06-29-2019, 05:49 PM | #1 |
Rep 12
What methanol set-ups are you running?
Interested to find out what kind of methanol set-ups people are running.
What have experiences been like with JB4 + BMS meth kit, AEM? |
06-30-2019, 09:05 PM | #3 |
Rep 2,357
The controller is the only interesting thing about a meth setup. It determines how you can do safety functions and you injection pattern.
The BMS has a lot going for it because it run off the OBD so you dont have to add any extra sensors or tap into the original wiring harness. However, it only run with the JB4 so an expensive option. Something to read about the Torqbyte CM5-LT here: https://f30.bimmerpost.com/forums/sh....php?t=1530667
(A Dane in China) |
G.Newt810.00 |
06-30-2019, 09:43 PM | #4 | |
Rep 1,454
2022 CT4-V Blackwing 6-speed
07-01-2019, 12:31 AM | #5 |
Rep 2,357
It is complicated to setup and you need to make your own wiring harness for it. But once done it work well.
(A Dane in China) |
G.Newt810.00 |
07-01-2019, 02:44 PM | #8 |
Rep 231
07-01-2019, 04:39 PM | #9 | |
Rep 216
My car didn't feel good at all on just the jb4 alone. But I'm willing to use it as a controller. Im currently on BM3 stage 2 e30 |
07-01-2019, 05:19 PM | #10 | ||
Rep 231
JB4 alone didn't feel so nice on majority of the B58 and it's not the JB4 it was the actually restricted DME. Back end flash obviously cleared all those issues and I don't see why you can't use JB4 only to control meth with your Bm3. |
07-01-2019, 06:39 PM | #11 |
Rep 949
With the JB4 you can run it in flash tune only mode so it only acts as a meth controller, or you can set it up to only act as a meth controller and a basic safety if meth stops flowing, which is the best way to do it. Something torkbyte and the other manually wired up controllers can't really do properly.
07-09-2019, 02:54 PM | #12 |
Rep 207
There is soon to be a new product on the streets just FYI for meth kit from Twisted Tuning. You may want to wait a little more until they release it. They have had wonders with their port injection kit on the N5+ guys
Built B58 // instagram: tyler.genter
07-11-2019, 01:38 AM | #14 |
Rep 231
07-11-2019, 07:00 AM | #15 |
Rep 1,067
I'm at 55 right now...hit 25.3lbs of boost last night. Probably a bit aggressive for daily, but we'll try it for the Dyno.
07-11-2019, 02:05 PM | #17 |
Rep 231
CntryClub007489.50 |
07-11-2019, 04:20 PM | #18 |
Rep 207
Yeah I was hitting 25 psi on my PS2's but on stock that is pretty impressive/aggressive. But hey congrats on pulling that much boost out of a stock turbo & meth. Can't wait to see the numbers
07-11-2019, 04:41 PM | #19 | |
Rep 1,067
MHD BEF (JB4 Race) JB4 + WMI XHP Stage 3 BMS Intake FTP Inlet and Charge Piping CG DS-1 Catted Downpipe AWE Exhaust VP Racing M1 Methanol 50% 93 / 50% E85 |
PURE340i104.00 |
07-11-2019, 09:36 PM | #20 | |
Rep 458
07-11-2019, 09:42 PM | #21 | ||
Rep 1,067
I see some of these insanely smooth Dyno charts, they are like a work of art...look at these ones from WedgePerformance https://www.wedgeperformanceracing.c...ate-p141175285 |
07-12-2019, 12:01 AM | #22 |
Rep 1,067
I'm back! This was a quick first try, nothing special. I got Dragy video too. 11.40's!...roasts the tires on launch in 2nd gear, I don't even bother with first gear anymore, so that fixed my 1->2 shift problem. I just did M2 to 3000RPM, let it rip, slap the shifter to D and back to S mode so it nails the 2->3 shift and 3->4 shift.
2000' DA. Can't wait to get to a proper track prep in October in IL. I think the car can go deeper into the 11's. |
