10-21-2018, 09:37 PM | #23 | |
Rep 387
11-13-2018, 05:46 PM | #24 |
Rep 2,044
11-14-2018, 09:12 AM | #26 |
Rep 2,044
I use Molygen for the summer, but want a 0w20 for the winter, which Molygen don't do...
Murf Last edited by Littlebear; 10-30-2021 at 06:03 AM.. |
11-14-2018, 09:40 AM | #27 |
Rep 16,079
I've never had a problem with 5w-30, and it gets a tad colder in New Hampshire than Brooklyn. Liqui Moly does make 0w-20 oils, just not in Molygen
11-14-2018, 10:29 AM | #28 |
Rep 2,044
Hi Bill,
I thought you lived in that mild coastal region, since you use 5w30. But I go to the Adirondack Mountains often, which are as cold as anywhere in the NE. Last year the week between xmas & newyear was nights -20 to -30, days below -10, similar to your place? Not too bad. I remember skiing Stowe with a wind chill of ~ -100.... SN or A3 doesn't excite you? Murf Last edited by Littlebear; 10-30-2021 at 06:03 AM.. |
11-14-2018, 11:26 AM | #29 |
Rep 16,079
I'm on Lake Winnipesaukee. I worked in the ski industry for 25 years, driving to and staying at ski areas across New England every week. I've always used 5w-30. The last time I had a cold start problem was in January 1973, in Minnesota, where it was -20F for a daytime high. That was before synthetic oil. Since using synthetic exclusively, first with Mobil 1 in 1974, I've never had a cold start problem so long as the battery was OK.
11-14-2018, 12:16 PM | #30 |
Rep 2,044
Thanks Bill,
During a stay at Stowe in the last century, my 2002 wouldn't crank even when I brought the battery in at night. We tried to push it down the hill for a jump, but the wheel bearing grease was too thick & the car wouldn't roll. We skied ever day, though! I was probably running 20w50 Castrol. The place we go to now is in a wilderness area, no phone, no cell. I want no problems.... Murf Last edited by Littlebear; 10-30-2021 at 06:03 AM.. |
11-15-2018, 05:17 AM | #31 |
Rep 2,044
Hello BMW Experts!
Seems BMW is making the choice easier now. The say use LL-01 or LL-14FE. But the two categories call for different things, especially for 'shear', which is what I thought LL-01 was good for. My conundrum is as this guy stated on BITOG: "...The problem with the lower weight oil is that it rarely satisfies A3/B4 (>3.5). Oddly enough, the 340's manual calls for 0W-20 or, alternatively, 0W-40 or 5W-30 as long as it has A3/B4. Yet the prescribed oil (OW-20 LL14FE) is A1/B1. I don't know... I guess I could start drinking the BITOG Kool Aid (PP). " My manual (2017 330i) says nothing about ACEA specs. Murf Last edited by Littlebear; 11-15-2018 at 08:50 AM.. |
11-15-2018, 08:11 AM | #32 |
Rep 16,079
14FE is 0w-20, which BMW started using with 2016 models. They did so to improve CAFE. Will it protect as well as 5w-30? I venture it will, for 4 years or 50,000 miles. But as its HTHS is no lower than that of the 5w-30 Molygen I'll stay with the Molygen.
11-15-2018, 01:45 PM | #33 | |
Rep 5,089
Where is the spec that says BMW LL14FE 0w20 is A1/B1? How about LL01FE 0w30, is that A3/B4? According to this page, LL01 HTHS is >3.5cp, while LL14 is 2.6-2.9cp, so what is LL01FE? https://www.bimmerworld.com/BMW-Engine-Oil/ Last edited by bavarianride; 11-15-2018 at 01:56 PM.. |
11-17-2018, 08:44 AM | #34 |
Rep 2,044
How about this:
Winter: 3/4 0w-20 LL14fe, 1/4 5w-30 LL01fe Summer: 1/4 0w-20 LL14fe; 3/4 5w-30 LL01fe Murf Last edited by Littlebear; 11-17-2018 at 03:36 PM.. |
11-17-2018, 02:52 PM | #37 |
Rep 10,351
How does it "beat" LL01fe?
"Drive more, worry less. "
11-17-2018, 02:57 PM | #38 | ||
Rep 10,351
LL01 is based on A3/B4. It has a HTHS of 3.5 or more.
11-17-2018, 03:45 PM | #39 | |
Rep 2,044
LL-14 (2014). API SN. ACEA A1/B1. SAE 0W20. HTHS rating is 2.6cP which makes it unsuitable as a performance oil. LL-17 (2018). ACEA C5. SAE 0W20. Replaces the LL-14 spec for N20, B38, B46, B48, and B58 engines. Not well-suited as a performance oil. Murf |
11-17-2018, 05:03 PM | #41 | |
Rep 10,351
*LL01/01FE is an obsolete spec in Germany due in part to the introduction to ULSG.
11-17-2018, 05:04 PM | #42 | ||
Rep 10,351
11-18-2018, 05:08 AM | #43 |
Rep 2,044
Don't quite understand your question, but....
My question would be, why do Texas BMWs come with 0w-20 oil? If I keep my car off the track, I see no reason not to use 0w-20, even all year in the NE. BMW stopped building cars that need 20w-50 long ago, and now they build cars to use 0w-20. Getting 'extra' protection, in some instances, is sometimes valid & good, but better gas mileage & burning less carbon (while getting better cold startup protection) is always good. YMMV Murf |
11-18-2018, 05:47 AM | #44 |
Rep 5,456
Drives: F30
Im running 5w40 year round in NorCal.
Recently switched from 0w40. |
