09-12-2019, 10:06 PM | #1 |
Rep 155
Putting EBC yellow stuff on. Pad grease questions
Have 1st track day coming and I'm putting EBC yellow stuff on in next couple of days. I usually just grab the cheap, no brand grease for my previous cars pad swaps, but wanted to see if anyone had a preference. I only plan to track a couple days per year. Im probably overthinking, but I've been told to stay away from copper these days?
Local options: https://shop.advanceautoparts.com/p/...ake+pad+grease CRC https://shop.advanceautoparts.com/p/...k-4/12024852-p Sil-glyde https://shop.advanceautoparts.com/p/...ke+anti-squeal Permatex Open to other options, but prefer something I can pick up local tomorrow. Any input appreciated! Last edited by Brotherhef; 09-12-2019 at 10:10 PM.. Reason: edit for clairification |
09-13-2019, 12:23 AM | #2 |
Rep 3,538
I don't really bother greasing my pads anymore. It won't hold up to the heat of the track.
09-13-2019, 06:37 AM | #4 | |
Rep 155
09-13-2019, 07:11 AM | #5 |
Rep 16,060
I was low on grease so I got Permatex Extreme. It works. The purple color makes it easy to see on my silver painted calipers. A year after using it I can still see it, so it doesn't melt or wash off. It's very inexpensive on Amazon:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
09-13-2019, 07:19 AM | #6 | |
Rep 155
09-13-2019, 02:57 PM | #7 |
Rep 8,492
I use a ceramic grease, and it holds up reasonably well.
However, a word of experience regarding EBC Yellows. They are, or at least they were when I tried them ~3 years ago, absolute rubbish. They faded badly with semi-fast road use, and melted (literally) on a track evening. After less than a lap the brake pedal was going long and I had to do cool down laps - ruined my session. I highly recommend Pagid. I run RS4-2 for the fronts and RSL19 for the rears, and use these for road and track. Cold bite is good, they take the heat on track very well, and they're kind to rotors. Yes they dust, and they can squeal (re-greasing the backing plates and clearing out the rotor grooves helps a lot) but this doesn't detract from the performance benefits IMO.
Brotherhef43.00 |
09-13-2019, 02:59 PM | #8 | |
Rep 155
09-13-2019, 03:06 PM | #9 |
Rep 891
I had the same on-track experience as Watsey with the Yellows albeit no problems on the street side of things. Wouldn't buy them again, that's for sure.
Definitely going to pick up some of the ceramic grease linked above.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i |
09-13-2019, 04:13 PM | #10 |
Rep 155
What pad did you end up liking for the track?
09-14-2019, 03:11 AM | #11 |
Rep 603
https://ebcbrakes.com/ebc-brake-pad-selector-tool/
RedStuff and YellowStuff are for heavy street use (good cold brake, very good warm brake behavior on street/highway, good wet brake) They are not meant for track days of n-laps. People should not blame it on the pads, if they are not able understand what the product they choose is made for! Because of its huge heat range, the applications where EBC Yellowstuff will deliver benefits range from fastest street use on higher horsepower cars and race use on most street based cars and even as a brake upgrade on Trucks and SUV. Yellowstuff is especially appreciated on Trucks for towing and heavy loads and where wheel and tire oversize upgrades have been fitted. In longer races EBC Bluestuff NDX or the new EBC Orangestuff grades should be considered The temperatures reached between the pad and the rotor in normal daily driving is around 350 to 450 C. In track day use temperatures can shoot up to 700-800C and in full race use even higher. This requires two totally different approaches to what is the best brake pad for your needs. There are many good articles to read and then choose the right product for street or track. https://ebcbrakes.com/ebc-technical-...-ec0fb519-6317 From top: RedStuff/YellowStuff/BlueStuff/OrangeStuff OrangeStuff comment: The lower curve on Lapsim 2 is the toughest test we can really do on a dyno, simulates massive brake energy and discs glowing bright orange through the brake cycle, highly doubtful any driver would race to these temps but the pads still held on to a very decent level of friction. Important to note that on this second test the cooling was halved, simulating a poorly vented brake system that can occur on street based cars without improved ducting. The disc temps shot up to over 1000C here at the end of the stops and the friction dropped but there was still a decent brake effect as shown below. This is an unusual test to do and not realistic but this was a test to the very limits and Orangestuff survived. We also doubt if any manufacturer would ever A) Run or B) Dare to publish such results but there you go. Source: https://ebcbrakes.com/product/orange-stuff/
335i F31 RWD in SB || Powertrain: Active Autowerke Flash Tune Stage 1 | AA Charge Pipe | AA FMIC | GFB DV+ | xHD Trans-Flash | Quaife LSD | Cyba 3.5" Carbon tips || Chassis: 20" 405M | Wiechers Strut Bar | Rear M-Diffusor || Brakes: 18" M-Perf Brake orange 370/345 | EBC YellowStuff pads all around || Various: LED bulbs: Fog-L. front | Turn Signal f&r | Brake L. | Reverse L. | Rear L. | Rear Fog L.
