BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Brake pad wear
European Auto Source (EAS)
      05-24-2018, 01:17 AM   #1
leejak
Drives: E92 M3, F12 6401ED, F32 428i
Brake pad wear
Hi I s everyone’s brake pad wear.....my F32 needed new front pads at 18,000 and rear pads at 23,000 miles......I needed to take off my front wheels today and noticed my fronts are halfway worn down at 25,000....and these were just replaced at 18,000.....most of my driving is highway so don’t understand my pad wear......quite certain no issues with calipers....
In contrast, my E92m3 driven the same did not need new pads and rotors until 90,000 miles
      05-24-2018, 03:56 AM   #2
HighlandPete
Drives: BMW F11 535i Touring
18,000 miles is fast wear for any normal driving. Were the pads definitely changed?
25,000 miles sounds more the figure for 'half pad life' with light brake use.
      05-24-2018, 07:16 AM   #3
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
Unusual pad wear can usually be traced to pads that are sticking in the pad carriers, caused by inadequate lubrication when installed.
http://f30.bimmerpost.com/forums/sho....php?t=1471617
      05-24-2018, 07:59 AM   #4
ErkanTR16
64-bit
ErkanTR16's Avatar
Drives: 2018 BMW 340i xDrive
Thats super early. Before my 340i was totaled at 50K Miles, i still had original break pads and still had some life in them.
      05-24-2018, 09:18 AM   #5
Skyhigh
Skyhigh's Avatar
321
Drives: BMW F36
Monitor your wheel temperature in the TPMS if you have that feature activated. It may give you some clues about sticking pads...
      05-24-2018, 10:22 AM   #6
leejak
Thanks for the tip!!!!.....never thought of that....will do
      05-24-2018, 10:34 AM   #7
NormanConquest
Drives: 340i
Ditto, I'm at 45 and my pads are barely half worn down and I live in the NYC metro area.
ErkanTR16439.50
      05-25-2018, 12:53 AM   #8
Big Mexican Women
Drives: 2011 528i
theres absolutely no way even the most aggressive driving can wear out any sort of brakes this quickly. can you post pics of your front and rear brakes, OP?
      05-25-2018, 04:10 AM   #9
JJS
New Zealand
116
Drives: BMW F31 335i 6MT M-Sport
Not suggesting that the OP does this, but I've seen drivers using both feet for brake and accelerator duties in automatics. If they have a habit of resting their left foot on the brake, I imagine the pads/rotors won't last long.
FWIW, my mostly highway driving F31 with 90,000kms on the clock still has pads that are not quite a quarter worn. I suspect binding pistons or some other lube-related problem for the OP, as others have suggested.
EBII 335i Touring M-Sport (Munich built July 2013)
| 6 Speed Manual | 2VF Adaptive M Suspension | 2VL Variable Sports Steering | 403M wheels | M-Sport brakes | 688 Harman Kardon | 494 Heated Seats | 610 HUD | 322 Comfort Access | 5AC High-Beam Assist | 609 Navigation Professional |
      05-25-2018, 10:21 AM   #10
Bmwman325
Drives: 2015 MG CR 335 XI 6SP
at 62k miles here, still OG brake pads here, but will need to be replaced soon.
      05-25-2018, 10:45 AM   #11
Orion4
Yup! Something is amiss with that level of pad wear. I'm at 98K on originals and after looking at mine 2 weeks ago while getting new tires installed, I have, at least, another 15-20k before doing my brake job. I may be an anomoly, but your's is definitely being impacted by something.
      05-25-2018, 11:37 AM   #12
CalCarNut
CalCarNut's Avatar
Drives: 2015 F36 Jet Black Sport Line
Almost 20K on original pads and i-drive says about 42K miles life left (taken with a grain of salt as we all know it's a guesstimate).
2015 BMW F36 428i JetBlack. Sport Line Edition
25% 3M Tint|
      05-25-2018, 12:01 PM   #13
Billfitz
Billfitz's Avatar
Take it with a truckload of salt. My right front inner pad was down to 3mm, but since the sensor is on the left front inner pad iDrive said they had 42k miles left. 3mm is when the sensor trips, at which point iDrive will give an alert and start counting down from 1,000 miles, so you can literally see it go from 40k miles or more to 1,000 miles in the blink of an eye.
CalCarNut1041.50
      01-13-2019, 09:46 AM   #14
ppetras23
Drives: 2014 328ix Sport
2014 328ix Rear Brake Pad/ Front Rotor Issue
I have a 14' 328ix and the "replace rear pads" warning just came up....the car has 23k on it ...is this even possible ?? Also on the dash is the word "BRAKE" in red? Could the emergency brake be sticking? Performance of car seems normal....? Also, I look at the front brakes as I would think they would wear first but look healthy except a healthy round gouge on the driver front rotor disc..dead center ???
As a side note I have had lots of computer software issues with this car??
Any help out there??
Pete
      01-13-2019, 11:09 AM   #15
Billfitz
Billfitz's Avatar
https://f30.bimmerpost.com/forums/sh....php?t=1471617
      01-13-2019, 12:53 PM   #16
EddieMorra
Drives: 2015 328i
Wow that seems like a pretty fast wear down.
      01-13-2019, 01:11 PM   #17
IAmATeaf
IAmATeaf's Avatar
Drives: 2015 F30 335i
2015 BMW 335i  [0.00]
I had my front pads changed at around 37k miles, didnít think that was unusually early at the time?
      01-13-2019, 05:11 PM   #18
Billfitz
Billfitz's Avatar
I say that's low with mainly highway driving, not unusual at all with mainly in town driving.
      01-13-2019, 08:19 PM   #19
greyf36
Drives: Grey F36
i got my front pads replaced @ 22k miles and the rear is about to be done as well
i was also shocked when BMW told me i need to replaced the brake during my service
and i thought something must be WRONG
but i guess its kinda just how it is with this car....even some say their pads were fine until 50-60k miles but there's still a group of lucky people out there like us that had to replace the pads around 20k miles...
      01-14-2019, 11:49 AM   #20
ppetras23
Awesome feedback everybody....BILLFITZ.... I am sure that the non lube would have something to do with it...funny my Toyota Truck is now at 40k and I have another 10-15k left...
      02-26-2019, 10:04 PM   #21
Pr3dict
Drives: '17 340
I drive like mario andretti and need to replace my fronts now at 32,000. been squealing for about 4k miles and idrive just let me know its time.
My issue is if I should replace my rears right now too =/
      02-27-2019, 07:10 AM   #22
Billfitz
Billfitz's Avatar
Squealing is usually caused by lack of lubrication between the pads and carrier, so your brakes were telling you that they needed attention 4k miles ago. As for the rears, the only way to know their condition is a visual check of all four pads.
