01-18-2019, 03:08 PM | #1 |
Chris
Rep 2
Drives: 2013 328i xdrive
Reset BRAKE light on 2013 328i xdrive
So a few days ago when I was driving from work my brake light turned on. I bought new brake pads and sensors and replaced them and the light is still there. I searched on YouTube that i need to hold the odometer button, but when i hold the button i get a menu that shows:
1.Identification 2. Start Test 3. Roll Test 4. Stop Test 10. Unlock I really don't want to go to a dealership to get this fixed and waste more money than necessary. Can someone please help? |
01-18-2019, 11:18 PM | #2 |
Rep 50
Drives: 2015 328i xDrive
I have a 2015 328i and when I hold the trip reset button, I get maintenance reset options (brakes, oil, vehicle check). I've never gotten those options. I would try looking up different instructions for getting to the maintenance intervals, butI'm not sure if there's a difference between to '13 and '15 process
2015 BMW 328i xDrive (f30) - Black Sapphire Metallic Luxury Line
01-19-2019, 08:00 AM | #3 |
Rep 16,082
+1, my '15 doesn't show those options either. Are you pushing the correct button?
https://www.newtis.info/tisv2/a/en/f...nance/1LiqKi85 |
01-24-2019, 03:21 PM | #4 |
Big Turbo Boys N Girls
327
Rep 579
You sure your e-brake is not engaged or your rotors are not binding against the rear ebrake shoes? Lift up the rear and try to spin the rear tires... If you can't you need to adjust the ebrake tension through the access hole in one of the wheel lug nuts to release the tension.
2012 F30: G25-660 Bottom Mount Mani+ DP+ Intake, CSF FMIC, VRSF CP, Walbro 450 LPFP, PR Injection with AIC 4, S63TU Injectors, Tuned with BM3, ZF Race 4 Puck and Non SSA Pressure plate, Catless, 3.5" Quad Muffler, Custom Valved Bilstein B8 + H&R SS. Max 456 WHP - 452 WTRQ. Currently tuned down to 434 WHP and 362 WTRQ to save the rods.
