06-14-2016, 07:29 AM | #1 |
Rep 258
Drives: F30 320i (328i ECU) M-Sport
Dampers upgrade without lowering
Hi, Friends,
I would like to upgrade the handling the car, but cannot lose the ride height due to the road conditions. My options are (keeping the stock springs): 1) Koni Sport (Yellow) 2) Bilstein B6 (Yellow) 3) Bilstein B4 (Black, stock replacement- do they have any improvement over floaty stocks?) 4) M-suspension springs, which are only -10mm from regular (I have one person, whom I can ask for the VIN-number to order, but not sure these springs do fit stock front dampers physically) with further dampers replacement with one of the options 1), 2) or 3) Another option is trying to find used M-suspension, but this is a quite complicated task, as here very few cars were ordered with that. Thanks a lot in advance for any opinions.
'13 F30 320i (328i ECU) RWD M-Sport
Michelin PSS, M-Sport brakes, 320i LCI muffler F32 bottom V-bar F80 bottom reinforcement plate Koni Sport, M-Performance springs, M135i Anti-roll bars |
06-14-2016, 11:02 AM | #3 |
Rep 191
i just put on b6's in the back (wed for the fronts) and notice an improvement already.i hated the bouncy ride of the stock setup. oem shocks are way softer than the HD b6's when i replaced. will update once i have the full setup, but from what others are saying, it's like "night and day" between b6's and oem dampers!
2012 335 2016 435 2019 440 GC |
06-14-2016, 11:44 AM | #4 |
Rep 258
It is 2013 (09/13) F30 320i RWD
06-14-2016, 12:21 PM | #5 |
Rep 10,249
I just noticed your vehicle details in the signature. Got it - thanks.
Koni Sport shocks are adjustable and a great first choice. Koni FSD shocks are not adjustable but another excellent choice for your vehicle. Because you prefer to retain OEM springs, I suggest to explore Koni Sport shocks first because stiffer shocks with softer OEM springs may require tuning (adjusting) to reduce bouncing effect. You live in Rostov, correct? What are the prices for Koni products in Russian Federation? |
06-14-2016, 12:36 PM | #6 |
Rep 262
B6 Bilsteins on mine....it's firm but feels like a BMW SHOULD....no float and no roll, just sticks to the road like glue. My car is 2013 328 X Drive and had std suspension. The stock front shocks were RIDICULOUSLY soft....could push and pull them out easily with my bare hands...(not against the ground).
06-14-2016, 12:57 PM | #7 | |
Rep 258
Yes, I'm in Rostov-on-Don. Koni Sport for F30 here cost $230 for the front one and $120 for the rear one: http://www.koni.ru/finder/777/5555/
06-14-2016, 12:59 PM | #8 | |
Rep 258
06-16-2016, 05:12 PM | #9 |
Rep 258
So guys, thanks a lot to everyone who shared with experience impressions- I've chosen Koni Sport finally, as those are less stiff plus adjustable- another possibility to play with settings in the front (rears are adjustable only when not installed).
Awaiting for the order to arrive on June 21, so plan to install next week. Will definitely report!
08-03-2016, 11:11 AM | #10 |
Rep 191
Drives: 2013 BMW 335i M-Sport
any update on the Koni's? I'm debating between the B6 and the Adjustable Koni's.
I had the Koni's on my s197 Mustang a few years back and they helped tame that beast... not sure if its a direction I really need to go with the f30. Also, can you easily adjust them ON the car? TIA
2013 335i M-Sport 8spA
2011 M-B GLK350 2000 Dodge Ram 2500 QC 4x4 CTD |
08-04-2016, 12:22 PM | #11 | |
Rep 1,252
Docrace 6266
fhlh37.50 |
08-16-2016, 06:53 PM | #12 |
Supreme Allied Commander
3815
Rep 54,319
Drives: F80 M3
Location: Santa Barbara, AP, Brembo, GIAC, Koni, Ohlins, Performance Friction, www.hpautosport.com
If you want adjustability go with the Koni's, none adjustable Bilstein's are good too.
08-30-2016, 08:51 PM | #13 | |
Rep 1,261
