09-05-2018, 11:21 AM | #23 |
Rep 21
I took mine in to the dealer for this a few weeks ago. They replaced a tension spring on the valve itself, lubed up the whole assembly and tightened everything down. Hasn't done it since. The tech seemed pretty familiar with the problem, so that was great
09-10-2018, 03:59 AM | #24 |
Rep 703
340i w/ MPPSK installed since day one and my car is in to the dealer now being fixed for exhaust valve rattle for the second time. Hopefully this time it doesnt come back but I'm not to optimistic at this point.
2018 M3 ZCP "Edition Velocity"
2018 X3 30i (wife’s) 2017 340i w/ MPPSK & Many M Performance Parts (sold) 2016 328i (sold) |
11-25-2018, 09:56 AM | #25 |
Rep 3,965
Apologies for resurrecting thread.... my MPPSK exhaust has just developed a rattle on the passenger side exit. Only does it on cold startup and it disappears once the engine is warm (so doesn't do it on warm start)
Can't be arsed to take it in, tbh.
Owned: 440i GC LCI with MPPSK, F31 330D M Sport with MPPK, F11 530D SE, F11 520D SE, E61 530D M Sport, E36 325i plus many MB's, Audi's & Volvo's
11-28-2018, 04:43 AM | #27 | |
Rep 2,495
So Ive booked my car into Nottingham Sytner on the 18th December for a fix (earliest date!!!). It's obvious under the car that you can move the exhaust it and it rattles against a metal mount in the centre. My car only rattles on startup and goes after 30 seconds or so.
Arrived! 2022 X4M Competition, SPY + Black Merino
Gone: 2019 X3M Competition, Toronto Red, Adelaide Grey. |
11-28-2018, 07:38 PM | #28 | |
Rep 1,454
2022 CT4-V Blackwing 6-speed
11-28-2018, 11:13 PM | #29 |
Rep 703
Issue Solved!!!
Ok, so after multiple trips to the dealer for this exhaust rattle issue and bmw even authorized a complete replacement of my MPPSK exhaust and there was still a rattle in sport/sport+ mode we finally figured it out. The cause is the $10 clip in the truck that is rattling (see photos) . After removing this the rattle is gone in all modes and rpms. I suggest you all try that out and see if it helps. Sorry it took me awhile to report back.
12-08-2018, 02:59 PM | #30 |
Rep 103
I had this on mine, was fine for the first few weeks, then after a long run. Stopped for fuel and when I started, it came up with a loud metallic rattle, enough for people to look around.
It wasn't consistant after that, but it did come back. I took it into BMW under warranty, they initially denied it, then found it, tried a few software updates, but then essentially said it was a quirk or the car and cars rattle. Because I am about to get the MPPSK I didn't really argue to much. Quite a few things rattle on my 340i! |
12-08-2018, 05:00 PM | #31 | |
Rep 1,454
And yes, everything rattles. I've put 2" foam through the holes in the shelf behind the rear seats. I've put velcro/felt where the rear view mirror meets the windshield. And now I have the infamous door pin rattle that I'll be rectifying soon. Oh, my driver side sun visor rattles too. Really disappointed with the fit and finish for a $55k+ vehicle.
12-10-2018, 05:10 AM | #33 |
Rep 703
Did you guys try to remove the part in the trunk that I suggested?
04-23-2019, 04:22 PM | #35 | |
Bmw340i Mppsk, bm3 tune,vrsf downpipe dinan intake
96
Rep 176
04-23-2019, 04:32 PM | #36 |
Rep 1,457
My windows creak and rattle at times. There is a BMW lube you apply on the seals, but it only helps for 1-2 weeks and i notice with the weather getting warmer it started again, but during winter not so much.
2024 X3 M40i
2014 BMW M5 |
