01-17-2020, 10:30 AM | #1 |
Rep 11
2017 440i M-Sport without Blue Calipers?
Hey guys, I'm about to finalize a purchase on a 2017 BMW 440i Grand Coupe xDrive (Long time away from this forum glad to be back in a BMW )
The car is advertised as a 440i MSport but the brake calipers are just regular silver. Is it normal that a 4 series LCI doesn't come with the blue brakes if its msport? A google search found me another thread talking about pre-LCI models not coming with those brakes by default. Is this the case for 2017? Also the car has never had an accident however there is a rock chip on the front bumper which actually got under the paint... The car is white and you see some black under. How thin is the paint on the front bumper, is this normal? Thanks guys, and looking forward to being active here in the coming months! |
01-17-2020, 10:34 AM | #2 |
Rep 882
M-Sport is the body style (front/rear bumpers, side skirts). M Brakes are separate option - alone or as part of Track Handling Pkg, along with Adaptive M Suspension...
01-17-2020, 10:35 AM | #3 | |
Rep 5,392
It's important to look at the line items listed on the cars build sheet by plugging the VIN number into a website like mdecoder. Sometimes those codes and descriptions are self-explanatory and sometimes not so much. ADDED: For instance I've seen BMW describe both of these build codes as "M Sport". My speculation is that the origins of them having the same description may be the fact that they are coded with the same front/rear brake bias. Despite sometimes having the same description, on an F30 335i the actual hardware parts and part numbers on the car are very different: S2NHA: Front 370 mm/ Rear 345mm P337A: Front 340mm/ Rear 330mm |
F36GC_NYC159.50 |
01-17-2020, 10:38 AM | #4 |
Rep 11
Ok amazing, thanks for the quick reply! I was worried they misadvertised the vehicle since I'll be finalizing the sales contract later today....
You guys know anything about the paint issue I have? I'm worried the front bumper was repainted. Why would a rock chip get under the paint? It's the only blemish on the whole car and the carfax shows 0 accidents, 1 owner, straight off of BMW lease so I should be in the clear right? |
01-17-2020, 10:51 AM | #5 |
Rep 2,432
Drives: 2021 M2C
Yep. I have an M-Sport and only have the standard gray brakes. They work pretty well if you ask me.
01-17-2020, 10:51 AM | #6 | |
Rep 1,758
2016 428ix, r, 2018 430iC, 2018 330it
01-17-2020, 11:04 AM | #7 | |
Rep 5,392
If they've done a crappy job tell them that you want it redone properly. I've asked local high-end detailers to evaluate interior and exterior on a car that I wanted to buy. Either make an appointment and take the car for a test drive to the detail shop, or some detailers have run over to the dealership for me. Detailers are professionals so they spot stuff instantly and can help you make a dealer fix things before you buy. Even paintless dent repairs, etc. Later, I've had the detailer paint correct and ceramic coat, especially with a black car. Hope this helps! |
01-17-2020, 11:34 AM | #8 |
Rep 1,268
I'd love to see the stopping distances of 2 identical cars. One with the regular brakes & other with the upgraded blue brakes.
I have the blue brakes and they are very good but maybe the difference is marginal and thus not a must have option. |
01-17-2020, 11:57 AM | #10 | |
Rep 535
It would have been M Sport 1 and/or M Sport 2 packages. M Sport 1 was essentially the “looks” package and 2 was the “performance” package.
Current: 2023 Volvo XC60 B6 Ultimate Thunder Grey on Blonde Polestar Enhanced
Previous: 2018 340 xDrive M-Sport Mineral Grey Previous: 2016 328 xDrive Alpine White |
01-17-2020, 12:33 PM | #11 | |||
Rep 11
He has promised me the only blemish on this vehicle is that front bumper rock chip and our live video call seemed to confirm the car is pretty mint. I can't help but to believe that front bumper was resprayed though. Quote:
I looked up the VIN on mdecoder as recommended by Johnung. It shows the following: S715 M Aerodynamics Package S337 M Sports Package S710 M Leather Steering Wheel So at least the car wasn't falsely advertised which was my worry. Quote:
01-17-2020, 12:52 PM | #13 | |
Rep 894
2017 4 series is an orphan with the b58 engine and new I drive but not LCI
01-17-2020, 12:53 PM | #14 | |
Rep 11
Edit: Ya double checked on wikipedia. Looks like 2016 they started adding the new engine and iDrive (ID5), then LCI was unveiled in 2017 but started in the 2018 model year which added ID6, the new bumpers and lights as well as a stiffer suspension. |
01-17-2020, 01:54 PM | #15 |
Rep 118
01-17-2020, 01:55 PM | #16 | |
Rep 118
01-17-2020, 01:59 PM | #17 |
Rep 118
Ask them if the vehicle has the rockguard for the intercooler because realoem shows that as an item but I do not have it on my '17 440i.. maybe you can have it installed before buying the vehicle. It might take a long time because a lot of people were saying that the part has to be ordered..
01-17-2020, 02:24 PM | #18 | |
Rep 5,392
So someone who has the grey 340/330 brakes can upgrade just the rear brakes to 345's and it will be a performance upgrade. 18" wheels would be required. Calipers can be painted to match each other right on the car using G2USA Caliper Paint. It brushes on and levels out to a sprayed on look as it dries. Two part epoxy like paint that is much tougher than any other caliper paint. The most noticeable street brake upgrade by far is simply changing out the brake pads for higher quality such as Hawk 5.0 pads. Better than stock in every category. |
The0pportunist470.50 |
01-17-2020, 02:25 PM | #19 | |
Rep 11
Yes I totally plan to do this as soon as I get the car!!
The dealer I'm buying it from is not a BMW dealer so I doubt they'll be aware or know what to do. I'll take it to BMW after purchase and have them do it if this service bulletin is still around. I doubt this one has it since it appears it was added after 8/2017, this car was built before that. Edit: NVM rock guard install is definitely not free. Just called BMW, rock guard is $108 part, service dept was closed so they couldn't tell me how many hours of labor. Edit 2: Upon further reading this is an insane issue... For the rockguard to fit some people are saying the whole radiator need to be changed?? What? Many saying BMW won't cover it? This seems like kind of a big deal.... Last edited by scoops; 01-17-2020 at 02:53 PM.. |
01-17-2020, 03:03 PM | #20 | ||||
Rep 1,827
01-17-2020, 03:58 PM | #21 |
Rep 1,502
Wow I haven’t ever seen OEM paint peeling before. I’d personally suspect a repaint job - you probably want to get it inspected by a paint pro before purchase. Might need to remove and repaint the whole bumper.
01-17-2020, 04:18 PM | #22 |
Rep 115
Drives: BMW 440i Convertible
Is that wrapped? Does the Mdecoder page say it was White or Black?
