BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Full lock rub only in Sport mode
      10-25-2020, 05:32 PM   #1
obzen
obzen's Avatar
Drives: 2017 BMW 440i Gran Coupe
Went from stock 19" 442m 225/40 - 255/35 to 19" 235/40 -255/35 with ET30 square 8.5j. Stock m suspension rwd not lowered. I'm hearing little rub from from but only when I'm in sport mode. In Comfort full lock no rub? Should I be concerned ?
//'17 F36 440i Mineral Grey
//MPPSK w/carbon tips
//Apex ARC8 255/40/18
//MST intake
//AutoTechnik brace
      10-25-2020, 06:07 PM   #2
HarryTee
HarryTee's Avatar
Drives: 2020 M4CP & 2017 440i GC
If you do use sport mode then you should be concerned.
But from your description, I think if you can find the place of rubbing contact, you may easily be able to bend the metal/plastic a bit to resolve it.
      10-26-2020, 06:24 AM   #3
obzen
obzen's Avatar
Edit: today I noticed it only rubs if I'm backing up, full lock, and turning right in sport mode. If I go left it doesn't rub. I wonder if it's because the front two tires have a bit different tread wear? They're sottozero3s
I'm gonna try and visualize where it's rubbing I think it should be ok to run this setup for a 4 months
//MST intake
//AutoTechnik brace
      10-26-2020, 06:26 AM   #4
Skyhigh
Skyhigh's Avatar
1888
Drives: BMW F36
I am puzzled what I am missing here, but what has Sport Mode to do with it!?
kern4174446.50
      10-26-2020, 08:10 AM   #5
kern417
Cheapskate
4447
Doesn't really make any sense but it's likely that you sitting in the driver's seat is reducing your clearance in the front right wheel well. Either way it should be fine but you can fix it if it's annoying.
      10-26-2020, 08:15 AM   #6
obzen
obzen's Avatar
Maybe because the dampers are stiffer and somehow that contributes to less clearance on full lock? I'll mess around with it today and try to figure out why this is
//MST intake
//AutoTechnik brace
      10-26-2020, 08:16 AM   #7
obzen
obzen's Avatar
Could be this. I need to turn fulllock and look in the wheel wells to see where it rubs exactly. Weird that it only does it one way.
//MST intake
//AutoTechnik brace
      10-26-2020, 08:44 AM   #8
Desertnate
Drives: BMW 435i
2016 BMW 435i  [0.00]
This would only apply if he has the adaptive suspension. Otherwise, nothing in the suspension changes when you go into sport mode. Even if we assume adaptive suspension, I'd think there would be less of a chance of any rubbing in sport mode because it is harder to compress the suspension with the stiffer setting. It isn't like suspension components change position depending on setting.
It's a head scratcher for sure...
      10-26-2020, 08:45 AM   #9
sqwinny
Drives: 2013 6MT 328i M Sport
Sport mode is odd, perhaps you are just noticing it now. You could always grab a quick set of spacers and you have more clearance.
      10-26-2020, 08:58 AM   #10
obzen
obzen's Avatar
Going from stock 19x8J ET36 to 19x8.5J ET30 the wheels are more flush now so adding a spacer will push them out past 'flush' likely resulting in more rubbing
//MST intake
//AutoTechnik brace
      10-26-2020, 09:04 AM   #11
Skyhigh
Skyhigh's Avatar
1888
Drives: BMW F36
Precisely!
Only the Adaptive Suspension is affected by the mode (Comfort vs Sport) and even that only changes the stiffness and response, not the height! Stiffer suspension means less bouncing, so less rubbing....
And the OP does not even mention Adaptive Suspension....
It makes no sense to me.
      10-27-2020, 10:30 AM   #12
obzen
obzen's Avatar
Precisely!
Sorry for the confusion, turns out that ET30 upfront with 235/40 rubs a tiny bit on the front of the wheel well. It's very close, a couple mm would clear it. Downsizing to 35 sidewall instead of 40 this week.
Originally I thought it was only in sport mode but after looking closely it rubs in comfort mode too so that was a false report on my end. Does the speedo report wrong with downsizing the front sidewall to 35 since OEM is 40?
//MST intake
//AutoTechnik brace
      10-27-2020, 10:32 AM   #13
Skyhigh
Skyhigh's Avatar
1888
Drives: BMW F36
Yes, it will.
You are effectively changing the circumference of the wheels.
obzen188.00
      10-27-2020, 11:47 AM   #14
obzen
obzen's Avatar
Yes, it will.
aside from the speedo will there be any issues running 35 profile tires instead of the 40? I know a bunch of people run 35 in front but not sure if thats an x drive thing or what not. For RWD does it make any negative difference except for the speedo and ride quality?
//MST intake
//AutoTechnik brace
      10-27-2020, 12:22 PM   #15
about94ninjas
about94ninjas's Avatar
Drives: ‘18 340i
Yes, it will.
I've been running 255/35/19 up front and I've had zero issues. It actually helped correct the speedo, which reads a couple mph lower from factory haha. I am using camber plates to help with the clearance tho
A 35 vs 40 profile in and of itself isn't going to affect much, sidewall and overall diameter is what you need to pay attention to.
      10-27-2020, 01:15 PM   #16
pauli18c
pauli18c's Avatar
Drives: 2017 340i RWD M Sport
How often do you drive around in reverse, at full lock, while only going right?
I would just drive it if it doesn't rub under normal driving conditions...
2017 340i M Sport Alpine White / Coral
Dorch Stg2, CTS catless, xHP, Custom E50 Tuned by Shoup
      10-27-2020, 01:18 PM   #17
obzen
obzen's Avatar
Yes, it will.
If 35 sidewall is within the diameter spec than I'm going to assume it's perfectly fine and not loose any sleep over it
//MST intake
//AutoTechnik brace
      10-27-2020, 10:20 PM   #18
about94ninjas
Drives: ‘18 340i
What paulie18c said. If you really wanna be sure, just go to a tire size calculator online, enter the stock size and then what you're running.
      10-28-2020, 03:38 AM   #19
BWbimmer
BWbimmer's Avatar
Drives: BMW F36, E36, E93
Yes, it will.
Since the speedo is "connected" to the rear wheels and the rear wheels didn't change, I can't seen any circumference impact?
Such Fun
If you finde any spelling mistakes in my posts you may keep them, no return required
      10-28-2020, 03:53 AM   #20
about94ninjas
Drives: ‘18 340i
Yes, it will.
I believe BMW uses the front wheels for speed
      10-28-2020, 04:00 AM   #21
BWbimmer
BWbimmer's Avatar
So you are saying if you are doing a burnout, then the speedo stays at 0?
Then this must have changed with the F series
Such Fun
      10-28-2020, 04:59 AM   #22
about94ninjas
Drives: ‘18 340i
Couldn't find a burnout video, but found one doing a rolling burnout, and the speedo was reading 40mph at the top of 3rd lmao. I guess that's why f series have a specific "dyno mode"
