Login
12-07-2018, 01:25 AM | #23 |
![]() ![]() 93
Rep 158
Drives: 2017 440i Coupe M Sport
I thought that for a moment too because it said something like "pad" instead of "pads" and the price, but I thought there would be no way to purchase sides separately instead of a full 4 pad set. They just came in and they are complete sets with new wear sensors and grease included. Also with just visual checks they look correct.
Past: 2011 Acqua Minerale Blue Hyundai Genesis Coupe 3.8 Current: 2017 Alpine White 440i F32 M-Sport MPPSK - TE37 Saga |
eleven11102.00 |
12-07-2018, 08:16 AM | #24 |
![]() ![]() 22
Rep 132
Out of curiosity has anyone tried the m3/4 pads on the m performance brakes. I have them in red and my SA said they will fit as the calipers are the same? (at my cost obviously)
![]() '14 F20 M135i EWG FBO://BMC FILTER // PURE INLET// GFB DV+ // //CSF INTERCOOLER // ER CP // NGK 97506 // ER DP //MPE // MPBBK // BM3 OTS STG 2 93 AGG// |
12-07-2018, 12:08 PM | #25 |
![]() ![]() 815
Rep 1,111
12-11-2018, 07:17 PM | #27 |
![]() ![]() 22
Rep 132
i dont mind the dust are they better then the stock pads? am i correct in saying msport and mperformance use the same pads[
01-02-2019, 07:24 PM | #28 |
Masterchief
![]() 180
Rep 640
Any reviews on the akebonos or r1 concept ceramics??
So im assuming based off what everyone is saying the EUR1880 front will fit even the unfinished grey 4 piston brembos but the EUR1656 will not fit for the single piston rears???? is the 1656 does not fit do you know if the 1610 fit the single piston calipers?
BMS Intake | ER CP | VRSF FMIC & DP | MPE | JB4 | APEX ARC-8 | H&R Sport | CF Everythang Last edited by yoon_209; 01-02-2019 at 07:55 PM. |
01-02-2019, 08:00 PM | #29 | |
Masterchief
![]() 180
Rep 640
So im assuming based off what everyone is saying the EUR1880 front will fit even the unfinished grey 4 piston brembos but the EUR1656 will not fit for the single piston rears???? do you know if the 1610 fit the single piston calipers?
BMS Intake | ER CP | VRSF FMIC & DP | MPE | JB4 | APEX ARC-8 | H&R Sport | CF Everythang |
01-03-2019, 06:24 PM | #30 | |
![]() ![]() 102
Rep 1,028
I've got the Akebonos sitting in a box, but haven't had a chance to install them, yet.
2017 X5M - Current
2017 F31 Wagon - Current 2014 M5 ZCP - Retired 2011 135i Coupe - Retired 2007 335i Sedan - Retired |
01-03-2019, 06:33 PM | #31 |
![]() ![]() 93
Rep 158
From solely looking at pictures it LOOKS similar to it.
Akebono site, Tirerack, and Rockauto seem to say it would fit for yours. No mention of "Blue Caliper" in the listings. Mine too, another two weeks until my calipers are done with powdercoat. Then after that no idea when I'll have the time to install them.
01-03-2019, 07:20 PM | #32 | |
Masterchief
![]() 180
Rep 640
01-04-2019, 09:52 AM | #33 |
![]() 37
Rep 176
I did the install. Every now and then I get squealing under light braking, even though I applied anti-squeal to the recommended areas in the Bentley manual. Will try troubleshooting some more.
01-16-2019, 11:56 AM | #35 | ||
Masterchief
![]() 180
Rep 640
i've had them for a few days, no squeaking whatsoever, they do have less bite than oem but the brakes feel more linear and consistent and the best of all minimal brake dust.
01-16-2019, 12:04 PM | #36 | |||
![]() 37
Rep 176
01-18-2019, 08:29 PM | #37 | |
![]() ![]() 815
Rep 1,111
01-19-2019, 11:17 AM | #38 |
![]() 17
Rep 80
01-19-2019, 12:20 PM | #39 | ||
![]() 37
Rep 176
M4_GTS815.00 |
01-20-2019, 06:29 PM | #40 | ||||
Masterchief
![]() 180
Rep 640
I've been hearing a quick oscillating noise when I drive with the windows down and it's definitely coming from the wheels.sounds starts at about 20mpb. It's not a squealing or grinding but a oscillating noise. The noise only occurs when I'm driving and there is no noise while I brake. I'm not sure if it's the akebono pads or the r1 concept rotors. Iv the pads and rotors for about 100 miles so far. Im guessing I need to give the pads and rotors more time
01-20-2019, 08:05 PM | #41 | |||||
![]() 37
Rep 176
01-22-2019, 01:36 PM | #42 |
Masterchief
![]() 180
Rep 640
i took it back to the shop that installed the pads and rotors and they are saying everything looks fine and to give it some more time. they are saying since the pads and rotors are new the buzzing sound could be a result of the pads making contact with drilled and slotted part of the rotor while driving. i guess we will see what happens in the next few hundred miles
01-23-2019, 11:12 AM | #43 | |
![]() ![]() 815
Rep 1,111
01-23-2019, 11:32 AM | #44 |
Masterchief
![]() 180
Rep 640
well that sucks
