03-16-2021, 01:22 PM | #1 |
Rep 105
N20/N26 CSS / Closed deck
Got my block back from CSS. I decided to just have them do the closed deck insert but not the steel liners. Instead, I'll send it over to either Millennium Technologies or US Chrome to have Nikasil-like liners applied. If anyone knows where to get plasma arc spray done let me know!
First pic is just the block, second pic is with an old head gasket laid on top. It looks good but I do have one concern about the small holes (1/8-3/16" diameter) between each pair of cylinders. The ones on the driver side (top side of the pic) are not covered by the gasket, but the ones on the passenger side don't line up with the holes in the gasket. I may end up drilling the head gasket where those holes are depending on what the head looks like in that spot. Otherwise I'll just have to accept the compromise between cooling and stiffness. navardi Kel918 |
03-16-2021, 01:51 PM | #3 |
Rep 1,058
This is good info. I was waiting for someone to do this and post pictures before I sent the spare block up there to css or just have it sleeved.
Curious to see what the gasket verdict is. To me I think it would be fine, but then again I know nothing about this. I have all the parts for the bottom end (block, pistons, rods, crank, seals, melting sleeves) and figuring out the supporting mods first before just bolting in a motor + pt6262.
MY13: TTE400 Stage 2 turbo.
e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block |
03-21-2021, 02:25 PM | #6 |
Rep 105
Actually I plan on just running the stock turbo. Maybe I'll upgrade to the Bimmerworld/MHI turbo. For what I'm doing, I don't need big power, but I do want big torque and low spool time.
Arguably the closed deck work was unnecessary, but I needed to rebuild anyways, and the added cost wasn't too much. |
03-31-2021, 06:57 PM | #7 | |
Rep 176
Even the upgraded Cut-Ring HG would have the same issue as the OEM gasket, if you drill the gasket you could end up causing it to fail prematurely, but the coolant pump is still faced with the same situation of forcing more coolant through smaller holes. As for the Cut-Ring HG you won't be able to use this gasket without sleeves as you'll damage the block once you tq the head down (Done this myself was an expensive fix). Sleeves in general have alot more benefits over the plasma arc spray, but if you want to save money and use it then go ahead, the factory coating is fine for around 30psi of abuse. |
04-01-2021, 11:12 PM | #8 | ||
Rep 105
04-03-2021, 12:47 AM | #9 | |
Rep 176
The gasket is designed to bite into the Aluminium cylinder head, but the base puts too much load on the Aluminium Cylinder walls, due to the lack of material there, at 90lbft you will see distortion and an impression into the top of the deck surface. I haven't had issues with thermal transference on sleeves however I do understand why, the coating is preferred for that reason. But the added strength properties of sleeves in my opinion still outweigh the benefits of the OEM coating. For memory coolant at 120-125 deg C is when the OEM DME will put the car limp mode, and 130 deg C the DME will shut the car off. But you have to choose what works for your application. |
04-07-2021, 03:18 PM | #10 |
Rep 261
Drives: 2017 320i xdrive
what are you doing to the engine and what is the purpose of this?
08-22-2021, 12:50 PM | #11 |
Rep 105
Super late follow up... yes I'm moving that slowly on my motor rebuild. At least I got the head on!
After looking over the cylinder head we decided to cut the head gasket to ensure the holes in the block allowed the coolant to flow. Attached are photos of the cylinder head, the head gasket on the block pre-cut and post-cut. I think the change is small enough it shouldn't affect the gasket integrity though one cut did close to the red seal. It is interesting the head gasket coolant holes are asymmetric - I assume it's to control coolant flow? |
