etinifni
etinifni's Avatar
Drives: 2012 328i Modern Line
Originally Posted by atzebmw View Post
Yes, this is because I have sorted out the part numbers from the complete retrofit set.
To the complete retrofit kit belongs still the camera, the button and so on.
But if you already have all parts except the cable set, you can order this at your BMW-dealer by this part number.
Nice. Have you already ordered and used this cable so you can verify it is the correct length?
:wave:
      04-14-2017, 09:06 AM   #310
atzebmw
Drives: Tesla Model 3
I did this retrofit in 2015 at my old F30.
I just checked my old bills from 2015 and found exactly this number.
So i can tell that this cable set has the correct length.
      04-14-2017, 10:46 AM   #311
etinifni
etinifni's Avatar
The whole kit is actually really inexpensive. The only issue I see is that when running the part # with my vin it doesn't say it's compatible. I have factory PDC f/r and CIC pro nav.
:wave:
      04-14-2017, 03:55 PM   #312
KingpinRCR
Belgium
61
Drives: F30 320d ed
Just to make sure:
-Retrofit kit: 66212361833 (containing: hsd-cable [long enough for dashboard install according to AtzeBMW], wiring harness, camera, trunkhandle, screw, tap, fuse and cableties)
-Control unit: 66539393952 (yes, I know, this unit also has the connections for top and side view. I probably won't ever use these connections, but the cost is the same as rear view only and if i ever change my mind i won't need another control unit. I'm guessing it won't cause errors when they are unused)
-control unit bracket: 66539232797
If I order these i'm good to go or do I need anything else? (Apart from coding)
      04-14-2017, 04:40 PM   #313
atzebmw
Yes perfect.
With these parts it should work.
      04-14-2017, 04:56 PM   #314
KingpinRCR
Belgium
61
Drives: F30 320d ed
Thanks AtzeBMW, looks like I have a new little project.
      04-15-2017, 04:26 PM   #315
magic77
magic77's Avatar
Drives: ex- 335i
For those looking for mounting points in the boot area. Found on mine just above the battery two lugs spaces exactly to take the camera module. Just needed to order 2 nylon nuts same as the ones holding the boot floor fuse box in place.
This puts the system away from any risk of damage and looks very stock
F30 335i M Sport - now departed
      04-19-2017, 10:33 AM   #316
Abi
Drives: BMW 430d M-Sport
2015 BMW 318d  [0.00]
Did anyone try with this harness set ?
Part number is : 61 12 2 183 660
This harness is very cheap(~ 40€).
I made the order and will try install soon.
EDIT: It's also a short HSD cable, but at least it's cheaper than the original harness cable for f30
      04-19-2017, 11:48 AM   #317
etinifni
etinifni's Avatar
I wish the longer HSD cable was available by itself.
:wave:
      04-19-2017, 01:34 PM   #318
atzebmw
Yes, this cable can also be taken.
But the TRSVC then must be placed in the trunk.
      04-19-2017, 01:55 PM   #319
Abi
Is there part number from longer hsd cable only?
Edit: which pins do I connect on HU_ENTRYNAV ?
      04-19-2017, 02:24 PM   #320
atzebmw
The longer hsd cable set (Complete wiring harness) has the part number 66122360176 like already written one page before.
I'm not sure if the rear view camera can be installed with HU_ENTRYNAV.
      04-19-2017, 02:34 PM   #321
Abi
Yes I know but I'm wondering if I can buy just hsd cable, not whole set.
I think it is possible like it is said before on previous pages.
      04-19-2017, 02:54 PM   #322
etinifni
etinifni's Avatar
From all of my research it doesn't appear to be available a la cart.
:wave:
      04-19-2017, 03:08 PM   #323
atzebmw
I have not read correctly.
On the previous page we were talking about the cable set (HSD + connection wires).
Only the HSD cable is also possible but i don't know the part number.
I know some people bought a HSD cable from the 5 Series F10.
There is one with a length of 4020mm which maybe could work.
But then there will be missing the other connection wires.
      04-22-2017, 04:20 PM   #324
RIKO_440i
Drives: F36 440i MPPSK
Hi guys is there a cable extencion for the hsd cable
Got the camera fitted to my car but the cable is only long enough to sit on top of the battery but I want it to be fitted to the front were it should be
Any help would be appreciated as Bmw parts department are useless to help .....
      04-22-2017, 04:55 PM   #325
atzebmw
You can now install the TRSVC above the battery.
Or is the cable also too short for this?
      04-22-2017, 05:09 PM   #326
RIKO_440i
It's literally sitting on top of the battery
I know there is a extension hsd for the 5 series but BMW won't tell me the part number
      04-24-2017, 02:19 AM   #327
magic77
magic77's Avatar
Drives: ex- 335i
Woudlnt worry about it there is perfect fitment place above the battery near the top of the boot. Unit sits there perfectly just go with that and save the money.
      04-24-2017, 03:54 AM   #328
Abi
This might be a problem later if you want to install top/side view because the hsd cable wouldn't be long enough to reach boot.
      04-24-2017, 04:06 AM   #329
magic77
magic77's Avatar
Drives: ex- 335i
Valid forgot about that option , though that is one mod that would be bottom of the pile IMO. Rear lights, digital dash , F15 screen , Idrive 5 far better spend
      04-25-2017, 01:37 PM   #330
jkwhar
Drives: F30 328i Xdrive | F15 x35i
Anyone needs the HSD cable from the camera to the TRSVC?
Did my post help? Click "Appreciate!"
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD)
