05-17-2020, 08:09 AM | #1 |
Rep 392
Rusting MPPSK exhaust tips
Whilst washing the car the other day I noticed one of the exhaust tips (right) seemed to have some rust on it. Only had the MPPSK a year so will definitely give the dealership a shout when lockdown is relaxed a bit more. Just wondering if anyone else has had this issue.
Pictures of both tips attached. Cheers.
2017 Grey Black 340i M Sport MPPSK
2015 BSM 328i M Sport MPE - sold 2007 LMB 320i M Sport - sold |
05-17-2020, 08:25 AM | #2 | |
Rep 2,271
IG: project540ix
G30 540i xDrive / Stage 3 via BM3 / xHP Stage 3 / Pure 800 Cast Turbo / 5" Catted Downpipe / MST Intake / Remus Exhaust / MSS Springs / 19" JR SL01 & Conti SC7 / 20" BBS CI-R & Michelin PS4S / F90 Sway Bars & Braces / Lots of Gloss Black |
2CRO4TV228.00 |
05-17-2020, 08:35 AM | #3 | ||
Rep 392
Thanks for the suggestion 👍🏿
06-27-2020, 05:07 AM | #5 |
Rep 392
At the stealers to sort this out and an interesting experience so far. Contactless handover of keys and car disinfected before being driven away. No free coffee and biscuits anymore 😞. Hope it doesn't take long to swap the exhaust tips.
06-27-2020, 05:13 AM | #6 |
Rep 187
Drives: 330d f31 msport
if it's not stainless steel , it will rust .
it's a year old and suffers with salt and all sorts of road shite . it will polish off , it's only minor . get a grip on reality . |
06-27-2020, 05:26 AM | #7 | |
Rep 392
The 2nd tip does not have the issue and yes it's not a major issue but I'll rather have the tips without the rust and yes I believe they are stainless steel under the carbon so should not rust. Cheers.
06-27-2020, 05:32 AM | #8 | |
Rep 1,158
Either provide a useful input or I'd say be quiet. Thanks for the insight into how metals rust, very very insightful. |
06-27-2020, 06:30 AM | #9 |
Rep 392
Proposed replacement tips also have light corrosion on them 😂. They have to order a new set which they will check for corrosion before calling me in for fitting.
QC process seems poor imho. Might have to order the carbon spoiler to go with the new tips 😉 when I actually get them.
06-27-2020, 06:35 AM | #10 |
King of the North (living in the east...)
1056
Rep 2,154
Interesting it's the right tip. I.e. The one with the valve open all the time...
2021 M340i in mineral white, options galore
Previously 2018 440i GC in MG 2015 330D F30 MSport EBII 2012 Alfa Guilietta 2.0d Veloce 2009 Fiat bravo sport 2000 ST Mondeo |
06-27-2020, 06:47 AM | #11 |
Rep 267
If stainless steel doesn't rust allegedly and they are rusting, then surely it's not stainless steel, just an observation
I don't eat raw meat unless it's wearing red stillettos
06-27-2020, 07:04 AM | #12 |
Rep 392
Yep it was the right one but the left one also had a little corrosion.
06-27-2020, 07:13 AM | #13 | |
Rep 392
https://shop.bmw.co.uk/bmw-uk-respon...trim/PID_1615/ Would be interesting to see if the same issue affects the chrome tips. Had an MPE on my 28i (chrome tips) for a few years with no corrosion issues.
06-27-2020, 09:37 AM | #14 |
Rep 649
My GC has the same carbon/SS tips as the OP. They've been on the car for 21 months and are showing no signs of corrosion at all.
Cheers Q
2018 440i Gran Coupe, MPPSK, Champagne Quartz, Ivory White, Adaptive Susp., Sunroof, Active Security, CA and a few other bits.
BIFCAIDS857.00 |
06-27-2020, 02:52 PM | #15 |
Rep 267
I looked at the link , read the description and nowhere does it mention stainless steel, it mentions the carbon, I think a presumtion has been made that it is stainless steel, but it isn't , it should be for the price though.
The chrome however DOES mention stainless steel, it is chrome plated stainless steel at a fraction of the carbons cost, you'd think that the carbon piece just went over the chrome bit, but no, obviously not
06-27-2020, 03:30 PM | #16 |
Rep 15,858
Stainless Steel can tarnish and/or 'rust'. Depends on the grade of SS and the type of finish. Then, how it interacts with the environment.
I spent over 20-years working with products using different grades of SS. Atmosphere (typically salts left on the SS) and humidity can degrade it quite quickly. The spec' comment on "SS and chrome", makes me wonder if it is not the best grade for resisting degradation. We'd use a lot of SS in the 316 range, with additional electro-polishing to give longevity to appearance. Same as the yacht/boat industries, where a lot of damp and salt is present. |
06-29-2020, 05:30 AM | #17 | |
The artist formerly known as AC Schnitzer UK
3609
Rep 4,518
06-29-2020, 06:58 AM | #18 | |
Rep 5,392
As you say, maybe the assumption is being made that the same chrome tips are just having carbon fiber added on top of them. But that may not be the case. Evidence seems to indicate that cheaper materials or finish are being used in the carbon fiber tips. |
06-29-2020, 07:06 AM | #19 |
Rep 1,659
The construction of chrome and carbon tips is utterly different.
I've just had MPPSK fitted and had new chrome tips. I swapped the carbon from my MPE to MPPSK. I haven't checked on RealOEM but the chrome ones seem to weigh about 3 times as much as the carbon. The chrome seems to have a double skin which is curved over at both ends. Didn't notice if it had the M/// on it as I didn't remove them from the plastic! The carbon is effectively just 2 tubes, one metal one carbon. |
06-29-2020, 12:06 PM | #20 | |
Rep 392
New tips arrived today will go down on Sat to swap round.
04-09-2021, 08:11 AM | #21 |
Rep 392
Booked in again tomorrow to get the tips changed again as the new pair have also started rusting. Can't be only me that has this issue but it's being changed under warranty so mustn't complain.
04-09-2021, 08:21 AM | #22 |
Rep 271
Actually, stainless steel can rust - it's all to do with the quality of the steel and the chromium content therein. So sorry for the correction of your info, but your post is not only unhelpful, but wrong .... I'm an engineer, with qualifications in metallurgy ....
