01-19-2019, 12:56 PM | #1 |
Not stock
472
Rep 617
M Performance Brake install - DIY? Dust shields a pain?
Hey guys - thinking about pulling the trigger soon on the M Performance brakes (370mm). I was wondering if anyone had a DIY. I know it's a caliper swap and rotor/pad change - not scared of that. Is bleeding the brakes on these cars just like every other BMW ever? I have a pressure bleeder from BavAuto. I know about the coding required. What I don't know is if I can easily access the dust shields - on other BMWs I have had to pull the wheel bearings/hubs which sucks.
Thanks!
2015 BSM 328i Sport Line - BSM
2015 BSM X1 M Sport - BSM 1992 525i 1987 325e |
01-20-2019, 04:38 AM | #2 |
Rep 464
Attached is the instruction to install the M Performance brake kit.
I did not have to replace the shields on my vehicle when I installed the MP brake kit but from the instructions, the fronts bolt right up and if you do not want to cut the rear shield (per the instructions), you will need to remove the hub/wheel bearing. Larry
2020 Black Sapphire M340iX
2014 Estoril Blue 435iX - sold |
aps335.50 |
01-20-2019, 04:47 AM | #3 |
Not stock
472
Rep 617
Thanks a TON Larry -- surprisingly hard to find!
I was looking at images and the front shields bolts are definitely outside of the hub area, but the rears as you mentioned look like they'd be a pain. One question - does the new rear shield get cut in order to put it on? Any chance you could peak under your car?
2015 BSM X1 M Sport - BSM 1992 525i 1987 325e Last edited by 5mall5nail5; 01-20-2019 at 05:09 AM.. |
01-20-2019, 01:41 PM | #4 | |
Rep 464
Larry
01-20-2019, 02:27 PM | #5 |
Not stock
472
Rep 617
Thanks - makes sense. I am sensing that the N20/N26 cars probably need a cut and shield replacement.
04-18-2019, 05:41 PM | #6 |
Rep 147
Did you do this yet? I'm trying to piece together a M Performance brake kit on my 328i (x-Drive, so larger rear hubs). Calipers, Rotors, easy. I'm more worried about gathering all the correct bolts and the dust shield issue.
04-19-2019, 03:42 PM | #9 |
Rep 3,535
x-drive cars don't need to change the rear dust shield.
eddiehatchblack40.00 |
04-19-2019, 06:02 PM | #10 | |
Not stock
472
Rep 617
https://f30.bimmerpost.com/forums/sh...1&postcount=16 Cliff notes are all cars after 7/2014 have the large rear shields as shown in the pictures of my 9/2014 build above. Also, this means you need "335i" rear rotors if your car is built after 7/2014 also regardless of 2WD vs xDrive.
04-22-2019, 03:34 AM | #11 | |
Rep 147
04-22-2019, 08:45 AM | #12 | |
Not stock
472
Rep 617
Obviously the new rotor I received was incorrect based on the original (rusty) rotor. I have a 2015 328i RWD, build 9/2014. For the dust shields you can see through the wheel - note how much area is around the rotor. These are the stock shields on my car I did not have to swap them out. Hope that helps
