04-21-2018, 11:42 AM | #1 |
Rep 1,076
Is there anyway to activate the rear parking light led bars with the regular brake lights on braking during the day?
At night they can stay on as is and just the outer regular brake lights can turn on. In other words just work as normal. Any codes out there for this? By the way the car is a pre lci f31 |
04-22-2018, 04:01 PM | #3 | |
Rep 77
04-23-2018, 07:05 AM | #5 |
Rep 1,076
04-23-2018, 08:42 AM | #6 |
Schmollbraten
12512
Rep 1,985
No, Im afraid that cant be done, caused by the physical wirings to the lamps. As far as I could see this from the schematics layout of the wiring, theres no physical connection between the outer rear lamps and the brake lamps.
That surely wasnt foreseen, if you have the headlights on, the rear lamps are also lighted and when you press the brake pedal, the brake lights are applying additional. I see no way to power the tail lights simultaneously with the brake lights at normal daylight condition. If theres a coding way Im curious.
Citizen of ///M - Town, where too much is just right Some say, that my scrotum has its own small gravity field and when Im slowing down that brake lights come on at my buttox |
04-23-2018, 09:55 AM | #7 | |
Rep 1,076
Hence the hope for some coding miracle. Here is what I was basing my query on... Coding: Rear Light Bars Remapped For Turn Signals - Still Enabled for Tails https://f30.bimmerpost.com/forums/sh....php?t=1267468 |
04-23-2018, 10:50 AM | #8 |
Rep 53
You might be able to make this happen by exploiting the emergency brake function by mapping it to the inner lights and lowering the thresholds so that it activates every time you brake. I have the rear parking lights enabled all the time for safety reasons so can’t test.
Gabreigns493.50 |
04-23-2018, 12:44 PM | #9 | |
Rep 1,076
Morse: ... - —- .—. I kid... I just turn them Off and on in rapid succession while I speed up a little. In case of hard braking my outer lights and the third stop light blink in rapid succession and if I completely stop the hazards come on. |
04-23-2018, 03:37 PM | #10 |
Schmollbraten
12512
Rep 1,985
Hmm...the F32 holds 2 rear fog lights left and right within the main lights in the trunk lid. If you havent the rear fog switch, check if you have the front fogs, if its be able to modify as described here within the section. Pry out the lower unmarked button, remove the two plastic tabs behind and code the rear fogs, voila, you got this first. But: They should only be applicable at activated head lights, thats a safety switching, Idk how to code aside of its purpose...but its an option to get more visible.
Gabreigns493.50 |
04-23-2018, 04:08 PM | #11 | |
Rep 1,076
Dang3r12512.00 |
07-29-2018, 08:48 AM | #12 |
Rep 60
Has anyone been able to figure this out? I’m in the same boat — I think BMW could take notes from Audi on how brake lights should look and work!
07-29-2018, 03:41 PM | #13 | |
Rep 1,076
03-06-2019, 06:44 PM | #15 | |
Rep 146
Code:
MAPPING_TAGFAHRL_H_L_OUTPUT > sl_l (14) MAPPING_TAGFAHRL_H_L_FUNCTION > 0C MAPPING_TAGFAHRL_H_R_OUTPUT > sl-r (15) MAPPING_TAGFAHRL_H_R_FUNCTION > 0C MAPPING_TAGFAHRL_H2_L_OUTPUT > sl_2_l (16) MAPPING_TAGFAHRL_H2_L_FUNCTION > 0C MAPPING_TAGFAHRL_H2_R_OUTPUT > sl_2_r (17) MAPPING_TAGFAHRL_H2_R_FUNCTION > 0C Adapted from the threads on how to use the rear light bar DRLs as turn signals and the thread on how to remap the rear fog lights as brake lights. Last edited by shadowx360; 03-06-2019 at 06:53 PM.. |
07-21-2022, 06:42 AM | #16 |
Rep 224
It does work but you lose the function of keeping the rear DRLS on with the fronts in auto. Does work in other light settings though. Unless anyone knows how to keep the rear DRLS on with This braking feature
Martin
