BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > M Performance Brake install - DIY? Dust shields a pain?
      01-19-2019, 01:56 PM   #1
5mall5nail5
Not stock
5mall5nail5's Avatar
Drives: E34 525i Turbo
Send a message via AIM to 5mall5nail5
Hey guys - thinking about pulling the trigger soon on the M Performance brakes (370mm). I was wondering if anyone had a DIY. I know it's a caliper swap and rotor/pad change - not scared of that. Is bleeding the brakes on these cars just like every other BMW ever? I have a pressure bleeder from BavAuto. I know about the coding required. What I don't know is if I can easily access the dust shields - on other BMWs I have had to pull the wheel bearings/hubs which sucks.
Thanks!
2015 BSM 328i Sport Line - BSM - 18" Style 397 - OEM BMW Performance Black Grill
2015 BSM X1 M Sport - BSM - 19" Style 225
1992 525i - Built 2.9L "M50" - Precision 7675 turbo, DTA standalone ECU, custom everything
1987 325e - M52 2.8L 24v swap
      01-20-2019, 05:38 AM   #2
larrylam646
larrylam646's Avatar
Drives: 2014 435i xDrive
Attached is the instruction to install the M Performance brake kit.
I did not have to replace the shields on my vehicle when I installed the MP brake kit but from the instructions, the fronts bolt right up and if you do not want to cut the rear shield (per the instructions), you will need to remove the hub/wheel bearing.
Larry
2014 435i xDrive M-Sport, Executive, Premium, Active LED, MP brake kit (SPBR), MP Carbon/Alcantara Interior Trim, MP V2 Steering wheel, MPPK (NPOW), SLI (7E), 437M, HJS Catted DP, Wagner EVO2 Comp, RDC (2VB), AFE Momentum Pro 5R, EVO ID5/6+ATM, BM3 Stage 2 91 OTS, Euro LCI tail lights (HELC), LCI 6WB, LCI HVAC/IHKA3, PMA Gen2 (5DP), 8.8" Touch CID, ACC (5DF), Adaptive M Suspension (2VF), Eibach Pro.
aps107.50
      01-20-2019, 05:47 AM   #3
5mall5nail5
Not stock
Thanks a TON Larry -- surprisingly hard to find!
I was looking at images and the front shields bolts are definitely outside of the hub area, but the rears as you mentioned look like they'd be a pain.
One question - does the new rear shield get cut in order to put it on? Any chance you could peak under your car?
      01-20-2019, 02:41 PM   #4
larrylam646
I did not have to install the shields from the kit since my vehicle came with these shields from the factory (i.e. vehicle came with 340/345 M-Sport brakes). According to the instructions, the rear shields must be cut to install.
Larry
      01-20-2019, 03:27 PM   #5
5mall5nail5
Not stock
Larry
Thanks - makes sense. I am sensing that the N20/N26 cars probably need a cut and shield replacement.
