08-31-2017, 12:35 PM | #1 |
Rep 801
What gear for Dyno? BM3, FBO, EWG, 93, 335i XDrive 8AT
Headed to the dyno and was curious what gear I should be doing the pulls in. My car is a 2014 335i XDrive EWG 8AT. Thanks!
08-31-2017, 01:12 PM | #2 |
Rep 775
4th
Enjoy the Drive,
Steven 2014 435i M-Opt, M LSD, Dinan CAI/IC/BTurbo/Stage 4, ER TIC/CP, GFB DV+, Fabspeed HJS cat DP & Mich PS4S. |
08-31-2017, 01:18 PM | #4 |
Rep 1,782
I thought 5th gear for the 8AT as it has 8 speeds and 4th was for 6MT cars
13' 335i M Sport. EBII/Coral Red 6MT. RPI GT exhaust, Resonator delete, PS1, GFB DV , BM3 Stage 2, ER CP, VRSF DP, VRSF 5.5in Stepped FMIC, Dinan Shockware. Carbon M Performance rear diffuser. M4 trunk lip. Conti DWS06 225/40/19 and 255/35/19
08-31-2017, 01:37 PM | #5 |
Rep 801
I just looked at the gear ratios for the 8AT and 6th is the 1:1 ratio, but I would hit the speed limiter before redline. Would it not make sense to do pulls in 5th since it would be the closest gear to the 1:1 ratio without hitting the speed limiter?
08-31-2017, 02:12 PM | #6 |
Rep 775
You guys are right, 6 is 1:1 yet many people use 5th.
4th is for MT
Enjoy the Drive,
08-31-2017, 08:46 PM | #9 |
IG @bmwF9xG80
3813
Rep 7,593
Manuals Dyno in 5th
Auto usually in 4th You wont hit speed limiter since you have BM3 (delimiter) What I tell everyone is do your first pull in 5th, 2nd pull in 4th, and decide from there. I've made 4 pulls in 5th, 4 pulls in 4th with little difference. Plus 4th gear will heatsoak less
60-130mph 6.5s X4M #HCP
08-31-2017, 09:40 PM | #10 |
Rep 716
Drives: F90 M5
I dynod in 5th, advised by a few others
(Sold) M235I Dinan intake, Active Autowerke FMIC, meisterschaft, TCKline coilovers, NT01's, BMS Oil cooler valve, VRSF DP&CP, BM3,StopTech Trophy BBK, Corbeau FX1 Pro seats, AP bar, Bimmerworld V3 Wing, APR Front splitter, Seibon Vented CF Hood
399.8whp on 91oct Hmu on Ig: @n55_shayan |
03-22-2019, 05:31 PM | #11 |
Rep 832
Drives: 2019 G01 X3
I'm probably getting a baseline dyno soon (hopefully on a Dynojet) before flashing BM3 later this year. Never ran a dyno before so I'm looking to see if I should run 4th or 5th gear. F32 435i, N55 EWG, RWD, 8AT.
Also, Sport+ or DSC off? STD Smoothing 5? |
05-01-2019, 04:16 PM | #13 |
Rep 832
Drives: 2019 G01 X3
Just to follow up, I took a baseline dyno yesterday.
No problems using: -DSC off -Manual mode -5th gear -Told the dyno operator to be careful not to hit the kickdown switch on the gas pedal. This will cause an unwanted downshift even in manual mode. I was ready to enter the "secret dyno mode", but it wasn't necessary. In case anyone needs it, here's how: Doors closed Ignition On Clear messages on dash (BC button) Hold dash reset buttton Press button to 03 Hold DSC Off Hold dash reset button Press dash reset button to confirm Start engine Sport+ Shift to Drive Shift left to Sport Mode Tap left paddle shifter to Manual Mode |
