10-21-2019, 11:04 AM | #1 |
Rep 63
So I have great news that my 2014 435I with 50K on it now has a blown engine. I lost all compression in cylinder 5 and the leak down test sounds like the air is coming out of the oil cap. So with that knowledge I need help figuring out my options.
I think these are my options: Drop oil pan and see what happen - possible replace piston. Find a drop in engine and just replace the whole thing. Send the engine out to get built. What do you guys think? Just sucks I have to do this but I want to do it right. I have all winter to get it working and I have a full shop in the garage. I would just follow the ISTA steps to pull the engine. I have FBO with the pure stage two turbo and the XDI fuel pump. Any input would be great. Thanks Found out what is wrong with it. Broken spring.
Current Mods
2014 F33 435I // Intercooler//Pure Turbo Inlet // DV+//Charge Pipe//Boost Pipe//Downpipe//BM3 Custom Tune//Pure Stage 2 turbo//XDI-35//PR Black Coils//LSD |
10-21-2019, 12:34 PM | #2 | |
Rep 188
ronanz1819.50 |
10-21-2019, 12:57 PM | #3 |
Rep 1,499
+1
10-21-2019, 01:00 PM | #4 |
Rep 462
Agree with above.
It sounds like time and cash are not a hindrance. If the intent is to repair rather than sell, the cost difference will not be huge if done yourself, and it sounds like the desire for more power is there(blown engine usually means pushing the limits of safety for more hp). Curious as to the conditions/circumstance to the engine's injury. What kind of boost levels were you running? any logs?
2015 435i XDrive Gran Coupe M Sport 8AT - Track Handling Package - M Brakes - PS2 - VRSF Charge Pipe - VRSF FMIC - BMS Intake - JB4 with MHD BEF - AA High Flow Catted DP - BMS Meth Kit 70% Meth - TurboSmart PB DV - MST V2 inlet - xHP Stage 3
10-21-2019, 01:04 PM | #5 | |
Rep 1,105
10-21-2019, 01:11 PM | #6 |
Rep 1,499
and the buzzards start circling
10-21-2019, 01:13 PM | #7 | |
Rep 63
The story is... Updated the XDI pump and turbo then went to the Strip. I still did not have the custom. the car ran great. On the way home it start to run bad. I pulled the spark plus and #5 had gas on it. So I replaced all the injectors thinking it was a leaking injector. It did run better but still not like before. I was not driving it because the XDI pump was making a loud noise that I did not like. I would come home from work upload the updated tune and take it for a spin. Well it started to smoke and then I noticed oil coming out of the exhaust. So I did a compression test and #5 did not have anything.... I don't not want to replace the motor and rather get the special tools and just take it apart. Would be a fun project with my son. So just upgrading the pistons if the cylinder wall is not messed up. Anything else while I have it apart? Here is the log that I did right after before I figured out that the #5 is bad. http://www.bootmod3.net/log?id=5da4d8bfc090c64ea9e15669
Current Mods
10-21-2019, 01:16 PM | #8 |
Rep 63
My plan is to do something...
Current Mods
10-21-2019, 03:52 PM | #9 |
Rep 1,105
Would be an awesome build to see from start to finish!
Just wishful thinking to get a used XDI pump lol
10-22-2019, 06:18 PM | #10 | |
Gettin It Figured Out
1820
Rep 2,669
10-25-2019, 12:10 PM | #11 |
Rep 63
So I looked at all the piston and this is the only one with oil on it. This is number 5
Current Mods
12-12-2019, 03:34 PM | #12 |
Rep 63
Found out what is wrong with the engine. Broken spring and bolt.
Going to replace everything with new oem parts.
Current Mods
Pray for Mojo429.50 |
12-12-2019, 04:30 PM | #13 |
Rep 772
Drives: 2015 435i grand coupe xdrive
Wow interesting! You should look into MILVS while you are there.
2015 435i grand coupe xdrvie (current)
2006 F250 powerstoke CCSB (current) 2014 M235i Black on Red (SOLD) / 08 e90 335i MT Pure Stage 2 High flow (SOLD) 08 128i 6MT (SOLD) / 08 335i 6MT Pure stage 1 (SOLD) |
12-12-2019, 04:32 PM | #14 |
Rep 762
check this out
N52 cam for n55 - yields solid gains https://f30.bimmerpost.com/forums/sh....php?t=1660744 since you already have everything open, might be worth considering since you are already PS2 + HPFP.
MG F30 M-Sport 6mt FBO w/ MHD stage 2 plus (PWG), ST XA Coilovers, 19" VMR V804.
12-13-2019, 06:46 AM | #16 | |
Rep 63
https://rover.ebay.com/rover/0/0/0?m...2F233005051939
Current Mods
12-13-2019, 06:47 AM | #17 |
Rep 63
No idea! Kinda crazy. Hope it did not do any damage inside.
Current Mods
12-13-2019, 06:49 AM | #18 |
Rep 63
Ok so I did look at this. Looks like $350 for the kit. I guess I should do it. I wonder if I should just keep going and pull the top and do a stage 3 port. Man so many choices.
Current Mods
arhoads335i179.50 |
12-13-2019, 07:21 AM | #19 | |
Rep 287
n55 engine no compression 435i f33 |
