BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > BM3 users dyno?
      03-11-2019, 07:53 PM   #45
rjd_F30
rjd_F30's Avatar
Drives: 2013 335i 6MT
Originally Posted by fate_f30 View Post
I got another quick question. Any idea how to get our cars into Dyno mode?
Not a clue, might have to hit google for that one.
      03-11-2019, 08:44 PM   #46
fate_f30
fate_f30's Avatar
Drives: 2014 Glacier Silver F30 328i
I see this 328i in dyno mode in this video but not sure how they got it there:
2014 GLACIER SILVER F30 328i * Wheels:18" VMR V801 Titanium Black Shadow * Springs: DINAN 1" Lowering Springs * Tune: BM3 OTS E30/93 OCT * Engine: Evolution Racewerks Catless DP/CP/FMIC * Intake: AWE S-Flo Carbon Fiber Intake * Exhaust: AWE Exhaust Suite + Mid Pipe * Go Fast Bits DV+ Diverter Valve * Plugs: NGK LI Plugs * Lights: Depo Angel Eyes W/ Morimoto HID's * Hood: Seibon Carbon Fiber Hood
      03-11-2019, 09:07 PM   #47
rjd_F30
rjd_F30's Avatar
Yah, definitely dyno-able, not sure how to do it though. There might not even be a dyno mode. Maybe you just strap it to the rollers and go.
      03-11-2019, 10:55 PM   #48
sspade
sspade's Avatar
Drives: F30
2016 BMW 320i  [7.87]
2014 BMW 328i  [6.83]
Never heard of such a thing. Doesn't mean it doesn't exist tho...
      03-12-2019, 05:06 AM   #49
ChuckF30
ChuckF30's Avatar
Australia
Drives: Bmw 328i F30
The dyno mode applies to Xdrive vehicles to disable front axle incase awd rollers aren't available. Its done in the cluster. Youtube bmw f series dyno mode.
sspade2464.50
      03-12-2019, 09:14 AM   #50
sspade
sspade's Avatar
Drives: F30
Very interesting. Definitely makes sense for AWD vehicles.
      03-12-2019, 04:20 PM   #51
LordRuxpin
Drives: F30 N26
Do you know if E30 is readily available? I don’t hear much about it... I hear more about E85.
E30 is just a 3:1, 93:85 mixture... 3 Gallons 93, for every 1 Gallon of E85.
-2013 F30 328i xDrive Melbourne Red-
Injen CAI | GFB DV+ | FTP CP & TP | CW DP | G-Plus Oil Cooler | Mishimoto CC | VSRF FMIC | BM3 Stg 2| H&R Rear Sway Bar | H&R SS & Bilstein B8 | Carbon Fiber Dealibobs | 525 LPFP | Soon to come upgraded HPFP (B58TU) and Navardi Tune
rjd_F301999.50
      01-29-2021, 10:05 PM   #52
wifes first bimmer
Drives: 330i, i3, '82 R65LS
not sure if the OP found his answer but I did - here is a gentleman who has compared how a piggyback tune and a flash tune match up on the N20 engine -
https://f30.bimmerpost.com/forums/sh...postcount=1063
MODS: Turbo Transformer boost controller, ECO-SPORT auto selector (home brew), Electronic boost gauge vent mounted, RPM based LED Carbon paddles
WISHLIST: BM3, HPFP, Turbo + IC + water ... new car eventually
      02-01-2021, 05:27 PM   #53
culpability
Drives: 2018 440i Gran Coupe
I'm in that same post, just above the guy who compared bm3 / piggyback / stock. My 328xi with the front drive shaft disconnected and a VRSF charge pipe put down 249.8 whp and 302 lb/ft of torque on bm3 stage 1 93 octane.
      02-01-2021, 07:00 PM   #54
Kel918
Drives: 2013 bmw 328ix
I did a dyno months ago using jb+ at 4psi and now I have bootmod3 stage 2 93 oct. Even though the car feels way smoother with bm3 my car was definitely way faster with the jb+. The jb+ dyno was done on a awd mustang dyno 262 awhp 294 awtq. A dynojet conversion of 11% = 290 awhp and 326 awtq.
VipinLJ1941.50
      02-01-2021, 10:02 PM   #55
RMachuca3d
RMachuca3d's Avatar
722
Drives: F30 328i Msport
I did the dinan piggyback initially, and now im running bm3 91acn stage1, even though the dinan on race setting was strong, the smoothness, consistency and extra features of bm3 totally made up for it. Its good for us f30 owners that we have various options depending on how we want to mod.
      02-16-2021, 09:54 PM   #56
wifes first bimmer
doesn't surprise me - here is another gentleman that tested a Turbo Transformer piggyback and BM3 on the dyno - the piggyback made more power and was actually a smoother dyno pull than the BM3 also. Not knocking BM3, I was actually planning on getting one until I saw this - now I am wondering if it would be really worth it to upgrade.
https://f30.bimmerpost.com/forums/sh....php?t=1796731
In your dyno sheet, what happened at 5000-ish rpm when there is a sharp dip? Is that the DME reacting to something (knock perhaps)?
      02-19-2021, 06:09 AM   #57
RMMAGA
Drives: 120i
JB4 or JB+ can make good power if you have the octane, the issue is they tell the ECU it has lower boost, as the ECU run speed density at higher loads, the ECU thinks the load is lower then it really is and therefore it runs more aggressive timing and AFR then it would normally at the load your really at
lets say the stock ECU would normally target 9 degrees at 200 load, but at 150 load it targets 14 degrees, you end up targeting 14 degrees of timing at 200 load, that is similar to an OTS BM3 e30 tune!
however if you do not have the octane, then things start to go bad with a lot of timing corrections and even broken pistons.......
So just know, the most boost you apply with a piggy back, the more aggressive timing you effectively apply, so make sure your fuel is appropriate for what that timing is, log it, check for timing correction, and if you see more then a few per 3rd gear ramp run back it off
also need to watch your AFR and trims, if you trims reach >35-40%, I would not go higher then that either, and fi you AFT is pegged at >14 also be more careful with your fuel as well as you will be much more prone knock
