03-09-2017, 08:55 AM | #1 |
Rep 1,976
Drives: 2020 G20 320i M Sport
Codemybimmer's First COMPLETE 100% iDrive 5.0 Retrofit with ConnectedDrive+CarPlay
We are proud to be very first in North America to have a fully working iDrive 5.0 retrofit on a 2016 M235i xDrive Convertible (Canadian spec) with all OEM parts.
Last week, we were able to obtain a full fledged iDrive 5.0 unit along with a screen and iDrive controller from a US 440i donor vehicle, flashed it to my vehicle's spec and loaded a custom set of FSC codes and to my surprise, we are able to retain all of the ConnectedDrive functionality that originally came with the vehicle! RTTI, Concierge, Internet and BMW Online are all working. We have experimented with this in the past and tried with various iDrive 4.0 NBT EVO equipment but due to many difference in the hardware, we were never able to retain the vehicle's ConnectedDrive functionality. We plan to make this retrofit available later this year to those who own a 2016 F2x and F3x vehicle that originally came equipped with navigation. If your vehicle was equipped with ConnectedDrive, you can keep using your existing subscription with our retrofit. Last edited by steve@codemybimmer; 06-05-2018 at 09:28 AM.. |
03-09-2017, 10:52 AM | #2 |
Rep 3,018
Drives: 2019 M2 Competition
Fascinating.. wonder if this would work for my 14 F32!
03-09-2017, 10:55 AM | #3 |
Rep 1,976
This would only apply to those who own a '16 unfortunately. '14s use different Telematics equipment that's not compatible with iDrive 5.0 hardware.
We do have converted ID5 units that will work on your vehicle but you will lose ConnectedDrive.
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
03-09-2017, 10:56 AM | #4 |
Rep 3,018
Thanks for the update. 8)
03-09-2017, 01:52 PM | #6 |
Rep 1,976
The only '15s this will work on are the F23 built from November 2014 and F22 built from March 2015.
03-09-2017, 03:14 PM | #7 |
Rep 1,976
CarPlay is now working as well.
CanadianDriver98.50 |
03-10-2017, 01:41 AM | #8 |
Rep 186
Very interesting indeed. When do you think you will have a retrofit available for this? Will it run on a euro spec '16 F36?
03-10-2017, 12:37 PM | #10 | |
Rep 1,976
If your 2016 F36 has Navigation and ConnectedDrive then this is absolutely possible.
03-10-2017, 12:38 PM | #11 |
Rep 1,976
Only in a perfect world lol
03-10-2017, 06:56 PM | #12 |
Rep 272
What are we talking in terms of cost?
Also, assuming it's doable on an Australian spec 2016 340i with ConnectedDrive? |
palomino055.50 |
03-11-2017, 05:42 AM | #13 |
Rep 186
Yes, it is fully speced and has both Prof. Nav and ConnectedDrive.
03-11-2017, 07:17 PM | #14 |
Rep 1,976
We're still not absolutely sure on whether or not this will work in markets outside of ECE and US but stay tuned.
03-12-2017, 09:36 AM | #15 |
Rep 281
03-12-2017, 12:42 PM | #16 | |
Rep 1,976
This specific ID5 retrofit would only apply to those who own a 2016 F2x and F3x that is already equipped with the On Board Navigation system and has an active ConnectedDrive subscription. In your case, we can provide you with a different ID5 retrofit that has CarPlay, Navigation, Voice Control and BMW Apps enabled but without ConnectedDrive. If you are interested, please PM.
03-13-2017, 09:36 AM | #18 |
Rep 1,976
Yes it will.
03-13-2017, 11:37 AM | #21 |
Rep 1,976
Yep, as long you have the technology package and an active ConnectedDrive subscription.
Our solution is completely plug and play and takes 10 minutes to install. All that's required from you is to remove the HVAC panel, remove the head unit and move connectors over the the new head unit. All of the coding/programming takes place here before we ship the unit to you and it is coded and activated for to your VIN. You don't need to modify any wiring or cut anything. You keep your existing head unit for lease return/warranty purpose and this will not void warranty. Right now, we are still testing on the M235i and working out some small issues.
CanadianDriver98.50 Zefjan1419854.50 |
03-14-2017, 04:39 AM | #22 |
Rep 128
Any chance of iDrive 6.0 being made available for 2017 f36 that came with iDrive 5.0?
