01-21-2015, 02:24 PM | #1 |
Rep 79
How do you warm up your engine?
Some people say 30 sec of idle is necessary, others say more than a minute, and some say to just drive off immediately.
I usually just drive off immediately and keep the revs below 2,000 rpm. What do you guys think is best? |
01-22-2015, 08:11 PM | #6 |
10816
Rep 27,599
I have always started the car and drove off immediately keeping RPMs below 3k till the car is warm. Done this with all my BMWs and have had no issues. Like others have said this is what is recommend in the man as well
BEFORE YOU BUY YOUR NEXT BMW, EMAIL OUR GUY KOTE FIRST! Kote M Sales:Kotem@bmwofcamarillo.com Cell:805-368-9101 vipfinance@bmwofcamarillo.com for warranties! |
01-22-2015, 09:20 PM | #7 |
Rep 1,490
I don't know - I let it idle for at least 2-3 minutes on all occasions. I do not like driving the car (especially on cold temps) stressing out a cold block and trans. The seals, gaskets, valves and oils need some time to flow.
This is a practice I've done since driving some old cars or cars with lots of miles because they always felt rough to drive when cold. Also, I need time for the seat to heat up and the steering wheel to get warm. Takes at least 2 minutes.
Current: 17 Mustang GT no bmw
Gone but not forgotten: 07 E90 335I, 04 UA6, 95 E36, 04 EP3, 16 S550 EB, 14 F30 328I Stg 1, 08 E90 328I |
01-22-2015, 10:12 PM | #8 |
e92 - 335i
179
Rep 743
01-23-2015, 10:03 AM | #9 | |
Rep 4,981
<b>2023 M5C SRG|Aragon || 2018 Macan GTS</b>
2019 F90 Comp MBB|Black (sold) 2018 F80 ZCP TB|SS (sold) 2015 F30 335 AW|CR (sold) 2015 F31 MG|CR (sold) 2011 E90 JB|Oyster (sold) |
01-23-2015, 10:05 AM | #10 | |
Rep 4,981
01-23-2015, 12:31 PM | #12 |
Rep 5,316
Drives: G80 M3 6MT
Eco Pro, then I pull away after however long it takes for me to pick a radio station and look at traffic info to see which highway I should take. Unfortunately my car doesn't have much time to warm up before having to enter the highway as I live right by the entrance.
Scott, Partner
Insight Automotive Consulting Click HERE for all discounted BMW New Car Pricing Click HERE for all BMW In Stock Inventory Specials Call/Text: 516-416-5481 Email: scott@insightautoconsulting.com |
K737.50 |
01-24-2015, 04:09 AM | #13 |
Rep 418
Neither old nor modern cars are supposed to idle at start up. The increased revs followed by the drop is the automatic choke (increased fuel to air ratio). The quicker you put the car under load, ie driving, the quicker it warms ups up and the quicker the auto choke disengages. Also, the exhaust emissions are at their dirtiest at cold start up so another reason to drive off immediately. This applies for petrol or diesel. Proof of this is if you let the car idle for 10 minutes from stone cold, it'll achieve only a very low engine temp. But using the method I have described, the car will take a fraction of the time to hit the same operating temperature and quickly go on to achieving normal operating temp.
In terms of driving hard, best practise is to let the oil/ water (subject to your model depends on what gauge you get) temperature hit normal, and by then the gearbox and diff oil will be up to working temp too. This will keep the innards safest. If you have an auto, avoid kick down and the 'box and ECU will prevent overrevving anyway, so just drive as normal. For manual 'boxes, I don't think there is any intervention, so refer to the manufacturers guidance for Rev limits. At the other end of the drive, especially an enthusiastic one, idling the engine is actually good practice (this rule only applies only really applies for turbo/ supercharged engines). So my rule is, that for every mile driven, I let the car idle before I switch it off (ie, 100 miles driven, 100 seconds cool down) This protects the turbos from overheating ("heat soak"). Both methods will help ensure excellent longevity from mechanical components and help prevent expensive trips to the stealers later in the car's life. |
01-26-2015, 09:19 AM | #15 | |
Rep 764
I just start my car and wait for the revs to drop under 1k. Once it's been at under 1k for about 30 seconds, I just drive off but take it easy (under 2.5k) until the temp needle starts moving. |
01-27-2015, 11:03 AM | #16 | |
Curmudgeon and Pedant
690
Rep 3,489
01-27-2015, 12:37 PM | #17 |
Rep 10,509
I drive off and keep the revs low before the oil gauge moves off 160F, and I shut off the car after driving without an extended idle (It takes me some time to park anyway since my garage is narrow, and the water pump stays on after the car is shut off)
01-27-2015, 04:23 PM | #18 |
Rep 418
Turbos are oil cooled, not water cooled. If the oil pump stays on, then fine and understood, but I'd like firm confirmation of that. Common practice for turbo'd cars to idle on cool down when driven hard - this is why Turbo Timers were invented, so you could leave the car to switch itself off. these tend to be seen on hot Japanese drift cars, as an example
01-27-2015, 06:45 PM | #19 |
690
Rep 3,489
You're wrong: http://www.realoem.com/bmw/showparts...69&hg=11&fg=35
clearly shows the coolant lines attached to the (N55) turbo. Now, you're right about the M57 turbo, but wrong for the vast majority of folks reading this thread. |
01-27-2015, 11:14 PM | #20 |
Rep 79
You know, I was thinking about that today. I hate hearing the turbo whise when I'm driving with a cold engine because I feel like I'm overworking the turbos with very little oil to lubricate it. How should I prevent that? Is it bad for the turbos? It happens with average throttle input
01-28-2015, 02:33 AM | #21 | |
Rep 418
01-28-2015, 09:51 AM | #22 | |
690
Rep 3,489
In any case synthetic oil is one of the reasons BMWs have few turbo bearing failures. |
