04-05-2021, 10:39 AM | #1 |
Rep 222
Tow Bar / Rear Diffuser Question
Apologies in advance because this feels like a stupid question...
My 335 has a factory fitted towbar and I’m toying with the idea of fitting an aftermarket rear diffuser. Presumably the two are compatible? Assuming so, any recommendations on which aftermarket diffuser to go for? |
04-07-2021, 05:17 AM | #3 |
Rep 3,876
The BMW M Performance diffuser may end up touching the tow bar socket, as @jacksrath noted. This is the reason why it is officially incompatible with cars equipped with a tow bar. Some have however installed it successfully nevertheless, with a 1-2 mm clearance... but this is a gamble.
04-07-2021, 05:50 AM | #4 |
Rep 1,801
My copy spoiler fits fine with my electronic retractable tow bar. It really is just a few mm of clearance. If you put a £1 coin there it'd get squished but a 1p piece might just pass.
Europe's fastest (stock block) F31 340i RWD | MPPSK | XHP 3 | Pure800 | Port Meth | Dorch 2 HPFP | MG Flasher
04-13-2021, 10:21 AM | #6 |
Rep 122
I have the BMW M Performance diffuser as well with the electric tow bar. As you can see on the pictures below, it barely touches the diffuser rib.
If I use it I think I will just stick some tape on the tow bar and diffuser rib to reduce scratches.
Mods: 19" HRE FF15, M Performance diffuser, Bilstein B16 Damptronic, VRSF catted downpipe, Remus catback, Dorch St1, Pure 800, OS Giken LSD, Ross Racing PCV+OCC V1
goram89.00 |
