02-18-2019, 07:32 PM | #2 |
Cheapskate
4447
Rep 4,993
I run what's on the door jam placard, because that's what I'm supposed to. No issues but I only have 6k on the car so I wouldn't expect to see any abnormal wear indicators for a while.
02-18-2019, 09:42 PM | #3 | |
Rep 123
You can run 2 - 3 PSI less for a little more comfortable ride but I would not go less than that. |
rixride35.00 Machinebuilder278.50 |
02-19-2019, 05:06 AM | #4 |
¯\_(ツ)_/¯
945
Rep 1,762
36
02-24-2019, 11:02 AM | #5 |
Rep 165
02-25-2019, 01:33 PM | #6 |
Rep 878
19” alloys, staggered, non RF I have mine at 37 all round.
03-03-2019, 12:10 PM | #7 |
Rep 5
Recently bought f30 320d xdrive but it has the 20 inch m performance staggered wheels.
Any advice on tyre pressures as the card in the door doesn't go up to 20inch. Thanks |
03-03-2019, 12:51 PM | #8 |
Rep 5,457
Drives: F30
According to Tire Rack...
You should run the pressures listed on the door placard regardless of RFT, non-RFT, or size. |
03-27-2019, 08:28 AM | #10 |
A family of bimmers
2745
Rep 7,741
i run 34f/37r
03-28-2019, 02:27 PM | #11 |
Rep 433
2015 328i (probably base model), 17" wheels, Continental run-flats: Door sticker says 32 all around. I've been running 34, as it's comfortable enough and I hope to eke out a little more fuel mileage. Any higher on the cracked blasted streets here, and my car would start complaining.
03-29-2019, 07:57 AM | #12 |
Modder of everything I own
147
Rep 491
2013 335xi 255/35/19 square setup - 40 psi
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
04-29-2019, 09:23 AM | #14 | |
Rep 433
Car rode on these cracked streets like a truck without shocks. I let some air out so that TPMS reads about 32, the placard pressure. Much more comfortable. If you live in a town as I do with the finest of Third World roads, unless you want to beat your car up or are a masochist, go with the placard pressure. You'll thank yourself. |
04-29-2019, 11:00 AM | #15 |
A family of bimmers
2745
Rep 7,741
at cold temp? i can only imagine what they are at when up to operating temp.
05-06-2019, 12:45 AM | #17 |
Rep 165
2017 440i convertible. 36/41 f/r. Per placard on door jamb. After about 45 min driving rears up to 44-45 psi. Question is: what if I drive for another 4-6 hours at 44-45 psi? Is this too high?
05-09-2019, 11:52 AM | #18 | |
147
Rep 491
I thought I would leave it at 40psi for a while after a local indy shop recommended it, the 2 guys there are friends of the family and race and tune so I thought I'd try what they recommended.
05-09-2019, 02:29 PM | #19 |
A family of bimmers
2745
Rep 7,741
i run 34f 37r on my 19s and after a 20min drive on a day thats 70 degrees on the highway my rears are up to 39. i cant imagine what starting at 40 would do. you should enable the PSI measurements in the idrive to see
06-22-2019, 07:21 AM | #20 |
Rep 433
Checked the tire pressures with a G.H. Meiser Accu-Gage. Turns out I have been running 34 all around, and comfortably. So I performed a TPMS reset, which you have to do while parked and with the ignition or engine on, and then drove the car for a few miles (such a chore, huh?) while the tire pressures reset. TPMS now says I have about 32 psi all around.
06-26-2019, 04:34 PM | #21 |
Rep 13
I once rode around horrible roads in Ireland for 3 days in a C class rental at 4-6 bar(~60 psi+, can't remember exactly) - it was a rental and I had no reason to check until a low tire pressure warning came on and I checked it at a gas station. The folks there were all dumbfounded. Quickly lowered to around 2.2 bar and carried on. Only noticed slightly softer ride.
So for those of you running high - tire wear might be an issue but the tires can take it. They say to increase pressure by 10psi for extended 100mph + driving. You aren't going to pop a tire at 40 or even 45 PSI unless you're running the ultra low profile minimum tire width for a wheel width or something. |
