11-06-2022, 05:21 PM | #1 |
Rep 2,664
Trans Oil Change Question
Fellers and Fellettes!
I got a quick question. I just swapped my transmission oil and pan using the kit from FCP Euro. I must have watched a million tutorials, from FCP's to the most amateur videos on YouTube. In every video single video, when the fill plug is removed, little to no oil comes out. When I removed my fill plug, massive amounts of oil came out. The car was purchased pre owned so I can't say whether or not this service was done in the past, but I don't think it has since the pan was original and nothing seems to have been disturbed. Is it possible that the fluid was overfilled from factory? I'm talking a lot of fluid came out. It literally looked like I removed the drain plug. I took a sample to send to Blackstone and there was little clutch material on the pan magnets so it seems like the transmission is doing well. Let me know what you guys think…
2016 340i xDrive - BM3 Stage 2 93 OTS - xHP Transmission Sutphin Custom Tune - B58TU HPFP - Bilstein B14 - VRSF Catless DP - Kyostar CAI - Dinan Midpipe
11-06-2022, 05:39 PM | #2 |
Rep 565
Was that vehicle running when you removed the fill plug?
Typically you fill the transmission while it is running, up to the fill plug level. I'm pretty sure when the engine isn't running there is excess oil that comes down to the pan.
2019 X3 M40i | TU Pump | AA DP | VTT GC | xHP Stage 2 | Dorch ECA | MHD Odin FF | Carbon Black | Adaptive Suspension | M-Sport Rear Diff | 20" staggered
SOLD! 2015 X1 35i | Alpina Trans Tune | Dinan Stage 2 | Bilstein B6 |
11-07-2022, 04:50 AM | #3 |
Rep 2,664
No, the initial drain and fill has to be done when the transmission is cold. The second fill has to be done with the transmission temp between 40-50 Celsius.
11-07-2022, 10:00 AM | #5 |
Rep 2,664
That was kind of my thought process as well. The transmission seems to have smoothed out a bit after the swap. My 1st to 2nd has been a little laggy and sluggish, but seems to be getting better now with the new pan/filter and fresh fluid. Still need to get some miles in before I can say for certain. Next up, rear diff fluid swap
11-07-2022, 11:44 AM | #6 | |
Rep 287
Drives: 2018 440i xDrive Gran Coupe
11-07-2022, 11:47 AM | #7 |
Rep 2,664
I had some whine from the transmission before I did the service and it seems to have all but gone now. I will report back after a few days of driving with more details.
Prak903198.00 |
11-07-2022, 02:18 PM | #9 |
Rep 2,664
Good news. I feel like my transmission fluid was way overfilled. I get that more is better than being short fluid, but it can't be good either.
11-07-2022, 02:52 PM | #10 |
Novice
316
Rep 697
How much bottles of the trans fluid did you use up? The last time I did my trans fluid service I probably had 3 full 1 (1/2) of the bottles left
11-07-2022, 02:56 PM | #11 |
Rep 2,664
I used about 5 1/2 of the 7 bottles that came with the kit from FCP Euro. This ensured while the transmission temperature was about 44 Celsius, the fill plug was evacuating a slow drip. I then torqued the fill bolt per spec.
blacksapphire440i316.00 |
