BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Constant Brake Squealing F36
      01-15-2019, 07:24 PM   #1
jack10525
jack10525's Avatar
Drives: 435i GC
Hello Guys,
I have a new to me 2015 435i GC M-Sport. The brakes look to be in great shape with smooth rotors and lots of meat left on the pads. The computer says all maintenance is good for some time. The brakes squeal every day whether the car has been sitting and gets driven 1st thing in the morning or after its been driven a while. Is this just the m-sport brakes? If so I will be replacing them with aftermarket when the time comes.
2015 435i GC M-Sport Mineral Grey
( o )Y( o )
      01-15-2019, 07:41 PM   #2
CMAC’s ‘Vert
Drives: 2015 428i vert
My 2015 is also new to me and I experience the same issue...21000 till both front and back brakes need to be serviced....I hope it’s not a model year issue
      01-30-2019, 04:26 PM   #3
Assassin
Drives: F31 335d X-Drive Shadow Ed
Squealing brakes generally means that the pad is not landing square on the disc and oscillating under pressure. I suggest removing the pads etc. clean the pad and caliper surfaces that the pads locate on and apply silicon grease. Check the caliper piston is moving back and forth easily and not catching on any corrosion in the caliper. Sticky calipers are quite common. Check the locating pins carefully for any sign of wear and replace in necessary. Apply silicon grease to the pins and ensure that they move easily back and forward when located on the rubber grommets in the caliper. [these often harden due to heat and use of copper grease]. If not, replace grommets too. If that doesn't fix it, a disc resurface / replacement and new pads may be required.
jack10525145.00
      02-01-2019, 05:57 PM   #4
beardsandbeers
Drives: 2015 428i Gran Coupe
Search on the boards, there are numerous threads about this with M-Sport brakes. Also many suggestions for replacement pads to alleviate.
