01-18-2018, 01:15 PM | #45 |
Rep 274
Updated version
Version 1.4.0 is out! Made some tweaks to the script and more importantly, found that (Avast) antivirus interferes with predating system folders. Self-Protection (not shields) needs to be deactivated and can be reactivated after running the script!
01-18-2018, 01:18 PM | #46 |
Rep 274
01-18-2018, 01:24 PM | #48 |
Rep 274
I haven't tested earlier versions of the Launcher. Generate a new token and open in Notepad. Check the ValidBefore and ValidAfter dates in the header. Does your system date fall in between these dates? That's the only thing I can think of. Otherwise, I have no idea.
01-18-2018, 02:58 PM | #50 | |
Rep 43
my sys date is in valid value, but still no good. trying premium 2.7.1, but it asks activation key, and I had no answer from TM in summer, so used 2.5.3 I think, i should try premium 2.6.2 build 124, but i can't find correct source to download from. Can I ask you for link? UPD. 2.6.2 version asks activation code as well as 2.7.1. damn it Last edited by spudvti; 01-18-2018 at 03:14 PM.. |
01-18-2018, 05:05 PM | #51 |
Rep 274
If you're not on a virtual machine, I've read about a solution for activation as well. Had something to do with changing your system language. Google it.
Cheers, ----------- Tony Twoclicks |
01-19-2018, 01:29 AM | #52 | |
Rep 43
non virtual, US version of Win7 x64, all English.. so no language issues should be |
01-19-2018, 02:15 AM | #53 |
Rep 504
Thanks for the great tool! it would be wonderful if it was possible that you run *.bat or *.exe and it does everything automaticly (turns back date, cleans up launcher, runs it and then restores date to present), don't know if it's possible though..
01-19-2018, 05:04 AM | #56 | |
Rep 274
Cheers, Tony |
01-19-2018, 05:11 AM | #57 | |
Rep 274
Also, restoring the date to present after running the Launcher is possible. However, you'll likely end up having to use my script everytime you start the Launcher as Windows system folders will be updated to present date pretty fast as you're working. After that, the Launcher will detect a date manipulation. Since the script suffices my needs I thought it was best to keep it the way it is. |
spudvti8.50 |
01-19-2018, 05:16 AM | #58 |
Rep 1
It works!
It's working on Windows 10 Pro 1709 x64 Portuguese!
Already coded my car! Thank you very much Tony Twoclicks! Last edited by baroines; 01-19-2018 at 05:17 AM.. Reason: Bad grammar |
01-19-2018, 09:26 AM | #59 |
Rep 1,455
Probably of limited use but FYI my esys (3.2.7) and launcher (2.4.3.85) runs on an old XP laptop
Just setting the date back before starting the launcher works fine with no need to run Tony's script I know XP is ancient but as it will never connect to the internet and esys etc (at least my versions) run fine then I dont see an issue. Just coded a 2016 car without any problems |
01-19-2018, 10:47 AM | #60 | |
Rep 2,128
01-19-2018, 01:39 PM | #61 |
Rep 274
Older Launchers have limited or no date checking and allow for predating your system clock. However, they offer no support for the latest psdzdata files, which you need for coding the latest cars.
Premium Launcher 2.7.1 already lacks support for the very latest E-sys and psdzdata files. In time this necessitates migration to other solutions like E-sys Launcher Pro or BMWaicoder (too bad development seems to have stopped for that one, it was very promising). |
01-19-2018, 01:52 PM | #62 |
Rep 274
Updated version
Version 1.5.0 is out! Optimized script by removing RSA-key deletion and other unnecessary steps. Added compatibility with Launcher 2.5.3. No more endless loops for token creation and entering pin.
01-19-2018, 04:18 PM | #63 |
Rep 6
Windows system folder locked
Hi Tony, firstly thanks for the rearmer! I'm sure I'm nearly there, but get this message:
************************************************** ******************* * E-Sys Launcher Premium Rearm 1.5.0 - 19/01/2018 * * By Tony Twoclicks * ************************************************** ******************* Rearming E-Sys Launcher Premium. - Deleting Launcher config files/folders... - Changing Launcher file/folder dates... - Changing System file/folder dates... ----------------------------------------------------------------------- ERROR: Windows system folder locked ----------------------------------------------------------------------- There was a problem predating one or more Windows system folders. Avast Antivirus Self-Protection must be temporarily disabled to prevent system folder locks. Shields are OK. Afterwards, Self-Protection can be reactivated again. Other antivirus solutions may have similar issues. Please try again. ----------------------------------------------------------------------- Press any key to continue . . . -------------------- I'm on windows 10 with just the standard Windows Defender Antivirus disabled, so no Avast, running as admin, i turned off all security - Windows Firewall, Windows Defender Antivirus. [Edit: And I'm using v 1.5, on the desktop of admin user] Any ideas? Many thanks |
01-19-2018, 06:46 PM | #64 |
Rep 274
Can you do something for me:
1. Run the script again 2. Right after running it, open a command prompt and type: dir c:\programdata /tc /a What date is mentioned for the directory . (single dot)? 3. Now do: dir c:\programdata /tw /a What date is mentioned now for . (single dot)? 4. Now open Explorer and go to the folder where you installed my package. Open the Tools-folder. Right-click on RearmLauncher.cfg and select Properties. Can you give me the Last Changed date please? Don't know if I can help you, but this will give me some insight... |
01-19-2018, 09:19 PM | #65 |
Rep 740
First off, thanks for the script!!
I'm having an issue with the EST token. I've tried deleting the freetoken.est and recreating it but keep getting the "an error occured while processing the EST file" when trying to read FDL code. Any help would be appreciated! I'm running the 2.6.2 with psdzdata 63.
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD) |
01-20-2018, 02:26 AM | #66 | |
Rep 43
but still looping on token creation once again e-sys 3.27.1 Psdzdata_v3.59.5_lite launcher premium 2.5.3 win7 x64 us/en 1.50 rearm thinking about reinstalling windows |
Tags |
clock, date, esys, launcher, premium |
