03-16-2019, 02:32 PM | #1 |
Rep 83
320d M-Sport tyre pressures after replacing RFL tyres?
I have just replaced all my run flats for Kuhmo PS91 tyres 18". Just wanted to do this to get a smoother ride.
One thing I am unsure about is should I use the same 32PSI all round the run flats were? Or should I increase the PSI? I did notice my fuel economy suffered when I had the Kumho were 32PSI so I upped them too 36PSI all round now.. The fuel is good now but the ride is very hard! Maybe I need to play and try going down to 34/35 psi and see if this makes a difference.. Just wondering what people views were on this and what people have set theirs too when replacing the run flats for normal tyres? |
03-16-2019, 03:04 PM | #3 | |
Rep 810
The reason being that with a stiff sidewall, you have to inflate the centre patch of the tyre extra so the edges dont bear the weight. This is why RFT's are so prone to shoulder wear when under inflated. The best example of this is on the early Z4's, where the //M model had ~4PSI less in its regular tyres compared to the 3.0i regular model with RFTs. The M was also heavier due to an Iron block S54. I would go 2-4PSI under the stated pressure and have a play with it, or seek out the M3's details (provided it uses normal rubber!). |
03-16-2019, 03:06 PM | #4 |
Rep 83
Thanks. I know the Kumho though have hard sidewalls. But maybe I will drop to 35 psi and see first.. Just I am feeling 36psi is too rough. And I know with m sport suspension is very hard anyway.
03-16-2019, 03:18 PM | #5 | |||
Rep 83
I guess it's trying to find that in between.... I was reading the Kumho PS91 have a hard sidewalls and are also a 'sticky' tyre. They rate F on fuel where my Bridgestone tyres were like a B I think for the run flats. |
03-16-2019, 03:22 PM | #6 |
Rep 15,858
Tyres should run at a similar pressure, if the L.I. rating is the same. Then adjust if necessary, for the best balance of handling/chassis dynamics vs. wear patterns.
03-16-2019, 03:39 PM | #7 | |
Rep 83
03-16-2019, 04:29 PM | #9 |
Rep 3,967
I personally run 35psi front and 37psi rear on the M Sport 18" wheels with non run flat tyres.
03-16-2019, 04:32 PM | #10 | |
Rep 83
03-16-2019, 04:35 PM | #11 |
Rep 15,858
Just a thought, what spec' and ratings have you fitted, standard to similar ratings, or XL with a higher load rating?
03-16-2019, 04:37 PM | #12 | |
Rep 83
03-16-2019, 04:42 PM | #13 |
Rep 15,858
03-16-2019, 06:06 PM | #14 |
Rep 3,967
03-16-2019, 06:12 PM | #15 | |
Rep 83
03-16-2019, 06:19 PM | #16 |
Rep 3,967
03-16-2019, 07:18 PM | #17 |
Rep 15,858
03-17-2019, 04:43 AM | #18 | |
Rep 83
The tyres I have are: 2 x Kumho Ecsta PS91 255/40 R18 Y (99), Reinforced 2 x Kumho Ecsta PS91 225/45 R18 Y (95), Reinforced And the sticker from my car I have attached on this post to see what you think.. |
03-23-2019, 07:47 AM | #19 | ||
Rep 83
Decided to try next week 36 front and 37 back to see how that feels for the week. Will report back :-) I don't want to go too high because ride will be very rough, plus I don't want the tyre to be wearing uneven if the whole tyre isn't making contact with road. |
03-23-2019, 08:05 AM | #21 | |
Rep 83
