12-03-2020, 12:38 PM | #5479 | |
Rep 15
I haven't reverted because this is much better. From the custom you can flash without pin it seems, but i would use the same method as how I flashed the custom to revert back to stock. But people here might have a better way. |
12-03-2020, 12:57 PM | #5480 |
Rep 15
I just finished installing andream. Everything went pretty fast.
I didn't get to explore much because it was late. Came with the following software versions and mcu(b_v.1.1.2 and mcu20.8.19.23). There is something new for update or these versions are up to date? |
12-03-2020, 01:25 PM | #5481 | |
Rep 77
12-03-2020, 03:45 PM | #5482 |
Rep 40
That seems to be a new MCU.
12-03-2020, 04:03 PM | #5484 |
Rep 40
12-03-2020, 04:15 PM | #5485 | |
Rep 31
[COLOR="Blue"] I will really appreciate if someone could kindly help me to identify the Custom Firmware I can install. I have BMW F20 December 2013 (NBT). [/COLOR] I want to get the option to turn on Front camera by pressing a button (e.g. - option button) as the below post by @lawnmower351. Also hoping that the custom firmware will fix the random issue with the auto start. Thank you so much.
BMW F20 - Dec 2013 - N13 - NBT | Road Top CarPlay/MMI | iPhone 11 Pro | Aftermarket Rear Camera with OEM PDC | London, UK
12-03-2020, 04:16 PM | #5486 |
Rep 15
Android. I haven't been able to check to much after installation.
I had some problems with the transmission selector (broken spring) and it took me a lot of time! Tomorrow I hope to check/discover more about andream mmi ! I honestly don't really know what and how to do but I hope to find out tomorrow( how to connect , what settings to do , etc).I just installed autolink and android auto on my phone ! If you have some tips maybe you will send me a pm. |
12-03-2020, 04:27 PM | #5487 | |
Rep 6,723
Many thanks 🙏 |
12-04-2020, 09:30 AM | #5488 |
Rep 15
Can someone help me with some tips, advice. I have some problems in the sense that I can't connect the adroid phone to the unit(andream ) wirelessly. It only connects via cable, bluetooth works too!
I can't find any named wireless network on my phone. I checked the wifi antenna, I tried it near/next to the phone and nothing. Am I wrong somewhere? I need to check/set something else? |
12-04-2020, 09:46 AM | #5489 |
Rep 280
New update
New update BR112 for RoadTop NBT B-Version devices can be found on the 1st page (thx Masum2004).
Unfortunately I could not detect any significant changes. As always no changelog has been provided. I assume this update for RoadTop is the one to match Andream's B_V1.1.2. |
12-04-2020, 11:12 AM | #5490 |
Rep 59
Hi guys,
so I finally had some time and installed Carlinkit, and it seems like the unit came with a new software version, maybe someone can confirm this? the MCU looks like some old version though. Anyway, it became really late and I didn't have much time to play around with it today so I just tried carplay with my company iphone and all worked well (I'm and android user so I will try to install the custom version this weekend). The problem I immediately noticed is that my reverse OEM camera doesn't work at all, the screen is just black. PDC works but there's no picture, I just get those awful lines which I immediately turned off in the settings (reverse display track), and that funny looking top view of a car with the radar display. Any ideas on this?? I set up the DIP switch number 7 to OFF since on the first page it says "7 OFF = 3rd party camera, ON = OEM camera (does not seem to have any effect)". Should I switch it to ON? Well I hope someone had a similar issue with the OEM camera in the past and solved it (I couldn't find a solution while searching this thread). I'll continue testing other stuff tomorrow. Thanks for any help regarding the reverse camera! P.s. just forgot to mention that this black screen while reverseing happens even when I'm in the idrive menu. It looks like the video signal coming to the original quadlock and going to the MMI box is not being transferred later on to the HU. I hope this is just a software and not a hardware problem, I would hate to loose my reverse camera! Last edited by IvanK; 12-04-2020 at 11:24 AM.. |
12-04-2020, 11:15 AM | #5491 |
DINAN SELLER
170
Rep 544
Been battling ANDREAM for a refund after a screen showed delivered but nothing arrived. Having a hard time with ANDREAM to do the right thing and refund me the amount.
they are giving me the run around non stop. Poor communication and not supporting the product. I will be posting the text and emails from them. BUYER BEWARE>
2024 X3M COMP, 2019 X3 M40i DINAN, 2015 335xi DINAN stage 4, 2014 BMW i8, 2010 M5 V10 DINAN S2
12-04-2020, 11:33 AM | #5492 | |
Rep 15
I've flashed it with the latest MCU version of bimmertech and all seems more fluent. |
12-04-2020, 01:23 PM | #5493 | |
Rep 12
12-04-2020, 01:50 PM | #5494 | |
Rep 1,217
Anyway, make certain that you set the camera setting to "original." |
12-04-2020, 02:22 PM | #5495 | |
Rep 59
Concerning the camera, I did set it to "original", even tried with "aftermarket" but nothing worked, just a black screen. I've been reading almost all posts concerning the reverse camera on this thread and it looks like a user wrote (on the second page) that he set the DIP switch 7 to ON for his OEM camera and it worked. It also worked when it was in the OFF position, and this info was put on the main page as the official explanation of what DIP switch 7 does. After that nobody mentions the OEM but aftermarket cameras. So I'll try with DIP switch 7 in the ON position tomorrow and see if this solves the problem. Just to confirm, everytime you change a position of the DIP switch the CAN POWER cable needs to be disconnected and reconnected after 10s to apply the changes? |
12-04-2020, 03:08 PM | #5496 | |
Rep 1,217
And yes, changes to the dip switches don't take effect until the unit is disconnected then reconnected. |
12-04-2020, 03:51 PM | #5497 |
Rep 40
12-04-2020, 07:03 PM | #5499 | |
Rep 313
Drives: 2014 bmw640gc 2015Mercedes e40
andream, android, android auto, apple, carplay, mmi, retrofit |
