10-23-2019, 11:49 PM | #1 |
Rep 15
Help needed. Apex ARC8 Square Set
so theres a seller about 2 hours from me selling apex arc 8 18x9.5 +35 square set up with 265/35 for a good deal.
will this set up work for my 2016 340i? or will it be too aggressive? I'm currently on stock suspension.would like to jump on this deal if it works. thank you in advance |
10-24-2019, 09:18 AM | #3 | |
Rep 15
so as far as fitment goes.it works? awesome...now about the tires.what do you mean when you say it's too small? is it bad?I cant use em? I'm sorry but I'm just bad when it comes to this.so any help is appreciated |
10-24-2019, 09:59 AM | #5 |
Rep 891
I have to run -3 degrees of camber with a mild fender roll to fit my 245 (256 measured) tires up front.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i |
F30Chris0.00 |
10-24-2019, 11:53 AM | #6 | |
Rep 681
What are you wheel specs? It sounds like you're running a pretty low offset if you need -3 camber and a fender roll to fit 245s in front.
2016 328ix F31 - SOLD!
2006 997.1 C4S |
F30Chris0.00 |
10-24-2019, 12:06 PM | #7 | ||
Rep 15
10-24-2019, 02:13 PM | #9 |
Rep 15
he's a private seller.so it's the only tires he has but I did ask him if hes willing to sell without tires.hoping he says yes
10-24-2019, 05:12 PM | #10 | ||
Rep 891
10-24-2019, 05:48 PM | #11 |
Rep 681
Ahh yeah, makes sense with those tires. I ran ECS in 245 which are pretty narrow. My Indy 500s now are 255 but they're prob still not as wide as your RS4s. I'm running with -2.5* camber with standard LCAs and 8* of caster. We'll see how 245/40 r888r/nt01rs fit with my 18s once I get them mounted up.
2006 997.1 C4S |
10-25-2019, 10:01 AM | #12 | |
Rep 891
andino479.50 |
