BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > Midpipe instead of DP for n20 JB4
      07-06-2018, 04:35 PM   #1
M@USECOP
Drives: F30 328i Sport Line
Hello, currently looking into exhausts to pair with my JB4 (currently on map 1) and think I've settled on AWE touring exhaust with performance midpipe. My only question is if that is a suitable substitute for a downpipe for moving up to Map 2 on my JB4.
Also please feel free to share any knowledge you have on how the n20, AWE exhaust and JB4 all interact together if you have this combo.
Thank you.
      07-06-2018, 06:04 PM   #2
rjd_F30
rjd_F30's Avatar
Drives: 2013 335i 6MT
Thank you.
Swapping to the AWE midpipe is not a suitable substitute for a downpipe on an N20. The reason you get a catless downpipe is to remove the catalytic converter, which is very restrictive. The only way to do that is by swapping to a catless or high flow catted downpipe. The mid pipe is not restrictive at all on the N20.
Instagram: rjd_f30 | Current: EBII 2013 335i 6MT RWD | Retired: Jet Black 2013 328i 8AT xDrive |
      07-06-2018, 06:50 PM   #3
M@USECOP
Donít downpipes make your car code? And do you have a recommendation for a catted DP? Thanks
      07-06-2018, 07:17 PM   #4
rjd_F30
rjd_F30's Avatar
Don’t downpipes make your car code? And do you have a recommendation for a catted DP? Thanks
A catless downpipe will cause a CEL. Boatloads of threads on this and how to stop the CELs. Whether it be an O2 spacer or flash tune to suppress/clear it, there are plenty of ways around it. As for a catted downpipe (will still cause a CEL), Wagner and EvolutionRacewerks are the most reputable brands that offer catted downpipes for the N20. Don't have any firsthand experience with either, but that is what I'd recommend based off of what I've seen
      07-06-2018, 08:34 PM   #5
M@USECOP
Thanks for your help, Iíll look into those.
      07-06-2018, 09:00 PM   #6
rjd_F30
rjd_F30's Avatar
No problem Just remember that you'll still get a CEL with a catted downpipe. The only real benefit to catted over catless is less smell and not as loud. Effectively the same performance benefits between the two over stock though.
awe exhaust, jb4, midpipe, n20 328i
