BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > Who here torques the oil drain plug and filter housing?
      10-19-2019, 12:14 PM   #23
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
It's 8 Nm for the plastic plug/pan, 25 Nm for the metal plug/pan.
      10-20-2019, 02:14 PM   #24
IraHayes
Drives: 328i
I’ve always tightened the cap until snug. Up until my last oil change I always used a torque wrench for the drain plug , but my “small” torque wrench is a dial type, so kind of hard to read when you’re on your back looking up, especially since the car is so low, even on ramps. I need to invest in a click type.
      11-18-2019, 09:07 PM   #25
leejak
Drives: E92 M3, F12 6401ED, F32 428i
I torque the oil filter, but not the plastic drain plug
      11-18-2019, 10:09 PM   #26
Billfitz
Billfitz's Avatar
It should be the other way around. Too little torque on the plug and it leaks, too much and it breaks. The way the O-ring seals the filter cap makes for a tight leak free fit even if it's not torqued down. I've seen reports of filter cap leaks but only when a new O-ring wasn't used.
      11-26-2019, 10:18 PM   #27
SteveInfante
NewFinishColumbia/detailer
SteveInfante's Avatar
Drives: 2015 F31 xDrive
That new o-ring is key.
328 F31 xDrive/OSM/Venetian Luxury Line/Cold Weather/Premium/Driving Assist/Nav/Tech "Golden Goose"
78' Honda CB400A project
https://www.facebook.com/newfinishcolumbia
http://www.instagram.com/newfinishcolumbia
      12-06-2019, 08:37 PM   #28
Rebound
Rebound's Avatar
61
Drives: F33: The 435i Convertible
Originally Posted by BMWinAZ View Post
I am the King of Torque If there is a torque spec for a screw I will torque it to that spec. It must be part of being German
American. The torque wrench was invented in New York City, by an engineer in the Department of Public Works. But I think they were Germans (Bahr and Pfefferlie). Sounds German.
      12-06-2019, 11:53 PM   #29
johnung
Originally Posted by NoobCola View Post
I've done many oil changes on my previous vehicle and my girlfriends car as well so an oil change isn't new territory for me. Been seeing the DIY on oil changes for BMW and they all say to torque down. Just curious if the filter housing and drain pan are that sensitive and just doing the "tight but not too tight method" should be avoided.
I torque both the oil filter housing and the oil pan plug to spec. Torque wrenches are cool and fun to use. Love that nice ...click!
Seriously though, I read a post from a guy the other day that installed his oil filter housing incorrectly and it sprayed oil all over his engine. Years ago a buddy of mine did a quick tighten on his oil plug that wasn't tight enough. The oil drained as he drove and blew his engine. Not worth it to me.
      12-07-2019, 08:31 AM   #30
bgalakazam
bgalakazam's Avatar
Italy
66
Drives: 2015 328i
2015 BMW 328i  [0.00]
Just did oil change today. Torqued the oil filter housing to 25Nm. Didn't have a smaller torque wrench so hand tightened the drain plug, like last 3 times.
      12-09-2019, 10:22 AM   #31
jv004
Drives: F32 435i, E70 X5D
2014 435i Coupe  [0.00]
I torque both to specs every time. Rather do it one time and forget about it then worry if it's tight enough or if I over torqued it.
Wagner Evo II FMIC /// VRSF CP // CTS Turbo CAI // Wagner Catted DP // Dinan Exhaust// GFB DV+ // H&R Super Sport Springs // BM3 Stg 2 93oct Tuned// M-performance LSD// Future PS2 Upgrade