Brotherhef43.00 Eschmacher334.50 |
09-14-2019, 05:28 AM | #12 |
Rep 8,492
As I said, Yellows fade badly with fast road use as well.
Crap pads. End of.
09-14-2019, 08:12 AM | #13 | |
Rep 155
Added: new to this. Still learning. Have read tons and an overwhelming amount of options. Thanks again! |
09-14-2019, 08:34 AM | #14 |
Rep 1,127
I use the purple ceramic stuff. I also use STOPTECH sport at the track and they are wonderful once you get a bit of heat into them. Never had fade.
Brotherhef43.00 |
09-14-2019, 10:48 AM | #15 |
Rep 155
09-15-2019, 05:03 AM | #16 | |
Rep 603
I mean, how can you tell without measuring rotor temps? Just wondering. It would be interesting to see a professional test/comparison of different pads and to see, what the reason is, when fading occurs (and what temperature the different pads/rotor have when they start to fade). i.e. do a bunch of 100-0 stop. measure the braking distance and rotor surface temp after each stop until fading occurs. I have the YellowStuff on (all around) no problems/fading so far. But haven't been tracking yet.
09-15-2019, 11:21 AM | #17 | ||
Rep 8,492
I've had Yellows fade badly after just two long/hard retardations on the road. Let's just say it was 'spirited' driving on country roads that I've driven for the past 30+ years and I know where I can push when I'm trying to make the 180 mile journey in good time. Night driving and the light traffic helps progress On track they melted. When I took the pads out the next day the pad compound had disintegrated and had formed gloopy deposits around the remaining pad material. When I bled the fluid (to check its condition) there weren't any bubbles. I accept that 335D front brakes are not comparable to the Stoptech Trophy setup that I now run (fluid is the same : ATE DOT4), but the Pagids have been superb. They're in a completely different league.
09-17-2019, 08:56 AM | #18 | |||
Rep 155
If I end up getting addicted I'll defiantly bite the bullet and try some pagid or I've also read PFC08. |
09-17-2019, 09:39 AM | #19 |
Car Hypochondriac
335
Rep 901
I ran yellow stuff on my GTI for multiple years in a row, and they actually survived some pretty significant track runs and never faded on me. My issues were always fluid.
I just put yellow stuff on my 335i when I upgraded to the 370/345 calipers and god damn are they strong. Went for a spirited run on some back roads a few weeks ago and once they get warmed up they just get better, didn't have any fading issues.
Handling mods: Koni yellow - Eibach prokit - Millway street - M Performance LSD - M3 brakes - EBC bluestuff Exterior: Euro LCI tail lights - Shitty ECS CF spoiler - Chinese M performance diffuser Interior: Bavsound stage 1 and subs - custom trunk sub by Mike1327 |
09-17-2019, 11:27 AM | #20 |
Rep 3,538
I like the PFC08s more than the RSL29s. They're a bit harder to modulate (pedal becomes touchier), but the bite and pedal effort to get more braking force is much better.
09-24-2019, 10:40 AM | #21 | |
Rep 479
09-24-2019, 11:50 AM | #22 |
Car Hypochondriac
335
Rep 901
I would say the initial bite is identical or maybe a little less than oem, but they ramp up very well. Feels very controllable. I get very occasional squeals when warming up. I'm very picky about car sounds and these don't bother me.
TK335iMSPT299.00 |
