07-31-2019, 10:39 AM | #1 |
Rep 80
Drive Modes - should steering feel different?
Afternoon all,
I drive a 2015 f30 320ed (Business Nav Edition) with 70k. I know it's a boring car but I love it In each of the drive modes...Eco Pro / Comfort / Sport....the engine feels different...more pokey through the modes but I've noticed the steering feels exactly the same. I used to drive an older 2012 f30 320ed as a company car and I'm convinced the steering got heavier through the modes. Am I going mad or should the steering feel change in each mode? Thanks James |
07-31-2019, 10:46 AM | #2 |
BMW CCA Member
488
Rep 808
James, you aren't crazy. On some BMWs the Eco, Sport, and Comfort modes changes the behavior of the throttle (engine valve timing), suspension and steering. On my 2015 435i M Sport those modes can affect all three.
07-31-2019, 10:59 AM | #4 |
Rep 1,240
Isn't it wether or not you have adaptive which changes the steering feel through the modes?
Current: Portimao Blue G21 330i
Previous: EB F30 340i Shadow Edition Previous: EB F30 330d xdrive |
07-31-2019, 11:02 AM | #5 |
Rep 80
07-31-2019, 11:28 AM | #6 |
Rep 724
Is it not under 'Driver Mode' in settings through your idrive, you can alter the setting for Sports mode, i have mine under the softer setting as well, it gets a very hard ride if you start to crack on a bit in sports mode
07-31-2019, 11:36 AM | #7 |
Rep 59
Very interested in this discussion as well. I feel absolutely no difference in steering effort between Eco, Comfort, Sport or Sport + on my 2013 335i Xdrive with M-Sport package. I have it set to change the engine and suspension in the idrive menu with each mode but I only notice the difference in throttle response.
2013 EB 335i Xdrive, Msport package, BM3 Stage 1 93 octane, VRSF Chargepipe
07-31-2019, 11:43 AM | #8 |
Rep 2,511
The Servotronic or VSS (Variable Speed/Sports Steering?) steering systems change with the modes.
Servotronic is standard on some cars. It was X25 engines upwards I think. Servotronic gives variable weighting. VSS gives variable weighting and a variable rack speed. The standard steering on lower output cars is fixed weight and rack speed.
Driving i4 M50 (G26)
Previous 340i Touring MSport (F31) |
07-31-2019, 12:13 PM | #9 |
Rep 1,705
Your suspension will only feel different if you have adaptive suspension, if not there's no change.
07-31-2019, 12:16 PM | #10 |
Rep 255
My steering goes from a feather in comfort to a bicep builder in sport.
I think there are options for sport mode but I've never tinkered as this setting makes more happy to drive 90% of the time in comfort. 2017 shadow edition 320d BTW. |
07-31-2019, 03:23 PM | #12 |
Rep 186
My car has the adaptive suspension and these seem to be the differences I've noticed in the different modes.
Eco Pro: Standard steering, standard suspension, soft throttle response. Comfort: Standard steering, standard suspension, standard throttle response. Sport: Weighted steering, stiffened suspension, increased throttle response. Sport+ All of the above but traction control is limited DSC OFF: Same as Sport but no traction control and rev matching is deactivated. I know that I have got adaptive suspension as it's on the VIN decoder and there is a noticeable change in suspension when changing through modes, unsure about servotronic/VSS though. I've heard that you ideally need to drive two cars back to back to notice the difference between those two options though. |
07-31-2019, 03:40 PM | #13 | |
Rep 80
Thanks. |
07-31-2019, 03:47 PM | #14 |
Rep 584
On my previous 320d SE it had servotronic steering, definite difference in weight in different modes, current 320d Sport just has standard (electric?) steering, no change in different modes.
07-31-2019, 04:37 PM | #15 |
Rep 1,338
Drives: 2014 F30 320D X-Drive
no difference in steering effort between Eco, Comfort, Sport or Sport + but as others here suggested that servotronic option is what needed and that makes sense
Current Ride: 2020 G20 M340i in Metallic Black Sapphire with Individual Full Merino Ivory White and Piano Black Trim Previous Ride1: 2014 F30 M Sport 320D X-Drive Auto, Dakota Beige Leather, M Sport Brakes, Adaptive M Suspension, Paddle Shifters, 19" 403 Alloys, Folding Mirrors, Pro Sat Nav & Harman Kardon Surround Sound. Previous Ride2: 2004 E46 M Sport 320CI Auto, Montana Beige Leather & 18" 135M Alloys.
Soul_Glo13347.00 |
07-31-2019, 04:57 PM | #16 |
Rep 15,858
08-01-2019, 03:38 PM | #18 | |
Rep 724
08-01-2019, 04:32 PM | #19 | |
Rep 7,032
Drives: 335xd Msport +
Had the same issue and concerns on my 335xd ie no change is steering weight in sport mode. I quite liked the weight increase on my previous 320d. Had a conversation with a bmw master tech and apparently it doesn’t happen on the x drives, something to do with the half shafts at the front limiting steering range etc etc Strangely enough mentioned this on an earlier post and teaston mentioned his post LCI 335xd had the weighted steering. Not sure if you code it in.
08-01-2019, 05:04 PM | #20 | ||
Rep 1,240
08-01-2019, 07:04 PM | #22 |
Rep 724
Same here, its not too bad at speeds below the speed limit, but if you do on those rare occasions get above them suspension and steering do become to stiff and therefore doesn't have much feeling.
