BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > Running 2.5 Gallon e85 340i?
Studio RSR
      10-14-2020, 07:28 PM   #1
Foriegnmonkey1
Drives: BMW 340i RWD
Is this safe, just tried it today and I can feel the engine just runs better.
Worried about my fuel lines tho
      10-14-2020, 08:02 PM   #2
jackstrath
Scotland
659
Drives: 16' F31 340i & 03' Focus RS
Car will be fine
      10-15-2020, 11:44 AM   #3
eksigned
eksigned's Avatar
139
Drives: 4er
Fuel lines are okay. But you should do the research. Also, stock fuel pump doesn't like E85. You need the TU pump at minimum.
      10-15-2020, 02:32 PM   #4
weehe126
Drives: 2017 340i
Jesus, does anyone search anything anymore. As said before, fuel lines are E85 compatible. You can run up to E25-30 on the stock fuel pump.
eluded3002.00
kern4174445.00
      10-15-2020, 02:35 PM   #5
Foriegnmonkey1
Sorry man just didn't get a definitive answer anywhere. Thank you!
      10-15-2020, 03:18 PM   #6
G.Newt
Drives: CT4-V Blackwing 6MT
Been running the Stage 2 E30 map just fine on stock HPFP.
2022 CT4-V Blackwing 6-speed
SOLD: 2016 340i xDrive 6-speed
DAW v2.5 turbo E40 | Dorch S2 | VRSF DP | MST intake | AWE catback | 335is clutch | CSF heat exchanger | RK Autowerks intake manifold | Orange M Perf Brake Kit | KW Street Comfort coilovers | GTS taillights V2
      10-15-2020, 03:26 PM   #7
Cobra358
Drives: bmw 335i
I was having rail pressure drops down to 1700-1900 with stock pump on stage 2 E30 map. A little too low for my comfort.
G.Newt803.00
eluded3002.00
      10-15-2020, 04:08 PM   #8
340iNL
Drives: G81 M3 Competition '23
Yeah I don't really like the idea of running e30 map on the stock pump. If the rail pressure goes down the cylinder might get dry lol then you are f*****d
BMW M3 Touring Competition xDrive '23
Maserati GranCabrio MC '19
Maserati Levante S '17
Alfa Romeo Giulia Quadriofoglio (sold), Ferrari 488 spider (sold), BMW 340i xDrive F31 (sold)
      10-15-2020, 06:43 PM   #9
G.Newt
Ah, gotcha. The importance of logging and "every car is different" is understated. I did an E32ish mix, and mine drops to 2400psi for 400rpm (2700 - 3100). Before and after that range, rail pressure is good. I can live with the 400psi dip.
eksigned139.00
      10-16-2020, 01:40 AM   #10
eksigned
eksigned's Avatar
139
Drives: 4er
Really? Alex from Mission Performance saw dips in rail pressure with just 1 gallon of E on car on the stock pump. Was noticeable in driving too...felt like timing being pulled 🤷
      10-16-2020, 05:45 AM   #11
IMS-340C
IMS-340C's Avatar
Egypt
395
Drives: Self Tuned 340i 8AT RWD
Not questioning your findings mate but where did you read running E85 with stock fuel lines are compatible for the long term ?
On my official BMW fuel cap label it says maximum E10.
As far as I read engines built for running high Ethanol content are using different materials on the whole fuel system as Ethanol is very a corrosive fuel.
I think at this point nobody knows what long term damage could Ethanol cause.
2018 340i 8AT RWD - M Sport - Catless MPPSK - Stock Turbo - Stock HPFP
-------- Tunes: Self Made Tunes - MHD ------ Fuel: 92RON/87OCT --------
      10-16-2020, 09:57 AM   #12
weehe126
Drives: 2017 340i
Unless BMW went back to 80s fuel lines from what they have been using the last 15-20 years. They are (and all other cars) compatible with E85. BMW says E10 because that is what is needed to get the mpg and emissions they state. Would love to hear examples of BMW fuel systems being damaged by E85. My previous 150k mile N55 had no issue with it, neither do any of the N54s. The only issue with E85 is that over time it absorbs water and does not have the same lubrication gas does. But that's when you run straight E85 and let it sit in the tank for 5 months.
IMS-340C394.50
G.Newt803.00
      10-16-2020, 12:06 PM   #13
IMS-340C
IMS-340C's Avatar
Egypt
395
If you drove 150K miles on your N55 then yeah It should be ok.
Thanks mate for sharing this information.
      10-16-2020, 05:28 PM   #14
Foriegnmonkey1
I'm running the stage 2 91 map on MHD. Apparently the support told me to leave it on 91 because the European 91 is actually 93 here in the states.
So no idea, I'm getting around 92.7-93 octane with 2.5 gallons of E
It 100% running better than my stock 91 octane
But I want to clear a tank of the 2.5 gallon before I Log it
      10-17-2020, 03:40 AM   #15
G.Newt
99 RON in Europe is 93 octane ((R+M)/2) in the US, 95 RON is 91 octane. Unless they're talking about a different octane measurement I'm not aware of.
https://en.wikipedia.org/wiki/Octane_rating#Examples
      10-17-2020, 08:29 AM   #16
Sgm123
Drives: Bmw
Running e it’s a good idea to test the base fuel. There seems to be massive swings between stations so this could impact on the likelihood of the HPFP crashing.
Have you run any logs since putting it in. Generally e seems to clean up timing at the right amounts.
      10-17-2020, 01:18 PM   #17
G.Newt
This x10000. I ALWAYS test the "E85" every time I fill up (then do matrix reduced row echelon form to tell me how much ethanol and 91 to put in). It's an extra 3-5 minute hassle to ensure I'm getting as close to a perfect mixture as possible. And my logs look decent because of it.
      10-19-2020, 12:50 AM   #18
_N54
_N54's Avatar
300
Drives: 335d
I ran 40% E85 with meth. Your fuel lines will be fine. Yes indeed the car runs way better with even a small splash of ethanol.
2013 335is - sold
2011 335d
