01-04-2019, 06:38 PM | #24 |
Rep 391
Drives: F87 M2C
I think we need to start being specific as to what 2 piece we are talking about. I'm not sure if I'm completely correct on this so correct me if I'm wrong.
The OEM rotors are 2-piece but the rotors are riveted to the aluminum hat. Then there are the semi/floating rotors that are bolted to the hat like what ECS offers. I got a set of Brembo 2-piece dimpled and slotted (09.C394.13, 09.C395.13)that replaces the OEM M Performance Brake rotors (34106797603, 34206797600) Great! It was difficult (for me at least) to find a set of 2-piece all around for the 370/345 rotors. Hopefully people will take advantage of it.
Past: 2011 Acqua Minerale Blue Hyundai Genesis Coupe 3.8 Past: 2017 Alpine White 440i F32 Current: 2020 Long Beach Blue M2 Competition PC Build: 5950x/6900xt |
01-06-2019, 02:31 PM | #25 |
Cheapskate
4447
Rep 4,993
Yeah I don't mind if they re riveted or not honestly. Just the weight savings of not having a full cast rotor. If they are that cost-prohibitive, I'll just get OEM riveted blanks.
01-07-2019, 07:45 AM | #26 |
Rep 1,934
What's your aversion to having dimples on the rotors?
01-09-2019, 05:19 AM | #28 |
Cheapskate
4447
Rep 4,993
looks and performance
01-09-2019, 09:42 PM | #29 | |
Rep 2,601
Drives: G81 M3 Touring, GR Supra GTS
Was around AUD$2k for the front pair. |
01-15-2019, 08:56 PM | #31 |
Rep 123
do you have a link to a price? ive looked on the website and cant find that price unless yours were purchased more than a year ago
01-16-2019, 04:36 PM | #33 | |
Rep 123
01-18-2019, 12:01 PM | #34 |
Rep 503
Updated***
I swapped out my R1 concept rotorsand pads for both front and rear with stoptech because of the squeaking noise in the cold. I noticed that the rotors were a bit rusty where the dimples were too. Very pleased with Stoptech so far. |
kern4174446.50 |
01-18-2019, 12:54 PM | #35 |
Cheapskate
4447
Rep 4,993
Dang. And this is your first winter with them, right? Sure it wasn't the pads? I'd probably run some hawk ceramics with the r1 slotted rotors when it comes down to it. I know high performance pads squeal some but for a daily driver i'd be more concerned with reducing dust.
01-18-2019, 01:42 PM | #36 | |
Rep 503
01-19-2019, 02:24 PM | #37 |
Cheapskate
4447
Rep 4,993
Ah gotcha. I may still give em a shot considering i don't drive much in winter. I've had EBCs in the past but I got hooked on hawks after trying them, and their easier to find/cheaper in my experience.
01-19-2019, 03:50 PM | #38 | |
Rep 503
01-20-2019, 06:29 AM | #39 |
Not stock
474
Rep 614
Hey guys - something you may want to consider here is not just the weight between the two style of rotors. If you guys are using the Brembo calipers then they're "fixed". They don't slide/adjust/float like the typical Bosch units with the separate caliper and "carrier" with slide pins. So, the idea behind the two piece rotor is to also allow for it to adjust and move since the caliper is rigid mounted to the spindle. A totally cast single piece rotor will not allow for this.
2015 BSM 328i Sport Line - BSM
2015 BSM X1 M Sport - BSM 1992 525i 1987 325e |
