05-09-2015, 07:03 AM | #3 | |
Pace Car Driver
1547
Rep 3,163
The wife and I do tend to run the car hard so I can understand this. Lifetime of the car I think we are averaging 17.8 MPG. |
05-09-2015, 12:40 PM | #4 |
Rep 10,509
Agreed, normal. Next time your car is in for service ask them to check on the valve cover gasket. That was the cause on my z435, and gasket was replaced at the 2yr market when i thought to ask about it. I had been putting in a quart every 8-10k miles.
05-09-2015, 01:20 PM | #5 |
Rep 355
Before 8k miles I had to add a quart twice 😎
'14 F30 335i Msport bsm-black dakota
Tech-Premium-HK South Florida Real Estate |
05-09-2015, 02:45 PM | #7 | ||
Pace Car Driver
1547
Rep 3,163
Nice, work that motor. Quote:
Gas pedal is on the right. |
05-09-2015, 09:44 PM | #10 |
Rep 1,627
Interesting, I drive my car probably a little harder than I should , i.e. frequent full throttle take-offs up on ramps and lots of track days at the Avenue of the Giants (stock tires only lasted 11,000 miles), but my car has never needed additional oil in all of its 28,000 miles.. I did do a relatively hard hard break-in due to the fact I could not wait 1,400 miles to drive it properly, which may have helped out. Anyway, I don't think the need to add a quart after the mileage mentioned is extreme in any way.
M4 in MG | 6 MT
05-09-2015, 10:39 PM | #11 |
Rep 2,720
I was talking to a reputed tuner shop guy in Miami and talked about how my friend's e92 M3 V8 with just 20k miles needs oil. My friend said its normal as per forum and Bmw dealer.
So where does the oil go ? Piston rings leaking ? If this is normal, then is the car giving full performance ? |
05-09-2015, 10:59 PM | #12 | |
Rep 1,627
M4 in MG | 6 MT
05-10-2015, 12:31 AM | #13 | |
Rep 10,509
On all my BMW so far there was a little bit of consumption before the first oil change but after that there is no oil usage (other than when valve cover gasket was leaking on my Z4 as I mentioned earlier) |
05-10-2015, 10:56 AM | #15 |
Rep 5,316
Drives: G80 M3 6MT
Sounds right
Scott, Partner
Insight Automotive Consulting Click HERE for all discounted BMW New Car Pricing Click HERE for all BMW In Stock Inventory Specials Call/Text: 516-416-5481 Email: scott@insightautoconsulting.com |
05-10-2015, 12:04 PM | #16 | |
Rep 1,437
http://www.bimmerfile.com/2011/09/16...ar-or-any-bmw/ If you what to break in an engine - with the break in right oil ... http://www.mototuneusa.com/break_in_secrets.htm |
05-11-2015, 03:13 PM | #17 | |
Rep 10,346
"Drive more, worry less. "
05-11-2015, 05:08 PM | #18 | ||
Rep 2,720
06-08-2015, 11:11 AM | #19 |
Rep 17
I check my N47 just before it is due service and it always reads full. Working an engine hard tends to cause some oil to vaporize. This shouldn't be a problem if you are using a BMW-spec synthetic oil.
