05-06-2021, 08:57 PM | #7657 | ||
Rep 1,217
It was those missing features, e.g. AA widescreen support and using oem bluetooth connection for calls, etc. that drove the need for a custom option. Now all of the vendors offer these features. |
05-06-2021, 09:11 PM | #7658 | |
Rep 138
edit: damn they replied saying they have EW-BMCP-NBT04X. Is there any vendor that we know sells the A version still? Last edited by Ashhong; 05-06-2021 at 09:35 PM.. |
05-06-2021, 11:35 PM | #7659 |
Rep 1,217
05-06-2021, 11:38 PM | #7660 |
Rep 17
Hello guys, I've just got my MMI box installed and noticed two issues I am trying to figure out:
1. Sometimes when I get in the car the CarPlay isn't connected automatically and I should reconnect it again manually which is very annoying. 2. Sometimes when hold the iDrive button to open Siri the MMI box just freeze and restart. (This one is really rare but happened couple of times already when I am using the MMI box for more than 1 hour). I believe this could be fixed if I update the software but can't understand exactly which version I should pick for my unit: SDK Version: 25.0.0.7.0.0.2.0 CUST Version: B2_V1.2.0_t MCU Version: 20.10.22.16 HW Version: BMW_NBT2 Last edited by Melir; 05-18-2021 at 01:22 AM.. Reason: Found the answer |
05-07-2021, 01:09 AM | #7661 |
Rep 138
Thanks. I just bought this one on Amazon but just noticed that it says WIRED Carplay, but comments and questions do mention that it supports wireless. I wasn't aware of a "wired" carplay box. Do you think this will actually support wireless as well?
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Also you mentioned Carlinke, but I saw on the first page that they also sell a B2 version, but it uses ISPBOOT and not GEMINI. Would this be compatible with the Custom Firmware 2.0? Though like you said it might not matter since everyone has all of the features. Does Carlinke support auto day/night CarPlay switch then? Sorry for all of the questions, it's hard to find up to date info in such a big thread Last edited by Ashhong; 05-07-2021 at 01:37 AM.. |
05-07-2021, 10:06 AM | #7662 | |
Rep 499
Latest NBT2 version V.1.2.5 on this site to download. Freezing sometimes happened to me too. Just update and see it's stable. I never lost auto logon with BT and Wifi connection with Android Auto it started when I enter the car. Did you use a 5GHz channel? It's possible the signal is distorted at places with magnetrons, transmitters, DECT telephone's or other equipment with strong magnetic fields. Then you have to setup the connection again, I'm afraid. Last edited by RAAF12; 05-07-2021 at 05:24 PM.. |
05-07-2021, 10:27 AM | #7663 | |
Rep 1,217
They will likely ship the original version not the B2 but if they do, the custom sw can be modified to run on the B2 version. PM me if they do ship you the B2 version. And yes, all vendor versions now seem to support automatic night mode switching with their latest updates. |
05-07-2021, 10:50 AM | #7664 |
Rep 154
Drives: '16 SO M4
05-07-2021, 11:46 AM | #7665 | |
Rep 138
05-07-2021, 03:08 PM | #7667 | |
Rep 78
05-07-2021, 04:10 PM | #7668 |
Rep 1,217
05-07-2021, 04:21 PM | #7669 |
Rep 78
05-07-2021, 04:52 PM | #7670 |
Rep 60
Just received the Andream CIC model today direct from Andream - Model number is EW-BMCP-CIC10M - Have a few questions before I install and really hope someone can answer -I've read much of the thread..
First - To use the OEM Microphone, do I need to remove my A-Pillar or are those old instructions - Bimmertech's latest video doesn't mention that at al Second - I'm a little confused with the Dips - Out of the box 3 and 4 were set to on - I have an 8.8 inch screen with rear backup camera and front/rear Parking Sensor - What are the right Dip switch settings? Would it be 237 on everything else off? Thanks for the assist ! Last edited by scoobdawg; 05-07-2021 at 05:07 PM.. |
05-07-2021, 04:57 PM | #7671 |
Rep 1,217
05-07-2021, 05:49 PM | #7672 | ||
Rep 499
Switches number 3 and 4 are set to ON for 8.8' display. The 7 switch is only for not OEM mics. You have original OEM BMW mic, right? So the dipswitches are set to 00110000 according to CIC on https://nl.aliexpress.com/item/40001...20f131b20mZore Or just check a printed copy of the doc on the sellers site. Like I did BTW. This is the NBT version. Last edited by RAAF12; 05-07-2021 at 07:14 PM.. |
05-08-2021, 04:29 AM | #7673 | |
Rep 12
Only one sticker with NBT printed. thats it. This box cannot play MKVs with AC3 only MKVs with ACC. This box can only read USB Flash Drives wit FAT32. NTFS, exFAT is not working. when i go in the car, my iphone connect to the carplay automaticly. I can play music over Spotify, that works good, but when any body calls me i hear nothing, i must first time switch the bluetooth connection on the iphone from carplay to idrive bluetooth. Is this normal????? |
05-08-2021, 04:43 AM | #7674 | |
Rep 12
any idea??? |
05-08-2021, 06:14 AM | #7678 |
Rep 6
Hi all,
I'm currently in contact with the engineers at Andream to work out a solution, but maybe someone else has run into this problem? I wanted to install a EW-BMCP-EVO-A in a 12/2017 Mini Clubman with EntryNav2 headunit without GPS. (I've successfully done this before on another Clubman with the same headunit from the same month/year). Unfortunately, I can't seem to get this one to work. Holding the Menu button will not switch the unit to Carplay. I can still use the regular interface, all the buttons on the iDrive controller work, so I'm guessing the CAN messages are forwarded correctly. They've sent me another unit, but this one has the same problem. I've even had the chance to try both units in a 2018 Clubman with NBT EVO and another with the EntryNav2 unit with GPS. No luck... The engineers over at Andream want me to try the wired CarPlay connection, as this will also automatically switch the unit over. I will try this on Monday. If it does switch over, then it could be fixed with a software update, else both units are probably defective, but this seems statistically highly unlikely to me. Any ideas? Last edited by Umlautian; 05-08-2021 at 06:22 AM.. |
andream, android, android auto, apple, carplay, mmi, retrofit |
